My 06 330i has been a PITA - Bimmerfest - BMW Forums
Old 08-16-2014, 04:59 PM
ewolr ewolr is offline
Mein Auto: Toyota Tacoma
I have an 04 530i and an 06 330i. The 5er has had a few issues, but nothing like the 3. So far I have:
  • Replaced the idler pully bolt when the head snapped off
  • Replaced the left xenon head lamp
  • Replaced the water pump and thermostat
  • Brakes - which is to be expected
  • Battery which is to be expected
  • Replaced the starter (PITA)
  • Replaced the crank shaft position sensor. Same as starter and I believe I cracked it when I did the starter
  • Replaced the transmission mechatronic sleeve
  • Currently work on replacing the rear bearing
  • Looking like I need a new CV and Flange due to galling
  • Replaced the driver side power door actuator
Seems like a lot for what it is. I still love driving the thing so I just put up with it.
Anyone else have such issues?
Old 08-16-2014, 05:08 PM
Nerdboss Nerdboss is offline
Mein Auto: 2015 X3 35i
How many miles? It's the first model year and a BMW so issues are to be more likely.
2015 X3 35i | Black Sapphire | Technology | HK | Cold Weather | Xenon | X-Line | Premium Package | Driver's assistance |
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats (sold)
Old 08-16-2014, 05:33 PM
It's got ~ 95K. I have had it since it had ~25K. It is the first model year, but I do not believe they have re-engineered any of these components. Some of these items are to be expected. The difficulty/heartburn is somewhat related to the location of some of these components. For example, I have never seen a car that requires you to remove the intake, and about 14 electrical connections, to change a starter. I should have replaced the damn oil separator while I was in there but I did have to replace some of the hoses since they crumble when you touch them.
That water pump is pretty crammed in there as well with an octopus of hoses coming off that thermostat.
Old 08-16-2014, 10:34 PM
MB330's Avatar
MB330 MB330 is offline
Mein Auto: 2006 330i
I had few more items not on your list, but 80% what you discribe I have also.
Didn't replaced my right parking light yet. On my third set of tires, second battery and water pump. Was issue in gas tank with evaporator - CEL light was on for more then year until I get fixed ($650). Both front and rear actuators dead in 3 days a part.
'16 320i Alpine White/Black/AT [ZDA, 494, 205, 459, 403]
Old 08-24-2014, 03:29 PM
Boraxo Boraxo is offline
Mein Auto: ED 330i
My 330i has 96k miles and I've had these issues:
But not these:
Of course, I just spent close to $1200 to replace the Oil Pan Gasket and belt tensioner, and spent $1000 at 60k to fix transmission leak and replace fluid. It seems BMW does not buy long lasting seals for any fluids. And let's not forget the radio pixels issue that has plagued the car for a long time.
There is a reason BMW original warranty expires at 50k, because they know that parts will begin to break at 50-75k, and then it gets even worse between 75k-100k. Hence the extended warranty only runs another 2 years.
1993 325i - gone!
1997 328i - gone!
Old 08-24-2014, 03:34 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
My E90 has been a PITA in its first years. Most non BMW people would have qualified it as POS.
But it has been surprisingly reliable in the last 3 years - now at 81K miles. *knocking on wood*.
Old 08-27-2014, 06:31 AM
kevinescobar kevinescobar is offline
Mein Auto: 328XI E90
My 2007 328xi has the xenon headlights and the driver side just turned pink. 113k miles on it. Should I just replace the bulb or might it also be the igniter(ballast)??? Click image for larger version
Old 08-27-2014, 09:02 AM
spencers's Avatar
spencers spencers is offline
Replace both bulbs. The other side is likely to die soon as well
Old 08-27-2014, 09:04 AM
Old 08-27-2014, 09:23 AM
How often should the ballasts be replaced?
Old 08-27-2014, 10:46 AM
Mein Auto: '06 AW 330xi
When they fail.
I've had the following replaced.
Water pump/tstat
2 Batteries
Oil Level Sensor
Engine head (for ticking valve lifters)
Trans pan and gasket (cracked pan on high pavement)
1 D1S bulb
Various other bulbs (but upgraded them to LED)
All fluids, including lifetime
Fender liners (I tear through them sometimes)
These were replaced more so for handling improvements:
All suspension mounts and bushings
Shocks/struts/springs for coilovers
sway bars
arms to ///M arms
Over the course of owning this car for 8 years, I would say this is all normal maintenance, minus the engine head replacement, trans pan, and fenders.
