Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 08-20-2014, 07:41 PM
MagnusPyke MagnusPyke is offline
Mein Auto: X3
F25 with non-TPMS sensors
Any experience with the non-TPMS option that uses ABS to "check out" the tire pressure. Some reviews show that TPM will display alerts too late which would result with a damage on tire and rims. TPMS is mandatory in the U.S. but not in Canada or EU.
Old 08-21-2014, 06:30 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
The latest generation of ABS based TPMS is pretty good.
Old 08-21-2014, 04:37 PM
Mein Auto: X3
Does it mean that it will capture a pressure drop on a single tire and show it on the screen.
Old 08-21-2014, 04:49 PM
luigi524td luigi524td is online now
Mein Auto: '13 535xDrive; '98 Z3 2.8
Exclamation TPMS vs TPM
BMWs wheel mounted Tire Pressure Monitor System will isolate a single wheel/tire when inflation pressure for that specific one is below the threshold as set in iDrive. I understand that additional coding is available (search the forum) that will permit actual inflation pressure and tire temperature to be reported on iDrive.
Search is your friend - almost as friendly as your owner's manual!!
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 08-21-2014, 05:07 PM
yes, the system is smart enough to indicate a low pressure on a certain tire even if it doesn't have a direct pressure sensor.
Old 08-21-2014, 11:52 PM
ngcreese's Avatar
ngcreese ngcreese is offline
Mein Auto: '11 X3
I just coded--on TPMS pressure and temperature. It's pretty cool & useful. Ironically, I just had one of the sensors replaced because the system kept warning me of a malfunction. Now I can see, on the vehicle info screen, that the wheel serviced today is over inflated to 42.1 psi.
'11 X3 xDrive35i -- Coded
'07 X3 3.0si -- Coded & Traded
'91 e30 325i -- Sold
BMWCCA Member
Old 08-22-2014, 06:54 AM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
Regarding the display of the pressure in individual tires, note that this may only be possible in the US, where Direct TPMS is used. In the rest of the world, where Indirect TPMS (measuring variations in wheel rotational speed) is used, this wouldn't be possible. Direct TPMS has pressure sensors in each wheel, while Indirect TPMS does not.
