knock sensor going off - Bimmerfest - BMW Forums
Old 09-02-2014, 12:44 AM
adeljobran718 adeljobran718 is offline
Mein Auto: 2007 335i coupe
My knock sensor keeps on goung off going through forums i read that it could be gas related so i changed to a top teir gas station and put octane boost ran good for 2 or 3 days and limp mode again*ran codes and once again knock sensor plugs changed at 33k miles my car is a 07 335i e92 46kmiles.
any suggestions really apriciated
Old 09-02-2014, 03:33 AM
DSXMachina's Avatar
Bimmerdex 7.4!
i see you didnt list any codes that would be a big help because without them we are completely at a loss as to possible causes with the codes at least we can make an educated guess and then tell you what might be the problem then you can determine if the problem is something you want to fix yourself and we can then tell you how to do it but we need to start with the code(s) which you must have or you wouldnt know it was knock sensor related
Old 09-02-2014, 07:10 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Do you mean to say there is a warning on your dash, or that you hear it knocking?
Old 09-02-2014, 10:52 AM
code
The code is 2e69
Old 09-02-2014, 11:01 AM
Mein Auto: '06 AW 330xi
You have a bad knock sensor.
When the engine detects knock, it will adjust fuel, air, timing etc to eliminate the knock.
If this fault is present, it means the sensor is bad or there is a short somewhere in the harness.
Old 09-02-2014, 11:15 AM
So you dont think its something causing the sensor to go off?
Old 09-02-2014, 01:51 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Re-read what fdriller posted. The code means what he says it means; either the wiring, connection, or sensor itself has failed. In my experience it's the sensor 99.9% of the time.
Old 09-02-2014, 02:23 PM
Alright thanks guys for the information. Is there a website that has them for a better price than dealer i cant find much options online.
Old 09-02-2014, 02:55 PM
Try ECS or getbmwparts.
