Old 08-15-2014, 02:35 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2011 328ix
bird poop and clear coat damage
trying to remove a spot of bird poop on the hood was very difficult and yes the car has been polished and sealed -was but few months back
anyway, there appears to be permanent damage to the clear coat.
ive used scratch remover, buffer marks remover liquid to no avail.
its rough to feel and even shows in iphone picture
anyone every heard to such. i thought we had a harden clear coat.?
surely goodness and mercy will follow us all the days of our lives
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 08-15-2014, 02:44 PM
v8power v8power is offline
Mein Auto: 2013 550xi M-sport
Birds have strong acid content to digest all kinds of bacterial insects and whatever dirty stuff laying around. There is a 6 hour window from pooped to baked in the sun to clean off before the clearcoat is etched.
A rotary buffer with cutting pad and compound will work as it remove a layer of the clear. I always have a rag and a quick detail spray to wipe off bird **** when see it right away. People think im ocd but they dont know what damage will be done if left on.
2011 X5 35i Sport
2007 E92 335i
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
clear coat is just clear paint, nothing really special about it unlike Mercedes clear. A local shop should be able to take care of it for you, it just need a small layer removed and polished.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 08-15-2014, 02:55 PM
blue boy's Avatar
ive been told that i have type 2 bird poop which fracture the clear all the way thru to the base coat
ive had cars set out for yrs and not have this problem
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 08-15-2014, 03:37 PM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
that is why I always care in my car a bottle of "Meguiar's Quik Detailer Mist & Wipe" and microfiber cloth.
Old 08-15-2014, 05:34 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
This is certainly better, but even a bottle of water and rag will do, for quick removal of bird poop. Anything is better than leaving it on your paint.
In terms of paint quality, some bird poop is stronger than others. I don't think any paint is immune; BMW, Mercedes, or any other.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 08-15-2014, 05:50 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
I keep a bottle of Detailing spray and a fluffy microfiber in the trunk for the inevitable bird bombs. Letting them bake in the sun is a death knell for the paint finish.
And yes, some birds poop is way more acidic than others. Best to not try to guess but get it cleaned off ASAP!!
That being said, one thing I've found helps mitigate the etching is to get the poop cleaned off without further scratching the clear coat, then spray pure isopropyl alcohol on the area liberally then cover with a cotton ball soaked in ipa and let it saturate for about 15-20 minutes. Rinse with water and then use a rubbing compound like Meg's 105. You can usually lift the etch and finish the polishing.
If this sounds like too much work, have a body shop or a reputable detailer do paint correction.
Just get the poop off asap and as gently as possible.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 08-15-2014, 05:53 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
BMW paint is a lot thicker, and IMO much more robust than econobox paints of Toyota, Honda, Mazda...
The worst off are dark paints, especially black. Heat accelerates the enzymatic breakdown of paint, and then there's the cycle of heat expansion and contraction of the paint which might trap in the damaging enzymes/acid.
Usually when I hear about a case that's really bad, it's with dark paint. You don't often hear about this happening with Alpine White, for example.
Old 08-15-2014, 07:22 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
I have been told that a 5% solution of sodium bicarb and water neutralizes the poop. Although lately, the idea of avoidance seems to have a certain appeal - white paint job for my next car.
Old 08-15-2014, 07:24 PM
Kind of hard to see the etching of clear coat with Alpine White. You could feel the etching before you saw it.
