Old 08-16-2014, 12:16 PM
Mrjee Mrjee is offline
Mein Auto: F01
Knocking noise from front
Hi!
My car is making weird noises, it sometimes happens at slow speed going over bumps and when turning right left under load.
Ive had the car up, but could no see anything or replicate the sound. Any ideas?
It almost sounds like the dampers.
Car has adaptive drive.
http://s106.photobucket.com/user/ls1...ba85d.mp4.html
Old 08-16-2014, 12:51 PM
Leftlane11 Leftlane11 is offline
Mein Auto: 2012 750Li
I would guess suspension related - I had a similar noise and I believe the fix was to replace the torsion struts (?) if I remember right.
Old 08-16-2014, 09:36 PM
MrLXI2010 MrLXI2010 is offline
Mein Auto: 2010 750LI XDRIVE
That's sounds similar to my issue only thing it was only on left turns when going forward or backing up. Turns out it was the ars module that was bad replaced under extended warranty no more issues.
Old 08-17-2014, 06:03 AM
Mein Auto: F01
Thanks guys, Im going in for a service in less than 2 weeks, so ill make sure to mention these things to the tech. He did say he suspected the motor in the ARS system has some play.
Old 08-18-2014, 07:03 AM
BMW7XAudi BMW7XAudi is offline
Mein Auto: 12 750LiX
I think some of the cars had bushings that were glued or painted to the struts or sway bars. They basically didn't work and would make a groaning or creaking noise over speed bumps, driveways or slow turns you could hear it. Is it really annoying?
Old 08-18-2014, 08:02 AM
Well they found a cracked bearing and replaced the bushing as well only to find that the noise did not go away. I went to pick up the car and as soon as I backed and turned to the left I heard it, they sent a tech out and he immediately said it was the control box and that was causing this issue. They replaced a valve block p#37-14-6-775-258:371030 also hydraulic fluid
also 83-29-0-429-576 toothed ring:619500 which fixed the problem hope this helps. He said it seems to be a common problem but normally if they cant replicate it is hard to detect because it is not always constant mine was normally after a cold start and only last for a little for probably half an hour but the dealership is 2hrs away damn!
Old 08-30-2014, 09:42 PM
Mein Auto: F01
Got the car back from service, the tech went over all the basics and checked for any play, could not find anything. Its going back for more diagnostics, ill make sure to mention to disconnect the front stabilizer bar and see if it still makes the noise. Yes, very annoying!
