3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here. |
ZHP 6MT Shifting - Is this Normal?
Just noticed over the past few days that whenever I put the car into either 1st or 2nd, there's kind of a mechanical resistence/notchiness to the action of the transmission...
anyone else have this problem? is this secondary to the 'short-shifter'?
I think so too. I don't have the ZHP but I do have the same 6MT in my 04 330i. I have about 9K miles on the car now and the tranny has loosened up a bit and is less clunky then when new, but I've also gotten much better at operating the car now. For example when the car is cold and I first start driving away slowly while it warms up, the first 3 shifts or so the rpms will take forever to drop when I step on the clutch and I have to adjust the way I use the clutch and shifter, but after a few shifts once I get going the rpms drop normally and then it's business as usuall. I'm pretty close to trying the CDV delete. There is a local independent shop that will remove it for pretty cheap. But yes, the MT does have a very mechanical feel when engaging the gears. Although if I'm shifting at higher rpms and time my shifts perfectly it will snick into gear very easily and smoothly. 1st, 2nd & 3rd have more of a mechanical feel then 4th, 5th and 6th though. Last edited by Moderato; 12-01-2004 at 07:51 AM. |
what's is the CDV?
Clutch delay valve. Do a search, lot's of people are removing this intrusive piece of crap, for better clutch response!
The first thing I plan to do when I take delivery is ditch the CDV. The 2nd thing is to swap the 'lifetime' trans fluid for Redline D4 ATF. In my 325 it made a huge difference in shifting, especially into 1st or 2nd or when cold.
I've had that in all three E46s I've had. It's a little more exagerated in zhp cars because of the increased effort required by the shorter throw of the lever.
![]() ___________________________________________ 2004 330i | zhp | 6-speed manual |
I have 22,000 miles. The shifter is VERY smooth now. Hardly any of the notchiness mentioned above--even on cold days. Before 1 out of every 3 shifts from N->1 was notchy, now it is like 1 out of every 7. Shifting is more pleasant than ever.
You live in Michigan... wait until below zero weather... second gear changes will become even more heavy.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Anyone find the ZHP exhaust intrusive? | equ | 3 Series / 4 Series | 26 | 09-24-2004 11:55 PM |
| 330i ZHP thump while shifting ??? | djovanovi | 3 Series / 4 Series | 6 | 09-04-2003 11:03 AM |
| Color choices for ZHP | BradATL | 3 Series / 4 Series | 7 | 05-16-2003 05:08 PM |
| Michigan winter with SP tires? | Pete Teoh | 3 Series / 4 Series | 22 | 11-07-2002 05:51 AM |
