Old 08-12-2014, 07:30 AM
boilerbacker31 boilerbacker31 is offline
Mein Auto: 2012 X5
Will X6 232 Style Wheels fit a 2012 X5?
Any help would be great. http://www.bmwstylewheels.com/bmw/232_a__a2_
Old 08-13-2014, 03:28 PM
Mein Auto: 2012 X5
bump? Anyone?
Old 08-13-2014, 05:46 PM
Thirdy Thirdy is offline
Mein Auto: E70Diesel, E46
e70 is listed on the link you provided. It should fit.
Old 08-14-2014, 05:32 AM
troymi troymi is offline
Mein Auto: '14 650i X Coupe
If you buy 4 front wheels you will be able to mount to your E70 X5 with no problems. If you note, the rear of the X6 has a different offset and a hub size that is smaller. You can either use the rear wheel with a hub adapter (current 74.1mm to 72.56mm) or have a machine shop bore the hub out.
If you're buying new (seems there could be better choices if you are IMO) then buy 4 fronts for easiest.
Old 08-14-2014, 02:47 PM
Mein Auto: 2012 X5
Does it matter if my 2012 X5 has the M Sport Package?
Old 08-14-2014, 03:25 PM
Does not matter. All X5 except X5M have the same hub at all four corner.
Boilerbacker? Purdue?
Old 08-14-2014, 04:05 PM
Mein Auto: 2012 X5
Yup - boiler up!
