Old 08-21-2014, 04:29 PM
Jetlife123 Jetlife123 is offline
Mein Auto: 2007 335i
I just got my back 2 tires changed, and every time I put the key In ignition, this ai
Old 08-21-2014, 04:31 PM
It turns on for a few seconds and turns off
Old 08-21-2014, 05:29 PM
max123 max123 is offline
Mein Auto: e46,e90
That's the passenger air bag light, probably the passenger occupancy sensor is going bad.
Old 08-21-2014, 05:31 PM
When I put the key in sometimes it turns on, and sometimes it doesn't, but never stays on for more than a few seconds. Could the shop have messed it up? Because it happened right after I left the place.
Old 08-21-2014, 06:01 PM
M3Inline6 M3Inline6 is offline
M4 Moderator
Mein Auto: 2017 Indv. Nardo Grey M4
Changing tires has nothing to do with the airbag sensor. It's just an unfortunate coincidence.
Old 08-21-2014, 06:06 PM
So what do I do, I have no clue. This issue happens some times, but most times when I put it in ignition the light turns on, but then goes off again.
Old 08-21-2014, 06:09 PM
M4 Moderator
Have somebody sit in the passenger seat and drive around a bit to see if it senses an occupant and turns off. In the newer cars, the airbag warning for the passenger side illuminates on occasion too (..it's overhead near the map lights), and shuts off on its own.
Old 08-21-2014, 07:53 PM
I did, it only comes on when key is in ignition, and the car is not turned on. The light comes on for literally 3 seconds, and comes off on its own. When my car is on a running, that light is not on.
Old 08-21-2014, 08:31 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
See if you can have the codes read and cleared. Usually all the sensors check themselves (well, not really) on ignition and them turn off. Since its an airbag, would go to the dealer for sure.
Old 08-22-2014, 05:56 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Wait a second here. Are you saying that the light comes on when you have the ignition key in AND BEFORE you start the engine. The light is already out once you start the engine?
Old 08-22-2014, 07:19 AM
Yes sir
Old 08-22-2014, 07:25 AM
Towelie Towelie is offline
Mein Auto: E90 335xi 6MT
Do you have standard (non-sport) seats? Passenger seat airbag detection mat recall for '07 335 issued end of last year -
BMW is performing a recall on various 3, 5, 7 & X5 series models from model years 2006 through 2007. The passenger side front seat occupancy detection mat may fail, resulting is a deactivation of the passenger side air bag system. The repair is to modify or replace the passenger side seat occupancy detection mat.
Affected models (depends on the specific seat type optioned for the vehicle):
E90 3-series sedans:
2006 325i, 325xi, 330xi
2007 328i, 328xi, 335i,
E91 3-series wagons:
2006 325xi
2007 328i, 328xi
E60 5-series sedans:
2006-07 525i, 525xi, 530i, 530xi, 550i
E61 5-series wagons:
2006-07 530xi
E65 7-series:
2006 760i
E65 & E66 7-series:
2006-07 750i, 750Li, 760i, 760Li
E53 X5:
2006 X5
According to the recall:
"Should the system fail, in the event of a crash, the front passenger air bag would be deactivated, increasing the risk of personal injury."
The recall notification letters will be sent in January 2014, as the repair parts are not yet available. Second letters will be sent when the repair parts are in-stock and available for installation (expected to be March 2014).
Additionally, 2006-07 3-series models with standard seats, 5-series with comfort seats and Z4 models will receive an extended warranty on the passenger occupancy detection mats.
Owners of affected vehicles are being notified by BMW. Further information can be obtained by contacting BMW customer relations at 1-800-525-7417.
BMW recall 13V564
(from - http://blog.bavauto.com/15028/bmw-re...e53-13v564000/)
Old 08-22-2014, 07:34 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Yes sir
Ummm...isn't that what's called a "bulb check"? The light is REQUIRED to come on when the ignition is in the 'on' but not yet 'engine running' position. It's so that you know that the warning light is still functional.
My point being that doesn't everyone's supplemental restraint warning light come on briefly when the key is being turned?
Old 08-22-2014, 07:56 AM
Mein Auto: '06 AW 330xi
That's what I'm thinking.
The passenger seat mat throws an error in the middle of the cluster, along with that little airbag light.
This is not a seat mat issue.
Old 08-22-2014, 07:58 AM
That light lights up when an occupant is less than 70lbs.
It's to protect a child if they are in the front seat.
Airbags deploy at over 200mph and can injure small occupants. That's why it's ALWAYS recommended to have children sit in the back seats.
Old 08-22-2014, 08:22 AM
It says sedans, my car is a coupe! Does it still apply to mine
Old 08-22-2014, 11:00 AM
Forget about the seat mat sensor.....that's not your issue.
Old 08-22-2014, 11:16 AM
What is then?
Old 08-22-2014, 05:37 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Once again, DSX has nailed it. Our ubiquitous federal regs call for a 'bulb check' when the key is turned...and they all soon extinguish.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
