Old 08-25-2014, 10:32 PM
IvanC IvanC is offline
Mein Auto: 328i
3 Series Audio issue
Hi Bimmer land, I'm new to this site, so please forgive my lengthy question.
I have a 3 Series with the BMW professional head unit within it that I would like to replace with an after market head unit. I see on the back of the BMW professional unit, it has a fiber optic output that I am advised feeds an amplifier in the trunk.
What I would like to do, is to connect the front and rear RCA outputs on the new head unit to the fiber optic line to use the amplifier already in the vehicle. Does anyone know of a supplier that provides a cable or interface that will allow me to connect to the existing in car wiring and allow the RCA output on the new unit to be converted to fiber optic via the existing cable plug?
Many thanks for any guidance available.
Old 08-25-2014, 10:59 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Not possible
The Head Unit does not determine the sound system the type amp or lack of amp does.
Not possible if you have the L7 amplifier. no analog inputs
If you have Hi Fi its possible because the amp has analog inputs
There is only one aftermarket head unit manufacturer that makes a device to convert
analog signals to the BMW proprietary fiber optic format and they have just come
out with that device . See dynavin N6 thread. (its the only one that will work with the L7 amp)
You need to determine if you have L7 or Hi Fi .
Hi Fi uses the fiberoptic for things like PDC , blutetooth and ipod in 09 and earlier models.(but not for audio signals)
Also for a BMW e90 specific stereo board go here.
http://www.e90post.com/forums/forumdisplay.php?f=27
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/showthread.php?t=343673
http://www.e90post.com/forums/showthread.php?t=138949
http://www.e90post.com/forums/attach...1&d=1209780605
http://www.e90post.com/forums/showthread.php?t=641323
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/
http://www.e90post.com/forums/attach...1&d=1209780865
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...4&d=1278871872
http://www.bimmerfest.com/forums/sho...ght=dynavin+n6
Old 08-25-2014, 11:16 PM
Mein Auto: 328i
Thanks for the links, I will have a good read
Old 08-26-2014, 06:16 AM
Mein Auto: '06 AW 330xi
Yes there are summing modules for fiber optic systems. They are very expensive and not worth it.
You're better off relocating your head unit (if you have l7) and using the aux input if you only want to install an aftermarket HU.
There's a DIY guide on e90post about relocating the OEM HU.
Old 08-26-2014, 08:23 AM
Mein Auto: 328i
Thanks for the heads up in terms of the cost issue. I don't have the I7 system in the car. Front doors (mid and tweeters); Rear shelf (mid and tweeters); under the front seats (sub woofers).
Old 08-26-2014, 08:29 AM
Wongway Wongway is offline
Mein Auto: 2011 E90
Then get one of these...
http://www.bimmerfest.com/forums/sho...d.php?t=786992
No need to rewire or connect RCAs to the existing amp. Everything on this plugs right into factory harnesses.
You'd lose the factory aux and usb inputs (if you had that option installed) but you can install new ones in their place because the head unit has those inputs as well.
You'd also have to wire a new microphone, since this unit has its own built in bluetooth for phone AND for streaming audio from your phone.
This might not be of a huge benefit to you though, if you had Factory Navigation?
Old 08-26-2014, 10:58 AM
Fyi
head unit
http://www.e90post.com/forums/showth...ight=head+unit
http://www.e90post.com/forums/showth...hlight=dynavin
http://www.janus-design.net/english/
http://www.e90post.com/forums/showthread.php?t=355089
http://www.e90post.com/forums/showth...light=retrofit
http://www.e90post.com/forums/showthread.php?t=993447
http://www.e90post.com/forums/showthread.php?t=1016187
Be aware that there may be side effects like
1) Without the original head unit mounted some BMW dealers won't be able to perform software
updates or repairs to your car. Some people do a parallel mount as described in the
second link above to avoid this.
2) Depending on options you may get some error codes as the fiberoptics bus connects to
bluetooth , Sos , PDC beeps though head unit , usb/ipod modules that are separate from the radio.
When they are dissconnected the car considers them faulty.
If you have PDC I think the only head unit that will work with it is again the Dynavin.
You can code some of the errors out.
