Old 12-08-2004, 05:15 PM
Ron Stygar's Avatar
19,585 Miles
Transmission Fluid MTF-LT-2
This came up on the roadfly E46M3 board awhile ago.
http://bimmer.roadfly.org/bmw/forums...5264627-1.html
From 09/03 transmissions came with the new MTF-LT-2. Someone had his fluid changed and they put in MTF-LT-1 since the MTF-LT-2 wasn't available here. The tranny didn't shift as well and he found out about the new MTF-LT-2.
Well it is now.
Old 12-08-2004, 05:27 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
So when I do mine I should use the MTF 2 correct?
Just to make sure I understand this right
Old 12-08-2004, 05:34 PM
Ron Stygar's Avatar
19,585 Miles
You have to decide that. I plan to. In time it will be the only one available if you choose to use the BMW stuff.
Old 12-08-2004, 05:35 PM
01silber's Avatar
Im here
Ok cool, I just wasnt sure if this was a M only thing
Old 12-08-2004, 05:39 PM
Ron Stygar's Avatar
19,585 Miles
Your car has the same tranny as my coupe.
Old 12-08-2004, 05:41 PM
01silber's Avatar
Im here
ohh shweeeeeet then Im going with the MTF2
Old 12-09-2004, 07:31 AM
sthoma9's Avatar
sthoma9 sthoma9 is offline
Mein Auto: 2001 Z3 3.0i Coupe
i was under the impression that the 2.8's trans carried over to the 3.0 and the ///Ms had the ZF.
http://www.bmw-m.net/techdata/mcoupe.htm
S.S.T.
'01 BMW Z3 3.0i Coupe- for fun
'91 Lexus LS400- daily driver
'03-'06 F-250/350 PS- for work
'97 BMW M3/4- sold
Old 12-09-2004, 08:59 AM
Ron Stygar's Avatar
19,585 Miles
I referenced the BMW EPC parts use. S5D320Z THCH. See following pic.
That bullettin also implies that the M's have the Torsen style differential and they don't.
Similar Threads
E46 Manual Transmission Fluid Change? Ramps? 2001E46 Do-It-Yourself H.Q. 13 09-29-2005 05:32 PM
Transmission fluid. ATF or MTF Pros? Cons? TIA daven E36/7 Z3 (1996-2002) 7 07-12-2004 08:47 PM
In remembrance of 9/11 AF Off-Topic 6 09-11-2003 11:12 AM
How to change transmission fluid on VW 1.8T JonM Off-Topic 0 01-11-2003 10:23 AM
