Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 11-28-2004, 01:08 PM
kioneo kioneo is offline
Account closed at users request
Send a message via AIM to kioneo
Mein Auto: 1991 318i (E30, M42)
Question Winter tire pressure question
I just put on my winter tires (Blizzak WS-50, 195/65R14 89Q M+S) and I have a question about the tire pressure I should run.
On the tire, it has printed "1279 lb @ 35 psi max". In my owner's manual, it recommends 33 psi front and 39 psi rear (for 4 passengers and luggage) or 30 psi front and 33 psi rear (for 4 passengers and no luggage).
Is it safe to run the recommended pressures even though the one exceeds the 35 max psi printed on the tire? I am assuming that since my car has a max permissible gross weight of 3605 lb, that each tire will not exceed the 1279 and that I should be fine. Is that correct?
Any thoughts or suggestions are welcome.
Old 11-29-2004, 05:11 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
We've talked with Bridgestone about this, and they assure us that the tires can use more than the max PSI stated on the sidewall for cold psi and carry the load of the vehicle with no problem.
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Similar Threads
1st Auto-x ... tire pressure question cruztopless Motorsports, Racing & Track 20 05-07-2004 02:23 PM
ADAC / auto motor und sport winter tire tests johnf Tire Rack's Tires, Wheels, Brakes & Suspension 0 10-31-2003 03:01 AM
Gary: What's the recommended H-Rated Winter Tire this year? SARAFIL Tire Rack's Tires, Wheels, Brakes & Suspension 2 10-25-2003 07:06 AM
Tire pressure - Anyone know why the 2003 has different tire pressure then my 2001 AF 3 Series & 4 Series 21 11-15-2002 08:32 AM
A question about winter tires Spiderm0n General BMW Questions 4 01-09-2002 08:25 AM
