Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1M & M2
1M & M2
Old 12-14-2004, 05:39 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Official M6 pictures and press release
The rebirth of an icon
The announcement of a new M car remains a rare and exciting occasion, and the launch of the new M6 in 2005 will reveal a potent new combination of BMW engineering and M power.
Hot on the heels of the new M5, and taking lightweight design solutions from the M3 CSL, the new M6 combines supercar presence with Grand Touring potential. Joining an exclusive club, the fourth new M car of the decade sets a new performance benchmark for a production car. The beauty of the M6 is also its ability to comfortably crush kilometres on a cross-country cruise.
The BMW M6 is the new standard-bearer for BMW’s M car range, as well as the return of a much loved and highly regarded BMW badge. The latest M car features:
* 5.0-litre V10 engine producing 507bhp
* Seven-speed SMG (personally programmable)
* Lightweight body panels including carbon fibre roof
* 0 – 62mph in 4.6 seconds / 62 – 0 in 36 metres
* 155mph limited top speed
* MDrive Manager control settings
Like its predecessor - the legendary 1985 M635CSi – the new M6 resets the sports GT benchmark, with supercar performance, dispatching the zero to 62mph sprint in 4.6 seconds and achieving a limited top speed of 155mph. If derestricted, the M6 would be capable of a 200mph+ top speed. During tests at the famous Nürburgring Nordschleife circuit, the new M6 regularly clocked
eight minutes lap times. These rarefied performance statistics are, however, backed up by ‘real world’ economy and efficiency - the new M6 delivers a combined EU fuel consumption of 19.0mpg and a CO2 rating of 357g/km.
Powered by the same 4,999cc engine that set new standards in the M5, the 507bhp power output ensures that the new M6 maintains the M car tradition of breaking the 100bhp per litre benchmark. Peak power is developed at 7,750rpm with the red line set at 8,250rpm. Peak torque of 520Nm is developed at 6,100rpm of which 450Nm is available from just 3,500rpm. The 90-degree V10 aluminium-silicon alloy engine block is extremely light yet robust and is the first V-arrangement engine to use a bedplate construction. The aluminium bedplate with cast-iron inlays ensures the engine’s rigidity throughout the rev range, but the complete unit still weighs just 240kg.
The capable chassis of the new M6 permits lateral acceleration in excess of 1g. To cope with such forces, the V10 engine features a lateral force-controlled oil supply that, from 0.6g of lateral movement, activates one of two electronic oil pumps to draw oil from the cylinder head and delivers it back into the sump to ensure perfect lubrication even in the most extreme situations. It is because of the extreme forces that can be induced by the M6 that the car also makes use of a semi dry sump lubrication system with an oil reservoir on each side of the front subframe.
Masterminding all the M6’s engine electronics is one of the most advanced engine control systems ever developed. The MS S65 control unit coordinates all engine functions using three 32-bit processors that handle more than 200 million operations per second from over 50 incoming signals. Each of the 10 cylinders has its own throttle butterfly, with its position being monitored 200 times per second. Reacting to changes in throttle position, the butterfly can move from closed to fully open in a mere 120 milliseconds (approximately three times faster than the blink of an eye).
Like the M5, the new M6 also uses BMW’s new third-generation seven speed Sequential Manual Gearbox (SMG) with Drivelogic. Drivelogic offers the choice of 11 different change patterns, depending on the speed of change required. Six change patterns are available in the manual mode and five in the ‘automatic’ mode, in which the gearbox will automatically select the most appropriate gear depending on driving conditions.
The new SMG gearbox also offers safety benefits when downshifting on slippery surfaces. If it detects the rear wheels locking up, the clutch opens for a fraction of a second to ensure traction is maintained. Hill Detection is another SMG feature. In automatic mode, the SMG gearbox recognises that the car is travelling on an incline and holds gears uphill to maintain acceleration and selects lower gears when progressing downhill to make the most of the available engine braking.
The suspension of the new M6 is based on the ‘standard’ 645Ci geometry. With the exception of components such as tie bars, wheel mounts and bearings, the double-arm spring strut front axle is made completely of aluminium. The U-shaped front subframe houses the rack and pinion steering assembly, anti-roll bar and track control arms.
The Integral IV rear axle assembly is also made from aluminium to reduce unsprung masses. In addition, the new M6 features BMW’s variable, speed-sensing M Differential Lock. Featured on all current BMW M models, the M Differential Lock builds up locking action whenever one of the rear wheels begins to spin, channelling drive to the wheel with the most grip to improve handling and stability.
Electronic Damper Control is also standard on the M6. Offering the driver three suspension settings – Comfort, Normal and Sport, drivers can select the most appropriate setting for their driving style or road conditions. The new BMW M6 also features a BMW M version of Servotronic steering with two specific settings corresponding to the Electronic Damper Control settings, Sport or Comfort.
BMW’s DSC stability control system has been adapted for the M6. Featuring M Dynamic Mode (first seen on the new M5), drivers can take their cars to the limit of the laws of physics, allowing considerable angles of controllable oversteer when circumstances allow.
The new BMW M6 comes with a Power button (pioneered in the M5) in the centre console. Initially the car pre-selects the P400 setting, delivering 400bhp for town or city driving, for example. Engaging the Power button modifies the response of the throttle and enables the P500 setting to deliver the full 507bhp generated by the V10 engine.
