Old 08-15-2014, 10:10 AM
xarmx xarmx is offline
Mein Auto: 2007 335i coupe
rattling sound from 335i exhaust
I have a rattling sound coming from my left exhaust. I heard it's a butterfly flap that's causing it. I went to an exhaust shop and they said they can tack weld it open so it doesn't rattle anymore. Is this the only solution? Is this bad for the car on the long run?
It sounds a bit like this
_a__a2_
Old 08-15-2014, 10:20 AM
rattling sound from 335i left exhaust
M 07 335i exhaust rattles upon start up. Usually when it's cold.
It sounds something like this
I have heard that I can tack weld the butterfly flap and it would stop the rattling.
Is this unhealthy for the car, is there another way to fix it?
Old 08-15-2014, 10:40 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Sounds like the flap actuator has seen better days. It's not unhealthy, purely mechanical noise silencer, it serves no power purpose aside from exhaust sound < 2500 rpm or so.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 08-15-2014, 11:20 AM
Okay, thank you. I think imma get this done today
Old 08-15-2014, 11:30 AM
thekurgan's Avatar
Bad Lieutenant
You don't actually have to weld it open, you can do the golf tee mod, or pull the actuator in the trunk compartment. Either trick will leave the flap open; the actuator pull might cause a code to pop up, however.
Ilse
Bruna
BMWCCA #453648
Old 08-15-2014, 11:35 AM
What is better to do? Golf tee mod?
Old 08-15-2014, 11:42 AM
thekurgan's Avatar
Bad Lieutenant
I think if you want to leave it open, without service or techs bugging you about it being disconnected, the golf tee mod, or you can zip tie the hose as well.
Is this a sedan or coupe? I ask as the sedan can drone with this open all the time while the coupe has a different exhaust setup.
Ilse
Bruna
BMWCCA #453648
Old 08-15-2014, 11:48 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Aha! Increses back pressure @ low rom,
Old 08-15-2014, 11:51 AM
thekurgan's Avatar
Bad Lieutenant
It does no such thing, esp. on a f/i car.
Here is the official BMW explination:-
Thank you for your email to BMW Customer Information.
We can advise that the exhaust flaps adjust at differing engine speeds in order to make the most effective use of the exhaust silencer. When the vehicle is running at idle or at low RPM, the flap ensures that the exhaust gases use as much of the silencer's volume as possible, keeping exhaust noise down, e.g. when you're in slow traffic or driving in high gear.
Whereas when the vehicle is running at high RPM, the exhaust flow characteristics are adjusted by the flap to give the exhaust gases a more direct route through the silencer, thus using less of its volume. This also has the effect of allowing the engine to rev more freely as there is less restriction on the exhaust flow.
The primary reason for the flap is to make the most effective use of the exhaust silencer volume at differing engine speeds.
We trust this information is of some assistance to you but if we can help you further at any time, please do contact a member of the BMW Customer Information Team.
Yours sincerely
BMW Group UK
Elfriede McNeal
Product Information Advisor
Ellesfield Avenue
Bracknell
RG12 8TA
Ilse
Bruna
BMWCCA #453648
Old 08-15-2014, 11:55 AM
It's a coupe
Old 08-15-2014, 11:59 AM
thekurgan's Avatar
Bad Lieutenant
Coupe = better sound from leaving the flap open.
Ilse
Bruna
BMWCCA #453648
Old 08-15-2014, 12:12 PM
MuffinMan91 MuffinMan91 is offline
Mein Auto: 11 e90 335i xDrive Msport
exhaust flap is done. i just pick up my 335 today from getting the same thing fixed under warranty. they replaced the left exhaust.
I've heard that just doing the golf tee mod will fix the rattle as well. haven't done it myself but from what i understand all you need to do is unplug one wire located somewhere in the trunk
Old 08-15-2014, 12:17 PM
Verts4Ever's Avatar
Verts4Ever Verts4Ever is offline
Random Helpbot
Mein Auto: 2011 E93 335i
+1
There are also a few public statements from BMW about this over the years, in older owner manuals and even the press release announcing the MY11 E92 and E93 -- e.g., http://www.topspeed.com/cars/bmw/201...e-ar83859.html ("The 335i Coupe and Convertible dual exhaust system runs at both sides of the vehicle. At low loads, a flap channels most gas through one side to reduce low-frequency exhaust 'rumble.'")
I can't speak to the E92, but the N55 E93 has a very annoying drone with the golf tee mod.
Old 08-15-2014, 12:21 PM
thekurgan's Avatar
Bad Lieutenant
Originally Posted by Verts4Ever View Post
+1
haha, I was just searching for E93 and this mod. I wasn't sure if the drone would be there. Agree on the above, if you were to create backpressure, you wouldn't do it AFTER the muffler
Ilse
Bruna
BMWCCA #453648
Old 08-15-2014, 12:25 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
For the "golf tee mod", you pull the vacuum line off of the actuator under the car and stick a golf tee into the line to plug it.
Or, you can remove the inner panel on the left side of the trunk by the left brake light. Unplug the connector found at that spot. This will unpower the actuator, but will also set a hidden code (no dash light) that the service techs will see and occasionally ask you about,
Old 08-15-2014, 12:37 PM
Thanks for all the info guys! Will be leaving it open. The rattling sound really bothers me! And I'd rather have a louder exhaust
Old 08-15-2014, 01:15 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
My N54 E93 sounds great with the golf tee mod, no drone, like someone else reported though, the N55 with the golf tee mod drones more, I did it in my N55 X5 and then undid it as it was annoying.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 08-15-2014, 03:39 PM
Reregistered User
Now look Big K, and not to put too fine a point on it, but ol' Elfreda said it!
less restriction on the exhaust flow [flap open] = lower back pressure
ergo....
more restriction on the exhaust flow [flap closed] = higher back pressure
By Gum, I done good!
I felt it when did my Golf Tee Mod. But there was the unavoidable loss of torque and some other mildly adverse effects....I undid the deed....then she ran sweet!
Old 08-15-2014, 03:55 PM
thekurgan's Avatar
Bad Lieutenant
ergo....
I dig the comic, where do you find these things?
High rpm, not the same as low rpm, there is no way, something after the muffler (a single unit, btw), helps with low end torque in a turbocharged vehicle, hell, there aren't many BMWs that need two exhaust outlets anyway.
This is nothing more than a noise/drone suppressor. Ever wonder why aftermarket exhausts don't have a flap?
If you felt a difference, then there really is something in the bay area water, which is why I avoid our corp office.
Ilse
Bruna
BMWCCA #453648
Last edited by thekurgan; 08-15-2014 at 04:43 PM. Reason: bad speller, really bad speller
Old 08-18-2014, 09:04 AM
Verts4Ever's Avatar
Random Helpbot
Including the non-Euro spec BMW PE. Pretty sure die Ingenieure would have put a flap on all the PE versions if it aided performance.
Old 10-10-2014, 09:09 AM
cWadeb cWadeb is offline
Mein Auto: BMW
I unplugged the connector on my 335i coupe. No issues whatsoever and a pleasant sound.
However I am trouble locating the connector on our 335i convertible. Anyone have a suggestion? the panels are completely different, I did remove the one behind the tail light alas no plug.
Thank You
Old 10-10-2014, 09:22 AM
Verts4Ever's Avatar
Random Helpbot
You can also use a tie wrap to crimp the vacuum tube for the flap actuator. Same result, and (if you're still under warranty) it won't throw a shadow code visible to a potentially butthead service advisor.
Old 10-10-2014, 09:23 AM
jiveturky1 jiveturky1 is offline
Mein Auto: 09 335xi 6MT, 05 M3 6MT
Why does the golf tee mod cause a loss of torque? Perhaps I'm reading it wrong.
-T
Old 10-10-2014, 02:20 PM
Verts4Ever's Avatar
Random Helpbot
Long-running debate around here... Cal insists the flap is necessary for turbo back-pressure at low RPMs, others of us argue that it's only for noise reduction.
Cal is wrong, of course.
Old 10-10-2014, 03:29 PM
floydarogers's Avatar
Pedant and Curmudgeon
Back pressure sometimes good...
On newer cars (F3x) the flap is monitored and the SES will go on if you do the golf tee mod. BMW wouldn't have gone to that much trouble unless there were some measurable affect on the emissions.
One thing that has been brought up on the diesel forums is what happens to the turbo controls when the DPF (Diesel Particulate Filter) is eliminated/cored (sits right after the turbos). At least one tuner has noticed (or experienced) turbo overspeed/destruction after DPF removal. That's because the lower back-pressure screws up the boost control that depends upon pressure sensors before/after the turbos. That tuner refuses to sell a DP in place of the DPF unless they buy a tune that takes that into consideration.
Obviously, elimination of the flap will have a lesser affect than the DPF removal, but I could construe some effect on the pressure sensors for the gas engines, too. Speculation on that is beyond my job description...
