Old 09-01-2014, 10:31 PM
Anderoo_328i Anderoo_328i is offline
Mein Auto: '07 328i
Stripped bolt on '07 328i starter removal.
So there I am, knee deep in removing my starter. Every thing that's in the way, is out. My air filter box, throttle assembly, electrical distribution unit, and my intake manifold. I go to take the two bolts off holding the starter in place, I get the right one off perfect, boom good. Then I go to the left one and it's already stripped, rounded and all. and I didn't even touch it yet. I could tell someone had replaced the starter once before, and put two entirely different bolts on it. I tried a bolt extractor no luck, penetration oil did no help either. So I sent my girlfriend to Lowes for a Chisel, to cut a slice in it and use a Flathead to get it out. She comes back with a Irwin's "Grab It" tool similar to a easy out tool. That didn't work cause I couldn't get my drill back in that tiny space. So we both go back get the chisel, come back and long story short the entire bolt head is off and I'm in a worse situation than when I started. Any suggestions or tips on what I should do?
M
Happy F**king Labor Day!
I slept and dreamt that life was joy. I awoke and saw that life was service. I acted and behold, service was joy.
-2007 328i
Old 09-02-2014, 05:08 AM
Banned
Mein Auto: 2007-335 HTC
so is the starter held on by 2 long bolts and they are Al too. My 335 bentley book shows one from the front side and one thru the back, which one did you get out and which on did you strip the head off?
either way you should be able to slide the starter out if you twisted the head off?
Old 09-02-2014, 07:58 AM
Mein Auto: '06 AW 330xi
Left hand drill bit and a flexible extension
Old 09-02-2014, 11:32 AM
idonthaveaBMW idonthaveaBMW is offline
Mein Auto: i walk
I would go for the "drill out" I hear they are aluminum bolts, so they should be easy to drill out. I also hear they are supposed to be replaced when you replace the starter, sound like the last guy who replaced the starter did not do that.
If the drill out does not work and it comes down to it, I would cut a slit in the starter housing around the bolt and then chisel it till that part of the housing brakes off, then that should free it up.
PS.
We got to drive that bad boy back to *Cali* bro!
Old 09-02-2014, 11:41 AM
Don't use a right hand drill bit.
It will spin the bolt further into the hole.
With a left hand bit, as your drilling it may catch and spin the bolt out of hole.
Start with a small bit, maybe 1/8" or 1/4"
Old 09-02-2014, 01:15 PM
Mein Auto: '07 328i
PS.
Hahah thanks Mr. idonthaveaBMW!
I'm on it! I'll let you know how it turns out
-2007 328i
Old 09-02-2014, 01:25 PM
Banned
I would be more inclined to cut the starter housing apart first and once you removed the starter you can get a pair of vice grips on the bolt or if you know someone with a Tig welder, get an AL Nut big enough to slide over the head and TIG weld in on then try to unscrew it. that starter housing should not be tapped is it? you could cut the bolt flush with the starter housing and it should slid off? if there is enough room in front of the starter
Old 09-02-2014, 04:10 PM
Mein Auto: i walk
I was thinking the same thing, but from what i see it looks like it is threaded, so even if the head of the bolt is off, the threads would keep it from sliding outů
Old 09-02-2014, 05:46 PM
updownsidewall's Avatar
updownsidewall updownsidewall is offline
Mein Auto: 2007 328i
Starter
If the bolt head is off the starter should come off no threads in block only on short bolt rt side. It is corroded on the flange to the block. Chisel idea is the only way to go or saw try starter flange.
I.m sure this car has been in water over the starter.
Old 09-02-2014, 05:48 PM
bolt
No the threads would not keep it from coming out . It should come out bolt and all id head is off bolt
Old 09-03-2014, 05:21 AM
Banned
if that is the correct starter, that makes no sense. that bolt should screw in from the back into the threads, as you see the bottom hole doesn't have threads and so that bolt should slide in from the front and the block should have the threads, actually every car I have worked on the starters and the block had no threads, they were all thru bolts and nuts on the ends
Old 09-03-2014, 10:37 AM
Mein Auto: i walk
I heard it was raining in your hood bro!
Looks like rain all week too....
Old 09-03-2014, 01:04 PM
Banned
here in the south we get the nasty afternoon thunder storms, that doesn't mean its raining all day
Old 09-05-2014, 04:41 PM
Mein Auto: '07 328i
ID:	462736 got it off.
I used a Reciprocating Saw.
-2007 328i
Old 09-05-2014, 04:42 PM
Mein Auto: '07 328i
I found what the problem was some one out the bolt in backwards
-2007 328i
Old 09-05-2014, 04:57 PM
Turborascal Turborascal is offline
Canyon Carver
Mein Auto: 2011 E92 335is
Attachment 462736 got it off.
Glad that you got it off and (presumably) the new starter installed.
Unfortunately, you certainly won't be getting a core charge refund for the removed starter ...
2011 Black Sapphire Metallic 335is Coupe | DCT | Luxury Pkg | Convenience Package | Cold Weather Package | iDrive/Nav/Sirius | Michelin Pilot Super Sports on 19" 313s
2015 Jet Black Metallic Porsche Cayman GTS | PDK | PASM | PTV | Sport Chrono | Power Steering Plus | Burmester sound w/nav | Park Assist with backup camera | Convenience Pkg
Old 09-05-2014, 05:22 PM
Mein Auto: i walk
got it off.
Awesome, whats up with the hose i heard you might have broke? What it a vacuum hose? Did they have it at the BMW shop?
Old 09-05-2014, 05:37 PM
Mein Auto: '07 328i
Yea I did lol AutoZone gladly took it. lol
-2007 328i
Old 09-05-2014, 05:40 PM
Mein Auto: '07 328i
Yea It was the Crankcase Breather hose. I found it online for like 40 bucks. But I can't wait long for it to get here. Luckily there is a BMW dealership close by, and the parts and service center is open on Saturdays. Hopefully they don't charge me an Arm an a Leg.
-2007 328i
Old 09-10-2014, 08:23 PM
Mein Auto: '07 328i
Sorry forgot to let you guys know. Everything went well.
After I put everything back together my car was shaking pretty bad, so I tightened my manifold and throttle body and it went away. Then my check engine light came on and said I had misfires in cylinders 1, 3, and 4 so I took off my spark plugs wiped them off and wiped off my coils. Started it back up and ran it for a little while now everything is back to normal. Thank all of you for your help!
-2007 328i
Old 09-10-2014, 08:37 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Thanks for the follow up! Scary stuff for sure.
Old 09-11-2014, 04:03 AM
Banned
that is why you need a torque wrench when you work on plastic parts on these cars and all New gaskets and bolts where directed and follow the tighten sequences, its a must so you dont have a manifold leak
great job!
Old 09-11-2014, 09:00 AM
shaking
Mine did the same thing, I just let it smooth out and then it was okay. Happy for you that it all came out okay. Lots of good help here on the web. You saved 1200 dollars. Its worth the effort and a world of experience.
Old 09-11-2014, 12:55 PM
Mein Auto: i walk
Awesome, now we don't have to hitchhike back to *Cali*
