Old 08-17-2014, 08:48 AM
Maxhere Maxhere is offline
Mein Auto: BMW X3 xDrive35i
Gas type for X3
Just wondering what fuel type everyone is using: midgrade or premium?
Old 08-17-2014, 09:12 AM
02420X3 02420X3 is online now
Mein Auto: 2011 X3 35i
Premium. Always. And Top Tier when I can get it, which is usually.
Old 08-17-2014, 09:26 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
89 octane is min requirement but BMW recommend 91.
Old 08-17-2014, 09:27 AM
IndyDog IndyDog is offline
Mein Auto: Alpine White X3 28i
Which engine type is it? Normally aspirated or turbo? Ours is NA and the manual states:
Super Premium Gasoline/AKI 91 or AKI 89
BMW recommends AKI 91 or 89.
Gasoline with lower AKI
The minimum AKI Rating is 89.
If you use gasoline with this minimum AKI Rat***8208; ing, the engine may produce knocking sounds when starting at high outside temperatures.
I'll use 89 unless it knocks.
Four poppers are turbo charged and will need the higher octane.
Old 08-17-2014, 10:54 AM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
How about RTFM instead of, 'what is everyone using'?
Old 08-17-2014, 12:58 PM
missedbass missedbass is offline
Mein Auto: 2012 x3 28i
I've used 89 without any problems but usually I will mix it up with 93 now and then. On a trip I will use 93. Don't know if the higher grade will get you better mileage or not. 6cyl. na
Old 08-17-2014, 01:24 PM
I don't get why higher octane would lead to better gas mileage? All a higher octane does is prevent detonation as a result of the heat generated by the compression of the piston. I'd think that not romping on the gas from a start would be a good way to save mpg (but what fun is that?), other driving habits will affect mpg more than octane differences.
Old 08-17-2014, 04:06 PM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2014 550i M Sport
Not another 'I bought a $50k BMW but I want to cheap out on fuel' thread topic. Yawn.
2014 550i M Sport, European Delivery May 2014
2013 X3 35i, Dealer Delivery July 2012
Gone, but not forgotten:
2006 530i
, European Delivery June 2005
2008 335i Coupe 6MT, PCD November 2007
2011 550i M Sport, European Delivery May 2011
BMWCCA #350568
farg farg is offline
Mein Auto: 2014 X3 3.5i M Sport
We are all driving vehicles that likely average $50K cost across the board Why quibble about 5-8 bucks a tankful for premium fuel?
If economy is the prime driver, then I suspect we should all go out and buy Priuses (Priae?)
IJS
Old 08-17-2014, 04:32 PM
IJS
Thanks for spending my money. I just sold my boat that drank 50 gallons an hour, if I feel like buying 89 I will.
Old 08-17-2014, 05:24 PM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
Because basic thermodynamics demands that to get efficiency and power from an internal combustion engine higher compression ratios are needed. High compression ratios, for a given set of conditions, reduce the margin to detonation. Therefore a higher octane fuel is needed to maintain a safe margin.
If you use a lower than recommended octane, the margin to detonation is reduced and the onset of detonation may indeed occur. The detonation sensor tells the engine management computer detonation is sensed and the computer then retards the spark to increase the margin. A retarded spark is not as efficient so your mpg and power output decrease.
Again, it gets back to the obvious thought; why does one worry about saving a few cents a gallon and violating the manufacturers specifications when they just spent $50K for a car?
And yes, you certainly have the right and ability to but 89 octane gasoline, as you clearly stated in the previous post, but that does not mean most people would afford you a lot of respect for the wisdom behind doing that.
Old 08-17-2014, 05:29 PM
luigi524td luigi524td is online now
Mein Auto: '17 540xDrive; '98 Z3 2.8
My documentation to the person who next buys my '13 535xDrive will include every gas receipt for fills at a Tier1 station with 93 Octane gasoline ... not that really makes a difference to anyone ??
But if I were buying someone's used car and they struggled to spend an extra $300/YEAR (approx cost diff between reg and prem gasoline & driving 15,000/year) for the correct/recommended gasoline I'd wonder what else they cheaped out on.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 08-17-2014, 05:51 PM
How am I violating the manufacturers specifications when it says 89-91?
