Old 08-29-2014, 06:49 PM
subarashi subarashi is offline
Mein Auto: 2012 550xi
Clunking noise from front suspension
Hey guys
I've got this weird clunking noise from the left front end of my suspension. You only hear it when going over speed bumps - on the release of the shock on the way down. The dealer had it in for two days (first didn't believe me/cannot reproduce and then went with me for a Drive where it was clear as day). They changed the left front sway bar link But no surprise - heard it again on the way home.
Makes me mad when they don't get things right two times in a row!
I read somewhere that this could be the shocks but has any one else experienced this? Advice would be appreciated. I have 18k miles on the car - still under warranty. Hard to believe it's the shock this early in the cars life.
2012 550xi Graphite Gray
2005 545i Gone but not forgotten
Old 08-29-2014, 08:11 PM
TomXH TomXH is offline
Mein Auto: 2011 535 xDrive
Had a similar noise coming from drivers front side in slow parking maneuvers. They changed the front sway bar and noise was gone. This was after 36k miles though.
Old 08-29-2014, 08:28 PM
bmguy bmguy is offline
Mein Auto: 2012 Dinan 550xi
I had the issue, and it was in fact the shocks, but I think they replace the "strut assembly" to correct the issue...
My issue was found using chassis ears they called them, However no one at the dealer had any, so they ordered them, took a few days but that tool was very helpful to find the source of the issue promptly. I don't think many shops have this tool, sounded like it was not common to need them, but they were designed for this and asked for a few days extra to get them and use them....
one trip and problem solved for me
Old 08-30-2014, 04:56 PM
batmbl's Avatar
batmbl batmbl is offline
Mein Auto: 2009 535i
I had the issue as well. Mine was only a loose bolt on the shock.
Old 08-30-2014, 08:13 PM
I'm heading in for my third trio now. V annoying. I'll ask about the chassis ears but this is very obvious to hear so not sure if that's a diagnostic tool vs just an amplifier of some sorts. Huge silliest part is they don't have speed breakers near their dealership so they "can't replicate" the problem or determine if it's been fixed.
C'mon -- you've got to check to make sure the problems fixed before you return a vehicle.
Old 08-30-2014, 10:52 PM
schnell525 schnell525 is offline
Mein Auto: 12 550xi
I've heard this clunking noise in the front end, especially the right front with adaptive suspension.
Auf Wiedersehen 12 550xi
Old 08-31-2014, 12:42 PM
I was told the chassis ears was used to find exactly where the noise comes from, triangulating the noise. I could here mine very clear also but sound travels different through different materials. That tool was used to pinpoint the location of the noise and associated part to replace.
Old 09-06-2014, 01:54 PM
Update on this thread:
Had the dealer send tech home where I replicated problem on speed bumps outside our home. He then pulled out these "sound sentry" devices which he put into 5 spots (both front wheel wells, engine compartment and underside of front sides). They are labelled and send sound individually to a control panel that he kept in the car while driving. Sure enough -- he caught the sound coming from the right front wheel well. Suspect shock, strut or sway bar bushing.
Car is back in the garage. Thought I would share. Fingers crossed this does it.
Old 09-06-2014, 02:17 PM
Thnx for updates very useful to try to convince dealer to get this machine
Old 10-06-2014, 08:57 PM
jfandl jfandl is offline
Mein Auto: Rx7 Twin Turbo
Same problem for me, clunking when turning at slow speeds and sometimes hard over speed bumps. The dealer couldn't find the problem after 3 days but they did indeed replicate the action. They said they retorqued some suspension bolts and the problem went away, well for 5 months, now it's back again and out of warranty. Thoughts? Sucks that there is no manual available for the car, I don't even know how much to torque the bolts.
