Old 08-17-2014, 03:43 PM
vincento70 vincento70 is offline
Mein Auto: 3-series touring
iDrive button knob push does not work
Hi all,
I am new to the forum, but I am a very happy owner of a BMW 3-series touring (2008). The car is equipped with the CCC-navigation system (I think I have the update-1, no split screen) and since a few months the controller knob is acting mysteriously: at random times, the controller stops responding to a push on the knob. Rotating works and all systems seem to work fine (the wheel buttons operate normally and navigation still runs). After a while (between 5 to 60 minutes to never), all 'clicks' seem to be executed all at once and the system is fully operational again.
Any hints on what could be the problem here ?
Kind regards,
Vincent
Old 12-01-2014, 12:30 AM
sorindx sorindx is offline
Mein Auto: BMW E93 '08 320d
BMW E90 IDrive problem
Hello,
I am having the same problem, but as far I have read/hear until now there is a problem with some contacts.
You can watch here how to take out the IDrive and the problem with it.
http://www.pinterest.com/sorindx/bmw/
When I will have some free time, I give it a try.
Best regards,
Sorin
Old 12-01-2014, 12:31 PM
Mein Auto: '06 AW 330xi
Sounds like the system is hanging.
Next time this happens you can press and hold the volume knob and both eject buttons in for about 30 seconds.
This will soft reboot the CCC system and should restore functionality instead of you waiting for the system to unfreeze or reboot itself.
Old 01-24-2016, 12:26 AM
Moose170 Moose170 is offline
Mein Auto: BMW 320d
Easy fix to iDrive select malfunction
All the links I read ended up with the car owner having to replace the iDrive select button unit at a cost of $200 to $400.
Then I found this YouTube video that proposed a simple and cheap solution.
"BMW iDrive funktioniert nicht - Reparatur / don't work - how to fix it"
Cost me just a few $'s as I did not have the flux or isopropyl cleaner. I have virtually zero experience and knowledge of electronics, yet I managed and so can you.
Amazing how such a simple solution resolves the problem.
The local BMW service center quoted me $1,200 to fit a new iDrive button controller unit!
Old 01-24-2016, 03:39 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Well, the function of flux is to deoxidize metal; alcohol will remove organics like grease & oil that glue dirt to contacts. Good advice!
idrive controller
