Old 08-12-2014, 07:20 PM
SleekStylz SleekStylz is offline
Mein Auto: 2010 BMW 750i xDrive
Possible Leak
Evening everyone. My car has been giving me some error messages. First it said that oil was low, so I put a qt of oil in there. Then it said coolant is low, I also put some coolant in the vehicle. Then not even a week goes by and I get the same error messages again. Is it possible that my car might be leaking? I have not noticed any leaks from my driveway, so what could the problem possibly be? Any help on this issue is greatly appreciated. Thanks in advance.
Old 08-12-2014, 11:15 PM
jgbackes's Avatar
jgbackes jgbackes is offline
Mein Auto: 2014 750Li
Blown head gasket comes to mind. What are the details of the car?
jeff
Old 08-13-2014, 04:09 AM
It's a 2010 750i xDrive.. 50k miles on her
Old 08-13-2014, 05:20 AM
mikey2u mikey2u is offline
Mein Auto: 2011 750i
had the same problem as you. had to replace the drivers side turbo it was leaking oil. and the water pump that was leaking antifreeze. hope u have warranty. its going to cost u. u wont know cause it doesnt leak to the ground
Damn.. How much was it?
Old 08-13-2014, 06:27 AM
eflack eflack is offline
Mein Auto: 20221 750i x-drive
2k, i'm having my worked on right now for the same problem
Old 08-13-2014, 06:28 AM
I have an aftermarket warranty.. I hope that it covers this or Atleast some of it
I have the same model with 60 K
Old 08-13-2014, 06:29 AM
So do you think I should take it to the dealer or BMW mechanic?
Old 08-13-2014, 06:31 AM
Yes, you have a extended warranty.
I'll take it in this week and hope to not break the bank
Old 08-13-2014, 06:32 AM
Good luck!!!
Old 08-13-2014, 09:55 AM
u going to have to change the plugs when u change the turbo. whatever side turbo is leaking oil the oil leaks in the engine and messes up the plugs and coils. u going to get error codes if u dont change the plugs. its a big job and the extended warranty doesnt cover full labor rate.
Old 08-13-2014, 03:08 PM
I found a BMW shop that will do the diagnostic on it for me for $100. Ill see what they find and hopefully I can get this resolved. Once again thank you guys for your assistance.
