Old 09-02-2014, 03:35 PM
yolome yolome is offline
Mein Auto:
Can someone help me with my problem? (Engine malfunction showing on screen) 07 335i e
Old 09-02-2014, 03:39 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Could be a lot of things, fuel pump, injectors, coils etc, you will need to have the codes read to narrow it down.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 09-02-2014, 03:40 PM
Mein Auto:
It happens every time i do redline..It's not that i drive fast or whatsoever I just wanted to test car.
Old 09-02-2014, 09:16 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Happened to me when I first got mine. Was pushing the car hard and that would happen. Turned it off and on and was good again. Took it to the dealer but never told them about that as I thought that was typical from pushing too hard. They replaced all of my coils and it hasn't happened again.
Then, later, after I added methanol and a new charged pipe, the nylon elbow that came with the kit kept sliding off the charge pipe and making a loud "pop" noise resulting in the same "reduced power" warning (poor install on my part).
The good news is the car still runs pretty good and the system "self protects" from engine damage.
I'm sure you have some codes thrown so get those codes read and go from there.
Hopefully it's coil related and not injectors. Those bad boys are expensive and need to be coded in. Dealership did mine later due to a recall or something.
Not sure if VANOS solenoids could cause that either (engine timing and oil pressure related) but those look easy to fix as well.
Old 09-02-2014, 11:19 PM
Mein Auto:
Thanks for the info!super helpful!
Old 09-03-2014, 05:22 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by yolome View Post
Mileage not far from 60K? THIS
Otherwise use THIS to give your quest perspective + direction.
Old 09-03-2014, 06:31 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
Originally Posted by roadkillrob View Post
could be a lot of things, fuel pump, injectors, coils etc, you will need to have the codes read to narrow it down.
+1
Old 09-03-2014, 07:40 AM
Mein Auto:
80k on milage..i can't bring it to the shop until tomorrow.so hopefully nothing bad happens today....
