Old 08-16-2014, 08:24 AM
Rough Neck Rough Neck is offline
Mein Auto: X3
Angry rough start up
I have a 06 and 04 X3. My 06 have a rough start up most ever time Cold or Hot. I have switched out many parts from my 04 and nothing has changed. When I reset the engine codes that read bank one and two are to lean at the same time it will stay off for a very long time and engine still starts and runs bad for only the first say 5 to 15 seconds. I have replaced fuel regulator and check pressure. Check for air leaks, MAP, replaced and recheck air intake boot. Many other parts that I cant recall the names. Had a friend check 02 sensors with his OBD2 tester all-good.
After the 10 second car runs fine.
Old 08-16-2014, 10:38 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Have you cleaned the idle control valve? It's below the DISA. Looks like a silver cylinder. It needs to be cleaned periodically due to carbon build up.
Old 08-16-2014, 12:51 PM
Mein Auto: X3
Yes I have cleaned both ideal valves and swapped them. No change
Thanks for your reply
Old 08-17-2014, 09:14 PM
iamjamen iamjamen is offline
Mein Auto: E90 335i, E83 3.0i
Did you check the oil return line that runs from the oil separator to the dipstick? It is made out of rubber which can deteriorate from prolonged exposure to oil. If it loses strength it can collapse and cause the engine to run poorly.
Old 08-19-2014, 07:45 PM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Smoke Test
have a smoke test done, you probably have vacuum leak(s).
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 08-21-2014, 02:27 PM
Mein Auto: X3
I visual checked and seen nothing broken. I was not aware of this when I cleaned the idle control valve. or I would of tore into this. Would this make the engine run bad all the time or just the first 10 seconds that Iím experiencing?
Old 10-31-2014, 02:36 PM
Mein Auto: X3
Its been a while, but I finaly got it. It was the crank case vent valve. This will cause rough idle for the first couple of seconds on start up. I seen on you tub about taken off oil cap and lisen for a hard sucktion. That did not work for me. Start engine up take of oil cap and hold your hand over the opening and if your hand starts to suck in and hard to pull off then your valve is bad. You will even here your engine rpms change. Also If you see your spark plugs oil found may also be from the Crank Case Valve and hoses.
