Old 08-16-2014, 07:08 PM
dgolf dgolf is offline
Mein Auto: 2012 528 Xi
Towing Advice For 2015 X3 28Xi
Just got my 2015 X3 28 Xi with BMW towing installed. I have never towed anything before, first to towing.
I was reading the owners manual and it says some thing about turning off all collision warning, blind spot monitoring etc.. before towing. It does not clearly say if this is for towing other cars using the BMW hook or for towing trailers with the installed tow kit?
Any one with experience please advise.
Thanks.
2015 X3 []
2012 528Xi
2011 X3 Titanium Silver [Gone Bye, Bye ]
Old 08-17-2014, 06:17 AM
IndyDog IndyDog is offline
Mein Auto: Alpine White X3 28i
I would suspect that whatever you'd be towing would interfere with their functions, however the techies here will probably have a more definitive answer.
What is it that you'll be towing?
Old 08-17-2014, 06:15 PM
A small U Haul trailer... this time..
2015 X3 []
2012 528Xi
Old 08-17-2014, 06:55 PM
Doug in NC Doug in NC is offline
Mein Auto: 2011 x3 28i
I have a 5 x 8 trailer I've pulled many times with my 2011 X3. Not much to it really. Allow for longer stopping distance. If they programmed it correctly you should be able to use the backup camera to view the hitch when hooking up the trailer. This is very useful for lining up the ball with the trailer.
Old 08-18-2014, 05:19 AM
Thanks Doug.
Do you have to disable any of the collision warning systems or blind spot monitoring etc. before towing?
2015 X3 []
2012 528Xi
Old 08-18-2014, 05:44 AM
My X3 does not have all of those features. However I don't have to disable anything. The car is probably smart enough to disable selected features once the trailer is plugged into the harness. I have found that it's best to turn the car off, then connect the trailer wiring harness and then restart the X3. When I follow that sequence the backup camera and sensors know there is a trailer back there.
Old 08-18-2014, 07:32 AM
invisihitch invisihitch is offline
Mein Auto: 2012 X3
The blind-spot monitoring system relies on side radars that are located at the rear sides of your vehicle, behind the fascia. When you connect a trailer, the side radars are no longer located at points where they can properly monitor whether anything is alongside your combined vehicle+trailer. So the system cannot properly warn you.
I assume the owners manual instructs you to turn off blind-spot monitoring when towing because, by turning it off, you are saying "I am aware that I cannot rely on the blind-spot monitoring system." Otherwise, you might rely on the system's lack of a warning and change lanes when a vehicle is alongside the rear portion of the trailer (a false "no alarm" from the system). I suspect BMW doesn't want the legal liability of you doing that and then claiming that you relied on its monitoring system to your detriment.
I am not well versed in the collision-warning system, but similar issues probably arise there also.
Old 08-18-2014, 07:41 AM
Thanks Invisihitch
2015 X3 []
2012 528Xi
Old 08-18-2014, 07:59 AM
Fjrmann Fjrmann is offline
Mein Auto: 2011 X3 X35i
Thanks.
What will you be towing?
Old 08-18-2014, 09:41 AM
Small U Haul Trailer
Small U Haul Trailer..
2015 X3 []
2012 528Xi
Old 08-18-2014, 12:12 PM
towing the small U-Haul is very easy while moving forward! I recommend opening the back hatch and drop the rear seats for better rear visibility. check your surroundings, be patent, and don't get flustered. Backing the short wheelbase trailer will be a challenge.
Old 08-18-2014, 12:25 PM
Fjrmann
Thanks.
2015 X3 []
2012 528Xi
