What does this indicator warning mean? - Bimmerfest - BMW Forums
Old 08-16-2014, 04:15 PM
blondie2010 blondie2010 is offline
Mein Auto: 2007 328XI
Hi Everyone -
I have a 07 328xi. Recently had an oil change by a local mechanic who works exclusively on bmws. He's done many oil changes and it's always been fine although every once in a while the indicator light comes on because he's forgotten to reset something.
This time, immediately post the oil change, the warning light comes on whenever I start the car with an exclamation point suggesting service. I have attached a picture of the dashboard, because I don't see this graphic/image anywhere in the manual. Also, I brought my car back to the mechanic and he thought it was referencing the 'coolant' which he topped off, but this doesn't look like the coolant graphic to me.
Does anyone know what this image means?
Thanks in advance -
Kristen
Old 08-16-2014, 04:50 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
Cabin air filter.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 08-16-2014, 05:01 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
aircond filter
$30
10 min diy
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 08-16-2014, 05:51 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
As noted, it's the cabin air filter replacement notice. $20 from Amazon for the filter (http://www.amazon.com/Mann-Filter-CU...KY7J48S8A32AQ4 fits mine, but does not necessarily fit yours). 5 minutes to change if you have the right size socket driver to remove the six screws that hold the cover in place. Possibly the easiest Do-It-Yourself maintenance item there is.
Old 08-16-2014, 05:53 PM
that's so helpful
thanks very much!!
Old 08-17-2014, 05:54 AM
jmsent jmsent is offline
Mein Auto: 07 335i Coupe
Bear in mind just changing the filter won't turn off that warning. You still have to reset the indicator. In fact, you don't have to change the filter at all to to turn off the warning, but it's a good idea to do so.
http://www.bimmerfest.com/forums/sho...t=red+triangle
Sold-07 335i COUPE-SPACE GRAY-STEP-SPORT-PREMIUM-COLD-SIRIUS-RFT DELETE