Old 08-18-2014, 05:24 AM
dandanio's Avatar
dandanio dandanio is offline
The One who Drives.
Mein Auto: 11 f25 n55/09 Jetta TDI
This!
Trips and Pieces - My new blog for Travelers by Travelers!
Personal Euro Delivery Blog
My, somewhat outdated, BMW Euro Delivery of 2009 blog with pics!
Old 08-18-2014, 05:31 AM
High octane gas produce more HP per each combustion, that means you will get up to cruising speed faster, which in turn let you get off the gas pedal sooner thus saving gas. This only applies if your engine is design to take advantage of the high octane gas.
Old 08-18-2014, 05:10 PM
Doug in NC Doug in NC is offline
Mein Auto: 2011 x3 28i
Agreed. I always buy Top Tier gas, and only Premium. Don't buy from the cheap gas stations. http://www.toptiergas.com/retailers.html
Old 08-18-2014, 05:34 PM
Buy premium...
Old 08-19-2014, 11:55 AM
mrmeyer mrmeyer is offline
Mein Auto: 2015 X3 x28d
Neither. I'm using diesel.
Old 08-19-2014, 12:06 PM
Me530's Avatar
Happily Driving
Originally Posted by mrmeyer View Post
neither. I'm using diesel.
b5? D2? B20?
2006 530i
BMWCCA #350568
Old 08-19-2014, 02:22 PM
b5? D2? B20?
Yes.
All of it is D2 locally, I think. I've only filled up twice so far; the 2nd fillup was B20 and I wasn't sure what effect that would have. But hey, it came out of the fuel nozzle, so I stuck it in my 2015 x28d X3. So far so good.
Actually, I'm a rotating equipment engineer by trade, so you'd think I'd be smart enough not to do that.
Old 08-19-2014, 02:26 PM
Me530's Avatar
Happily Driving
BMW definitely advises that the max biofuel is B5, but I don't think a tank or 2 of B20 is going to cause too much harm....
2006 530i
BMWCCA #350568
Old 08-19-2014, 03:09 PM
kevink4 kevink4 is offline
Mein Auto: 2015 X3 xDrive28d
The cap says B7.
But it seems like I'v only seen a few types. Pumps with no indication that they use biodiesel. B5. And B20 (where it says somewhere between 5-20%). I skipped that station.
I prefer stations where the diesel is in the same islands as the gas, even if it might only be the end pumps. Some of the other stations I've used have had special areas, and some didn't support paying at the pump.
Old 08-19-2014, 04:16 PM
I backtracked this evening to the same station, closest to where I live, and relieved to discover it's B5 after all.
Old 08-19-2014, 09:07 PM
PFol310 PFol310 is offline
Mein Auto: 2016 X3
Always fill up at Costco and its on the list you provided.
Thanks :thumb up:
Honestly, if you can't afford the extra $2-$3 a fill up difference using premie you probably shouldn't have bought a BMW.
I've always used premie even when I didn't need to. The extra .20 a gallon really doesn't make a difference.
Old 08-21-2014, 10:37 AM
LycanNyc's Avatar
LycanNyc LycanNyc is offline
BMWCCA '505245
Send a message via AIM to LycanNyc
Mein Auto: F26 X4 M40i LBB
Exactly, that's why I'd be worry about buying a car that came out of a 3yr lease a lot of folks don't really care of the lease that well.
Thank You!
Yes
Thanks :thumb up:
Not to mention, I've been comparing prices Costco Premium vs BP 93 vs Shell 93 , Costco, BP, Shell in that order of cheapest price to highest but I've also noticed a better responsive/performance with Shell in my Cadillac, BMW e90, 2011 M.Benz C300 i've owned but will test on my X3 now i haven't put shell yet maybe my previous cars were into shell since I used it for longer than any other brand lol.
PM for RaceChip Discount
16' F26 X4 M40i LBB | CTSTurbo fmic Custom @AimPerformanceNJ Downpipe | @EnzoRacing PTF/BootMod3
BM3 N55 vs F80
BM3 N55 vs JB4
CTS-Intercooler Logs/Pics
Check out my YouTube Channel
IG:@Frikiton
Member: BMWCCA #505245
