Old 08-24-2014, 09:11 PM
Bimmerzxcd Bimmerzxcd is offline
Mein Auto: Mazdaspeed3
Funny noise from gas pedal assembly
Hi,
I wonder if any E92 owner experiences the squeaky noise when stepping or releasing gas pedal as shown in the video. Any solution/suggestions would be appreciated. Thanks.
Old 08-24-2014, 09:26 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Mine went funny then played up (refused to decelerate)
end ed up $550 to replace the pedal & drive by wire module
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 08-25-2014, 08:27 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I believe the pedal is a modular unit, easy to replace, if it's the pedal. You'll need to make sure the noise isn't coming from the engine bay, or the throttle actuator motor. Does this sound happen with the ignition off or on?
What model vehicle? Year?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 08-25-2014, 08:32 AM
Mein Auto: '06 AW 330xi
Sounds like the spring behind the pedal got loose and is rubbing against something.
Looks like a new pedal assembly is your fix. Easy to replace. Not sure of the actual part costs though
Old 08-25-2014, 08:34 AM
The car 2012 335IS. This sound happens no matter the engine is on or off, so I assume it is the gas pedal module.
Old 08-25-2014, 11:11 AM
thekurgan's Avatar
Bad Lieutenant
These are easy swaps, plug-n-play, so if you're out of warranty, it would be a no-brainer, else warranty will take care of it.
Ilse
Bruna
BMWCCA #453648
Old 08-25-2014, 11:17 AM
Yeah, BMW confirmed it is an issue from the gas pedal module, and it is under warranty. Thanks, guys.
