Old 09-02-2014, 04:27 PM
bluezpeed90 bluezpeed90 is offline
Mein Auto: 07 330i
07 330i ccc coding
hey guys am looking for some help on this. ive currently installed bmw standard tools 2.12 on my laptop. i just dont know what files need to be loaded up please help. ive had my car for about a year and am still not able to hear anything.
little story about why it needs coding is because the original unit that the car came with gave out so i bought off ebay and i know it needs to be programmed to my car. ive taken it to someone who said he knows how to do it but he lives far away from me and always keep saying to go back next week. please help am willing to pay anyone.
Old 09-02-2014, 04:46 PM
Mein Auto: '06 AW 330xi
You can't program CICs or CCC units with a normal D/K line cable used for coding....well you can but it will take about 8 hours to flash it and you will most likely brick it.
You need an ICOM diagnostic head to flash the CCC unit.
ICOM heads are about $600
EDIT: Btw you only need to flash the CCC if you want to change the audio system levels.
If you bought a CCC that was coded for the same stereo level your car has, it should at least give you radio functions. Then you can code the CCC with a normal D/K line cable to active/deactivate features based on your VO.
Have you tried installing the new CCC yet?
Old 09-02-2014, 04:51 PM
Mein Auto: 07 330i
kool thanks for the info man as i think that the guy i took it to bricked it already. the unit will not go further then the bmw logo now. wish i wouldve known before
Old 09-02-2014, 04:56 PM
Have a look on bmwcoding.com regional section to see if you can find someone local who has an ICOM head to flash your CCC.
If you were in Philly I could help you out. My co-worker has an ICOM head.
You can also look into Dynavin's aftermarket stereo solutions. See if they have something that may work for you. However, they are designed around non-iDrive based dashes.
You will have to do some custom fabrication to mount the HU.
And you can use a video interface to hi-jack the iDrive screen for aux video, back up cam etc. They can be found on eBay for around $300
Old 09-02-2014, 04:59 PM
Mein Auto: 07 330i
thanks a lot man and am in California Los Angeles hopefully i can find someone
Old 09-02-2014, 05:01 PM
No problem good luck
