Old 08-31-2014, 07:38 PM
deeayy92 deeayy92 is offline
Mein Auto:
Radio decides to work whenever it feels like it
My radio works whenever it feels like it. I turn my car on and it works next day I turn it on and it doesn't. Any idea what this could be?
Old 08-31-2014, 07:49 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Do a search for amp dying and see if the symptoms/issues you see are what you're experiencing. The e38/e39/e53 all use the same amps (regular or DSP amp)...so you have at least 3 different BMW model forums to search from to see if this is your issue.
I'd also recommend using google search engine...just type "BMW e38 radio not working" into a google search box (also try inserting e39 and e53 for more results). Again, this is one of the common maladies that afflicts all 3 of these models...so you have a lot of past threads (from 1995-2006) to check if this is your issue to.
Good luck.
Q {BMW CCA Member #191509}
(SOLD)
Old 08-31-2014, 07:59 PM
Mein Auto:
thanks!
HTML code is Off
