Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 08-15-2014, 07:53 AM
fredsm3 fredsm3 is offline
Mein Auto: 2002 BMW e46 M3
Valve Ticking Chatter S52 E36 Fix
Hi all,
I bought a 2000 BMW M Roadster a few months ago. Recently, the car started to develop a very loud ticking noise that appeared to be coming from the valves. This became more and more pronounced in the last few weeks.
I was worried I may need to adjust the valves. However, apparently these cars have lifters so a valve adjustment is not the solution.
I read several posts on other forums and a few things came up. Number one, you should make sure the oil level is full. So if the capacity is 7 quarts, make sure it is not even a half quart low. Make sure it has at least 7 quarts and some people suggested adding a half or full quart to reduce the ticking.
Well, I had an oil change yesterday and of course they filled it to the full 7 quarts. The very loud valve chatter and ticking is completely gone! COMPLETELY.
I wanted to post this for readers that may experience the ticking. I think it's pretty common, so make sure your oil is topped up before you try anything else.
Old 08-26-2014, 05:33 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
proper oil level is awesome!
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 11-18-2014, 04:35 AM
Lee-UK- Lee-UK- is offline
Mein Auto: S50 Z3M
Ticker
This is a common thing in the UK too. If it starts ticking again listen and see if its coming from the front of the engine, These engines suffer with vanos seals degrading. A good service does sort this for a while.
Lee
