Old 08-12-2014, 07:34 AM
chiproller chiproller is offline
Mein Auto: 2011 328xi
Unhappy Horrible luck with my 328xi
I'm so upset. I've had two things happen one after the other and I need some advice.
First, I ordered a salad for take out and as I get in my car the lid pops off and half the salad fell into the black hole that is located between the drivers seat and the middle console area. I got most of it up but it is basically impossible to get my hand into some of the area where it has spilled and I don't know how I can get the rest of it cleaned up? Is there a way to take the car seat out?
As if that wasn't enough, I left the sunroof open (on accident) over night when it rained. There was about 3 inches of water the next morning in the back floor board areas! Any tips on how to make sure it doesn't mildew or anything? It rained pretty hard.
Any advice is greatly appreciated. My car is starting to smell
Old 08-12-2014, 08:06 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
The seats can be removed by taking out the 4, T45 or T50 torx bolts at each corner of the seat frame rails.
If you remove the seat completely, you will have to unplug the airbag module under the seat. Disconnect the battery BEFORE disconnecting the airbag module or you will throw hard faults in the MRS module and you will have airbag lights on until you can get them cleared with a proper diagnostic tool.
You should be able to just tilt the seat forward or back to clean the area you soiled though.
Wet vac all the water out. Leave the car parked in the sun with all the windows open. Using a dehumidifier or ozone generator may help. Do it fast or mold will start to grow under the carpet.
Old 08-12-2014, 08:16 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Removing the seatbelt isn't too difficult, the small plastic piece hides the seatbelt bolt.
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 08-13-2014, 03:51 AM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
I have a baby shop vac that has a very flat thin attachment. It fits in all the crevices and you can use it to suck up the water. No need to take out the seats.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
Old 08-13-2014, 07:51 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Wow! I'm hoping it wasn't Ceasar or Chinese Chicken.
If not, please clairify: Italian or Blue Cheese?
Immediate and decisive action required! If not addressed by Noon, your resale value and personal enjoyment may be permanently affected.
Old 08-13-2014, 09:18 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Just get a half dozen of those pine tree deodorant things, hang 'em all from the rear view mirror, and you're good.
Old 08-13-2014, 09:19 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by CALWATERBOY DUE View Post
Wow! I'm hoping is wasn't Ceasar or Chinese Chicken.
Attachment 458202
Take down that awful picture of The Bieb right now!!!
Old 08-13-2014, 10:03 AM
thekurgan's Avatar
Bad Lieutenant
Attachment 458202
I'm offended by her face.
Ilse
Bruna
BMWCCA #453648
Old 08-13-2014, 10:44 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Ummm...that's Justin Bieber's bad boy mug shot. I'm hoping you actually really didn't know that.
Old 08-13-2014, 11:43 AM
thekurgan's Avatar
Bad Lieutenant
I know who she is.
Ilse
Bruna
BMWCCA #453648
Old 08-13-2014, 11:47 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
I know who she is.
Old 08-13-2014, 11:58 AM
Reregistered User
Old 08-13-2014, 12:01 PM
Reregistered User
THIS or something like it....
Old 08-13-2014, 12:56 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Lessons to be learnt here
1. Dont eat in car
2. When lock car hold lock button remote for 5sec....
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 08-13-2014, 02:30 PM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
I assume you shop vac'd the water out of the car immediately. If not, you're going to wish you did.
Best thing to do is to bring the car to a detail shop, tell them your story and pay to get it cleaned out.
Old 08-13-2014, 03:10 PM
thekurgan's Avatar
Bad Lieutenant
Agree. OP needs an extractor and the seats to indeed need to be at least released and tilted to get under the seats.
Ilse
Bruna
BMWCCA #453648
Old 08-13-2014, 04:48 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
It all seems perfect timing to me, make a mess in your car, leave the sunroof open, Mother Nature washes it all up. Open the doors, mop and air out-done!
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
