Old 08-16-2014, 09:19 PM
e46_newbie e46_newbie is offline
Mein Auto: 2005 325Xi
Best course of action - multiple engine codes
Hello everyone!
I recently purchased a 2007 335i w/ approx 87k. The car is absolutely gorgeous but I am a little concerned it has some lingering issues.
It is currently in "limp" mode and has the following three codes pulling up: P0015, P1153, and P1154. In addition to this the DSC is currently disabled as well. At idle, the car does make some unique noises and does idle rough. However, even in limp, if you place into gear and get moving, all unique noises go away.
I did some research and pulled out the VANOS solenoids today and cleaned with compressed air. During this time I also disconnected the battery thinking this may clear some codes. I reinstalled everything and the codes remain. I did not use any carb cleaner on the solenoids. Also when starting the car for the first time the motor did make some lifter/valve ticks.
Luckily I also purchased an extended warranty on the vehicle but am curious if pulling the solenoids again and cleaning with a carb cleaner would be worth the shot.
Also, could the rough idle be contributed to the vehicle having an open atmosphere BOV?
Thank you so much in advance.
Old 08-16-2014, 10:09 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by e46_newbie View Post
Hello everyone!
Well, have you checked the resistance across the Bank2 O2 Sensor 1 heater? Sounds like a partial or total short.
Old 08-17-2014, 09:58 AM
I have not looked over the O2 system as the P0015 is for the cam position sensor. Which after research on here, appears to be related if the Vanos solenoids are going bad. With my initial post, I am going to pull today and clean with a parts cleaner. Will get some new ones ordered up as well. I will also pull my plugs as who knows if they were ever replaced by the original owner. Is there an easy way to check the HPF system?
