Old 08-12-2014, 04:54 AM
Dawnmagee Dawnmagee is offline
Mein Auto: 325i
335xi battery effecting water pump
So, I had my water pump replaced two weeks ago. The next day I shut my car off, pull the key and can here the pump continuing to run, stupidly I walk away. The next day I try to start my car and the battery is dead. I went away for a week, came back, charged the battery and brought the car to the dealership. They tell me my battery was/is bad and that's what messed up the water pump they just installed. They want to change my battery at $400 and tell me that that will fix the problem. Now I am a woman and I know I know **** about **** when it comes to cars however logic tells me that it's the other way around; the pump ran and drained my battery. However the dealership is insisting that I'm wrong. I have insisted that they take another look and that I will not be paying for a new battery if the running pump is still an issue.
Can someone PLEASE tell me if I am either correct or not correct in my assumption!
Old 08-12-2014, 07:09 AM
Mein Auto: '06 AW 330xi
I've heard of the pump failing and running continuously, draining the battery but never the battery causing the pump to fail.
It's very rare for a battery to fail.
I would get an opinion else where and if they find it's not the battery, then contact BMW NA to dispute the dealership's claim.
You can find certified indy shops in your area here: www.bimmershops.com
Old 08-12-2014, 07:18 AM
Mein Auto: 325i
You're awsome, thanks! I knew I wasn't completely crazy
Old 08-12-2014, 07:33 AM
DSXMachina's Avatar
Bimmerdex 7.4!
First, go back to the dealership. Have them put in writing precisely what they told you; that a defective battery caused the water pump to run until the battery went bad. I'll bet that there is no such statement on your work order from the previous visit.
Old 08-12-2014, 09:57 AM
Mein Auto: 325i
THANKS DSX! Since they still have my car I asked them to put it on the invoice somewhere, they're now taking another look at the 'problem'...go figure
