UPDATE: 11/06/2016 - E-Sys Launcher Premium 2.6.0 Build 119
- Added support for E-Sys 3.28.x
- Added CAFD Transalation for the following G-Series: G001, G002, G011, G012, G013, G030, G031, G032
- Fixed High DPI/Screen Resolution support for JRE7, JRE8 (E-Sys 3.26, 3.27, 3.28) - Enjoy crisp resolution without down scaling your display
- Fixed issue with HKFM_LS. Older PSdZ library and other ECUs do not need to expand CAF, but HKFM_LS does, and is sensitive to delay. Launcher is now modified to only perform translation when requested from the GUI
- Added color indicator to FDL Cheat Codes (Blue = OK, Orange = partially applied, Red = failure)
- CAF Viewer is forced to use \Data\psdzdata\swe\cafd folder instead of \Data\CAF
- Changed .NET Framework requirement to V4.5.2
- Launcher is now completely hands-off in coding/flashing modules
- Updated Cheat codes
More Info: http://tokenmaster.blogspot.com/2016/11/launcher-v260-pro-and-premium-ncd-cafd.html
2.5.3 Build 108
- Added support for extended characters in CAFD mapping
- Added support for extended characters in FDL Cheat Codes
- Added support for multiple FDL Cheat Code files
- Enhanced Search capability in FDL-Editor and CAFD Viewer: Option to search from the top
2.5.1 Build 99
- Fixed Cheat Code Filters for E-Sys 3.24 and 3.26
UPDATE: 12/24/2015 - E-Sys Launcher Premium 2.5.0 Build 97
- Fixed "High Resolution Fix" option
- Fixed TAL-Editor error on E-Sys 3.24.x
- Enhanced Cheat codes
- PSdZData mapping compatibility is now at V56.5. Some CAFDs are at V57.0
UPDATE: 5/7/2015 - E-Sys Launcher Premium 2.0 Build 42
* Support for Trimmed PSdZdata. With Launcher 2.0, it's now possible to perform FDL coding again. No more trimmed CAFD or FAFP, no more guess work, renaming NCD or CAFD files, no more risking your car unnecessarily. This is made possible by integrating @SkaterMeNot technology by dynamically injecting CAFDs on-the-fly.
* Absolute Security 2.0. Enhanced security yet again to a whole new level. Just when I thought I couldn't make it any more secure. Launcher 2.0 does the following:
a) Prevent modified JAR library from getting loaded. Any modified JAR file must be restored or unexpected error may occur. Use modified JAR file at your own risks.
b) Modified and encrypted/re-signed CAFD files are disallowed. Some people are using CafE and/or their custom tools to re-sign modified CAFDs. Unfortunately, we will never run out of people with bad intentions. If you acquired modified CAFDs, unknowingly or otherwise, you will get the following error:
Unfortunately, CAFDs fixed using @SkaterMeNot technology will also be prevented from loading, but, since Launcher 2.0 comes integrated with this technology, there is no need for these fixed CAFDs. Restore files from original PSdZdata set if you see this error.
VirusTotal Analysis: https://www.virustotal.com/en/file/...5fb3aa3d8613351ac2dab1c3532471e032fe5b1bb22e348f1fc4f3dbd5/analysis/1431061521/
SHA256: 12b4dc5fb3aa3d8613351ac2dab1c3532471e032fe5b1bb22e348f1fc4f3dbd5
File name: ESysLauncher.exe
Detection ratio: 0 / 57
Analysis date: 2015-05-08 05:05:21 UTC
Screenshot:
NOTE:
1) Ensure you choose the correct settings for your car.
2) If you choose "High" and E-Sys fails to start, either restart your PC or select a lower memory settings and try again
3) You can click on my forum name link to send bug reports, questions, comments and what-not
4) If you have custom or modified jar files, the launcher will ask you if you want to proceed. Note that modified Jar files won't be loaded but I highly suggest you abort and restore the files before trying again.
UPDATE:01/04/2015 - E-Sys Launcher Premium V1.0.6
- Modified Obfuscation settings to minimize false-positive detections by AV
- Fixed bug in saving/restoring settings when updating the app
Non-critical update but if you're bothered by your AV, you upgrade or replace the Executable
Latest AV scan using 56 different AV with virus definition from 12/30/2014 - 01/04/2015
Executable: https://www.virustotal.com/en/file/...b477972e8c3c8975556cb0bcadd1ea67570e479f34c589561929b40a05/analysis/1420393248/
SHA256: 802b9eb477972e8c3c8975556cb0bcadd1ea67570e479f34c589561929b40a05
Setup: https://www.virustotal.com/en/file/...a960f9ece9703d69c6e3a44ed37c390f25cd247a10faba9495e86991dc/analysis/1420393726/
SHA256: 30659aa960f9ece9703d69c6e3a44ed37c390f25cd247a10faba9495e86991dc
UPDATE:11/7/2014 - E-Sys Launcher Premium V1.0.4
- Added "High" Memory Settings
E-Sys Premium Launcher Version 1.0.3.16
My patchless token solution brought something new and something relevant when I introduced it. And now, E-Sys Premium Launcher, once again, changes the way we use E-Sys. When a simple patchless solution just doesn't cut it anymore, E-Sys Launcher Premium brings a whole new set of feature to the table and is the only true innovative contender to my own patchless solution.
Features:
- Increased default memory allocation. E-Sys needs memory and lots of it. Default setting is barely enough for simple cars like the F20/F30s but is hardly sufficient for cars with complex ECUs. Most coders do well by changing this settings but some aren't aware of this. While it can be easily change, E-Sys doesn't check the value and if you set it too high, will prevent E-Sys from launching.
- Enhanced overall System stability. By ensuring E-Sys gracefully shutsdown and JVM properly recycled at the end of each coding session, your system is kept optimized for the next session. Stock E-Sys, more often than not, does not fully terminate. JVM lingers in the background, hogging and leaking memory. The issue becomes more apparent when you start/shutdown E-Sys numerous times, to a point where system restart is required.
- Zero E-Sys Configuration. With the launcher, there's no need to reconfigure E-Sys to use different Soft tokens. Those with OEM or my patchless token solutions can keep using it by clicking the Blue E-Sys icon, while using the launcher will use the assigned token, all without having to fiddle with the settings.
- Personalized and individualized token. The soft token you create will only be usable on your own machine. It cannot be shared and reused on another machine. This also means that someone can't sell you a token and expect it to work. With the built-in Token Generator, creating soft token is as easy as pressing a button. No fiddling around with some command line tool and creating XML data.
- Absolute Security. It became pretty easy to hack CAFD recently. With the launcher, the risk of using hacked CAFD is reduced to 0. Hacked CAFDs are prevented from loading, exactly the way stock E-Sys does, stopping it dead from its track. Coupled with individualized token, there's no need to worry about hacked CAFD.
Note: Do not mix and match different solutions, it's not generally recommended and could elevate the security risks the launcher is trying to minimize. My patchless solution can safely co-exists with the launcher, however, but it won't be loaded while the launcher is running. The patchless solution will also be replaced soon.
Main UI:
Soft Token Generator:
See it in action:
http://youtu.be/Poq_ddDEAhY
Send me a PM or an email to request. Feel free to share or reply to subsequent request.
2.5.3 Build 108
2.5.1 Build 99
- Added Series option at the CAFD or code level
- Added Author attribute which can be used as a filter
- Added comment attribute at the function level.
Screenshot:
NOTE:
Features:
Main UI:
See it in action:
