Old 08-15-2014, 02:11 PM
Emmyraph1 Emmyraph1 is offline
Mein Auto: X3
AC Blowing Cool One Side Only
Hello, I have 2005 X3, My ac is blowing only one side i.e driver's side, how can i correct it?
Old 08-15-2014, 02:19 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Have you checked your refrigerant?
Blowing cold on one side is classically a low refrigerant indication.
PS I moved your thread to the X3 forum. Welcome to the 'fest.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 08-15-2014, 08:32 PM
Frenchx3 Frenchx3 is offline
Mein Auto: 2005 X3
You need to recharge your coolant. That's a tell tale sign it's leaking. Make sure you use refrigerant with a leak sealer in it...
Old 08-16-2014, 06:24 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
I wouldn't do it yourself unless you have gauges. If there's a leak get it fixed don't use refrigerant with leak sealer.
Old 08-16-2014, 09:32 AM
IIRC an E83 is not dissimilar to an E46. I recharged the refrigerant every 12-18 months or so on my ZHP.
The capacity should be stamped on the under hood AC label. My E46 took 26 oz. A can of refrigerant is 13 oz., so a simple recharge kit at Autozone ($30-$25) is a good option if you want to just give it a shot.
Might just fix the issue if it is a slow leak.
If not you can always get it to a shop.
- J.C. Watts Jr.
Old 08-19-2014, 06:36 AM
rbensley rbensley is offline
Mein Auto: 2005 X3
I had the same issue. Had an a/c shop evac and replace the refrigerant. It worked for two months then it happened again, blowing cold from drivers side and hot from passenger side. Culprit ended up being a bad compressor. $1700 later and I haven't had a single issue in 3 months.
