Old 08-12-2014, 07:26 PM
voiture5 voiture5 is offline
Mein Auto: 2012 X5 x35d
Great tire/wheel deal - how much should I offer?
I'm the person who posted a question recently about how to get low-cost set of tires/wheels. Thank you for all the replies.
Thanks to one of the search ideas someone mentioned, I found an ad: it sounds perfect.. someone apparently took the wheels/tires off his X5 after using them for just 2 weeks and is selling them. The size is just what I need 255/55R18
He says they were used for 2 weeks and are like new. I assume that means I don't really need to worry about checkign the tread is the same on all of them.
So, he is asking $480 for wheels+tires. Here are the photos he posted:
http://images.craigslist.org/01616_4...Wn_600x450.jpg
http://images.craigslist.org/00y0y_i...t3_600x450.jpg
Does it look a good deal to you?
All I really need is the tires. He is willing to accept an offer on just the tires. If I buy the whole thing, I'd want to sell the wheels. How much could I sell the wheels for alone (is there even much demand for such things? Most people need tires, not original wheels, right?)
Is there any risk of damaging the tires when taking them off/on.. ie should I just keep them on the wheels? I imagine there's no such risk, with a proper tire shop?
In closing, can someone give me a suggestion for how much a fair offer would be for just the tires in this case, given he wants $480 for it all, and I just want the tires.
Thank you thank you!
Old 08-12-2014, 09:05 PM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
If I remember the rims right, these are the older X5 wheels not the E70. I'm not sure they would fit: I lost track of the different center bores BMW has...
Old 08-12-2014, 09:22 PM
Yes I hadn't thought about that.. duh. Here is the E53 - it looks more like that.
http://en.wikipedia.org/wiki/BMW_X5_%28E53%29
If it's not from a brand new car, I wonder how come they're only 2 weeks old. I guess I should ask.
Old 08-12-2014, 09:24 PM
I have a follow-up simple question: if I change buy these and put them on my rims.. do I need any kind of TPMS service pack or something like that? or can they just re-use the TPMS devices on my car (the reason I ask is that when I had a puncture repaired, I had to buy a special TPMS service pack, and it was hard to find the right part in stock)
Old 08-12-2014, 09:29 PM
That's not reliable: each model comes with a moltitude of different rim styles.
Here's a resource you can use: http://felgenkatalog.auto-treff.com/?felge=1070. They look like Style 69 from the older X5. You don't find a style liking like those under the E70... Since you only need the tires you may not care, but if you resell the rims those are E53, not E70
Old 08-12-2014, 11:08 PM
Pat_X5's Avatar
Pat_X5 Pat_X5 is offline
Mein Auto: '14 F10 +'16 LR Discovery
Bore diameter and offsets are different.
I had the exact same rims on my 2002 E53.
I would pass - too old of a design unless you want to mess with spacers & hub centric adapter.
Old 08-12-2014, 11:47 PM
Am I correct that even though the rims are not worth getting, the tires should be completely fine to use on my car: all that matters is the dimensions which are apparently 255/55R18 ?
Old 08-13-2014, 05:19 AM
PAX5 PAX5 is offline
Freude am Fahren
Mein Auto: X5 50i
Re-using the tires should be fine, provided that:
1. this is a brand you can live with until your lease runs out?
2. you didn't say if these are Run Flat Tires: your lease return MUST be equipped with RFT!
3. If these are not RFT, you will be faced with finding RFT again in the future and the whole cycle starts over again ... mounting, dis-mounting, balancing, exchanging TPMS and associated costs
4. These tires MUST have the right load capacity. Look for it on the side wall, near the size. something like 109V
5. If these tires meet all of the above criteria, they have a value of between $50 to $75 per tire ... (not counting the cost of dis-mounting, remounting and balancing of course!)
As far as the wheels: they are non staggered style 69 from an e53. They have the correct bolt pattern (5 x 120mm), but the center bore is 72.56mm. The e70 CB is 74.1mm. They can be used on the e70, but must be bored out by a machine shop. If after the lease is over and you want to sell them, an e53 user can still use them with a simple centering ring to bring it from 74.1 to 72.56, readily available on eBay. These wheels have some desirability, if straight, round and true and not heavily scraped and curb rashed. Probably worth something in the order of $75 to $100 per wheel (with 72.56 or 74.1 CB). The wheels are not staggered and as such also fit other car makes, such as certain Honda models. They look good on Honda Odyssey's.
My recommendation: If the tires are RFT and have the correct load bearing, get them and sell the rims. You will incur a cost of swapping tires and re-balancing ... Otherwise, keep looking until you find the right RFT tire with enough tread left and the right load bearing to get you to the lease end.
PAX5
BMWCCA #20645
