Old 08-16-2014, 07:15 PM
bmwx3thirteen bmwx3thirteen is offline
Mein Auto: X3
Smile Replace headlight bulb
Hi All,
I am new here and I am happy to be a part of the bimmer family.
I recently bought a 2014 BMW X3. I like the ride. The only thing I miss is HID headlights. So I am planning to replace the headlights and fog lamps bulbs with a whiter Xenon type halogen bulb. I was able to get access to headlight bulbs but I was not able to remove the bulb from the holder. I took a pic of the bulb holder and could see 3 clips. But I couldn't remove it. The manual is not at all clear. I am not an expert so wanna play safe.
For replacing fog lamp bulbs, manual shows that the whole housing should be removed from the front. No need of reaching it from behind the bumper. But I am still not clear how to do it. I bought an LED bulb as a replacement for fog lamp bulbs from Amazon. I think that should fit correctly.
Please advice. It would be great if anybody could share a video or detailed pics with the steps to be followed.
Old 08-17-2014, 07:23 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
Those tinted halogen bulbs are pretty useless, they will never perform as well as the HID. If you put LED bulbs in the fog, you will need resisters to prevent the light out warning light on the dash. I believe the fog are held on by clips inside the bumper.
Old 08-17-2014, 09:41 AM
Mein Auto: X3
Thanks a lot. I know HIDs r more efficient. But it will cost $4.5K to replace it at dealership.
So please advice how to remove the bulb. Bulb is held strong in the holder.
Old 08-18-2014, 12:53 PM
Mein Auto: X3
Hi All,
At last i successfully replaced headlight bulbs. Its pretty easy.
Tip: There r three clips - one at 2 o'clock, one at 6 and one at 10. So push the bulb up so that it become free from the 6 o'clock clip. One that is out pull a little and pull it vertically down and voila the bulb is out. While placing the bulb back make sure the pointed strip is up and 90 degrees to the ground, and just push it in.
I have installed Philips Diamond vision and it looks cool. Exact replacement for HIDs. Will post some pics.
But I am still stuck with the fog lamps bulb replacement. If anybody could figure out please let me know. There is a release hook, I am not sure how to release it.
Old 08-18-2014, 01:16 PM
Check out this thread:
http://x3.xbimmers.com/forums/showth...light=foglight
Old 08-18-2014, 04:37 PM
Mein Auto: X3
Awesome
The X Men, U R THE MAN. Thanks, that gave me an idea and I was able to replace the bulb.
Old 08-19-2014, 06:55 AM
Maybe you can share with us how you replace the bulb on the fog light.
Old 08-19-2014, 08:13 AM
Mein Auto: X3
Sure I will. I installed an LED bulb and now its showing warning on the dash. So I am looking for a halogen or error free LED to replace it. Once I buy that I will make a video or take some pics.
Old 08-19-2014, 08:18 AM
You can also buy a resister or a canbus canceller.
Old 08-19-2014, 12:03 PM
Mein Auto: X3
But will that void the warranty. I have heard BMW guys are strict about it.
Old 03-30-2016, 06:18 AM
Image2Pixel Image2Pixel is offline
Mein Auto: 2013 X3 xDrive
Xenoflo bulbs
I just purchased the Xenoflo compact HID system for my X3 from JLevi-sw.com. Since my X3 came with Halogen bulbs, I am hoping this will work as a substitute to OEM Xenon. I installed, but got error codes, so took them back out. After contacting JLevi, they are sending me Error Cancellers and I'll try the install again.
I had problems getting the bulbs seated properly in the headlight housing. Am I right to assume they just pop in and are not turned to secure?
