Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 12-05-2004, 06:35 AM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Electronic gas pedal "clicks" before bottoming out
Why does the gas pedal (electronic?) "click" when I floor it at the moment just before bottoming out. It happened on all newer 3, 5, 7 series cars. My '01 330i doesn't do that, and it has electronic gas pedal.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 12-05-2004, 07:19 AM
drmwvr's Avatar
drmwvr drmwvr is offline
Stick Drive
Mein Auto: 330i, 911E, UZJ100
Probably has something to do with living in Houston
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold
Old 12-05-2004, 07:28 AM
kioneo kioneo is offline
Account closed at users request
Send a message via AIM to kioneo
Mein Auto: 1991 318i (E30, M42)
It should be in the owner's manual, but I believe that hitting that click forces the automatic transmission to immediately downshift.
That's just from memory though, since I've never owned an automatic BMW.
Old 12-05-2004, 10:21 AM
ChadS's Avatar
ChadS ChadS is offline
It's all good!
Mein Auto: 2006 330i
BMW calls it "kick down" and it is only on automatic equipped cars. It works just like kioneo described. It will immediately downshift the car and hold shifts until redline. All BMW's with automatics as far as I can remember have had it. I remember my '88 535i with an automatic had it.
Old 12-05-2004, 12:03 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
I was surprised by how obvious that kickdown switch is. Most cars have this feature (even old domestic cars with non-electronic transmissions) but AT BMWs are the only ones I've ever driven that have that very obvious click.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 12-05-2004, 12:30 PM
shortyb shortyb is offline
Mein Auto: 330i
I have a manual tranny and my pedal does the same thing. Might have something to do with signaling the ECU that its at WOT
Old 12-05-2004, 02:29 PM
BlackChrome's Avatar
BlackChrome BlackChrome is offline
Mein Auto: '02 E39 M5
Same here (manual, too)! I am just used to it by now.
2002 E39 M5 Chiaretto Red/Caramel extended leather
Old 12-05-2004, 02:36 PM
KP's Avatar
KP KP is offline
Buyakasha!
Send a message via AIM to KP Send a message via MSN to KP
Mein Auto: MY01.5 325Ci/93 Miata
I thought autos only had this
Old 12-05-2004, 02:47 PM
Come to think of it, mine only does that when I let go the gas pedal...
Old 12-05-2004, 03:01 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Ahhh...must give this a try!
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 12-05-2004, 03:05 PM
allaboutme allaboutme is offline
Mein Auto: 3x330,AMV8,996GT2
Isn't the kickdown switch for autos only? There would be little purpose having one in a manual car. Maybe you have the "sticky pedal".
Old 12-05-2004, 03:21 PM
It's not a switch, I know that for sure. It's just this sound the pedal makes when you push it hard and let it go quick (like when you shift)
Old 12-06-2004, 03:22 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The pedals are basically interchangeable, so either BMW put hte AT one in due to supply, or just switched to it for all cars.
The sticky pedal issue just felt notchy.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-06-2004, 04:18 AM
andy_thomas andy_thomas is offline
Mein Auto: 318i
The accelerator pedal module in BMW's drive-by-wire cars use a Hall-effect sensor to detect pedal position. No longer is the kickdown switch an "active" switch - it is there only for driver feedback. When the pedal is depressed beyond the normal full-throttle position, the sensor basically detects more than 100% throttle opening, and a command is sent to the gearbox to downshift to the lowest possible gear. The accelerator module is the same for auto and SMG cars. Manual cars have the same module, but without the kickdown detent (and a recalibrated sensor).
Old 12-06-2004, 06:03 AM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
The pedal in my car makes a loud click when I first start to step on it, regardless of how fast or far I push it down. I think something minor is broken, I'm going to bring it up at the 15K service.
Similar Threads
Bigger gas pedal help blip throttle? llando88 General BMW Questions 8 11-07-2004 02:50 AM
Strange gas pedal vibration heat010 3 Series & 4 Series 2 10-19-2004 07:45 PM
Gas pedal swap finaly, but ........... M 3C 3 Series & 4 Series 10 09-24-2003 11:11 PM
finally noticed sticky gas pedal bluskye 3 Series & 4 Series 5 07-29-2003 10:59 AM
Engine not responding to gas pedal robj213 3 Series & 4 Series 51 03-13-2003 06:13 PM
