Old 06-08-2002, 01:58 PM
wlee69 wlee69 is offline
Mein Auto: 2000 M Roadster
Need help with antenna wire @ HU
Hi - I have an Aftermarket Headunit - and up till a couple weeks ago, I used an adapter that connected the BMW factory antenna to the back of the headunit. Everything worked great and had everything properly wiredup to turn on the antenna amp.
I ended up breaking the factory BMW connector and tried cutting it off and crimping on a standard motorola plug (to bypass the adapter piece) - but I couldn't get it to work. Is the antenna just a simple co-axial cable? I connected the middle wire to the antenna cable to the motorola tip, and then the shield part was connected to the negative ground on the plug.
What am I doing wrong? Can I replace the end of the antenna cable? I called the dealer and they said that all I could do was buy the entire length and start for the rear antenna and wire it back thru the car....no crimping allowed!
Any help is appreciated...
Thanks,
Will
Old 06-08-2002, 03:06 PM
Ron Stygar's Avatar
19,585 Miles
Old 06-09-2002, 09:13 AM
Thanks Ron!
I guess I can just call up the dealer and ask for the part number listed! Weird that they said I would have to buy the entire cable again!
Similar Threads
Chicken Wire JonM Off-Topic 13 06-10-2003 01:21 PM
I can't find this wire ?? 03BMW330 General BMW 10 05-13-2003 07:47 PM
Coupe antenna part # ? karlblomquist E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 10 01-14-2003 05:40 PM
Removing windshield antenna mount Jetfire General BMW 1 08-29-2002 03:12 PM
Removing a cell phone antenna Jetfire Ask-A-Dealer 0 08-08-2002 10:51 AM