Control of all of these features has been brought together using the M6’s MDrive Manager. MDrive allows the driver to pre-select specific settings for the Power button, SMG gearbox, DSC, EDC and Head-up Display. With one push of the steering wheel-mounted button, the driver selects his or her chosen character. For example, the car can be set up for an exciting 30 mile A-road drive to and from work or, on the other hand, for a city commute. More extreme settings can be pre-programmed for track use.
For a car with such potential, high performance brakes are needed and the new BMW M6 doesn’t disappoint. Using aluminium double piston callipers and cross-drilled disc brakes, the car can stop from 62mph in just 36 metres and from 124mph (200km/h) in only 140 metres – equivalent to 1.3g deceleration.
Specially developed tyres ensure that the prodigious horsepower and braking power are transferred to the road. Measuring 255/40ZR19 on the front and 285/35ZR19 on the rear, the tyres are mounted on lightweight five-spoke 19-inch forged aluminium wheels, each weighing 1.8kg less than a normal cast alloy wheel.
Like other 6 Series models, the new BMW M6 uses a hybrid construction of aluminium, thermoplastics and SMC (Sheet Moulding Compound). This mixture of materials delivers an extremely rigid, yet light, body structure. The front wings are made of thermoplastics, the doors and bonnet of aluminium and the boot lid, SMC. Like the legendary M3 CSL, but unlike the 630i and 645Ci, the new BMW M6 also uses carbon fibre in the construction of the roof panel to reduce the weight yet further – this feature alone saves nearly 5kg and contributes towards the overall weight of just 1710kg.
Visually, the new M6 differentiates itself from the 6 Series by a deeper front valance with air intakes for the engine and brakes, more contoured sills and rear valance that includes a diffuser to increase aerodynamic efficiency. Nestling under the rear valance are BMW M’s telltale four rear exhaust pipes. To complement the changes in body styling, the new M6 is available in four exclusive M colours – Indianapolis Red, Sepang Bronze, Interlagos Blue and Silverstone alongside three other 6 Series colours.
Inside, the new M6 comes with fully adjustable M sports seats that include lumbar support and an adjustable backrest width as standard. They are covered in extended Merino leather, with the owner able to choose between Black, Silverstone or Sepang. As an option, full Merino leather can be specified in Indianapolis Red and Portland Natural Brown alongside the other three colours that includes a leather covered dashboard and Alcantara headlining.
The new BMW M6 also features BMW M’s version of the new Head-up Display system. Unlike the standard Head-up Display available on 5 and 6 Series models that offers navigation instructions and cruise control information, the system on the M6 projects driver-focussed information such as engine speed, gear selected and road speed directly into the driver’s view, obviating the need for the driver to take his or her eyes off the road ahead.
The new M6 will go on sale towards the end of 2005. Dates and prices will be announced in due course.
http://www.bmw.com/generic/com/en/pr...se_1/movie.htm
Sources: BMW AG / GermanCarFans
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 12-14-2004, 05:41 AM
Ex-Dictator
Mein Auto: Saab
Photo Set 1
ID:	41396   Click image for larger version
ID:	41397   Click image for larger version
ID:	41398   Click image for larger version
ID:	41399   Click image for larger version
Old 12-14-2004, 05:42 AM
Ex-Dictator
Mein Auto: Saab
Photo Set 2
ID:	41401   Click image for larger version
ID:	41402   Click image for larger version
ID:	41403   Click image for larger version
ID:	41404   Click image for larger version
Old 12-14-2004, 05:43 AM
Ex-Dictator
Mein Auto: Saab
Photo Set 3
ID:	41406   Click image for larger version
ID:	41407   Click image for larger version
ID:	41408   Click image for larger version
ID:	41409   Click image for larger version
Old 12-14-2004, 05:44 AM
Ex-Dictator
Mein Auto: Saab
Photo Set 4
ID:	41411   Click image for larger version
ID:	41412   Click image for larger version
ID:	41413   Click image for larger version
Old 12-14-2004, 06:18 AM
Mathew Mathew is offline
Code 66
Mein Auto: .
Is this Chiaretto (sp) Red?
I still fear that this will be more of a luxo-cruiser than a high-performance car.
Old 12-14-2004, 09:32 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
They could have picked a different color for these photos.
Hey, at least this one has an oil temp gauge (that's right, the real M6 doesn't have one).
Old 12-14-2004, 09:42 AM
philippek philippek is offline
Proud S ponsor
Mein Auto: Z4 M Cpe, Miata, X6 50i
A luxo-cruiser that can do 60 in 4.6?
Great cause for fear indeed.
Old 12-14-2004, 10:00 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Well, despite the fact that the original M6 was raced in touring car racing, it's really more of a cruiser as well. In US spec with the rear AC/coolerbox and Highline leather, it was close to 3600lbs. Doubling horsepower (256 US spec -> 507) and gaining 170lbs is pretty good historical progress if you ask me.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 12-14-2004, 02:23 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Like the E60, this 6 Series interior is just disappointing, no matter how much leather they use to hide the lackluster design, IMO. And in this M6, with the ugliest, nothing-says-sport-there steering wheel, it is a disgrace.
For the rest of the car... this is the second time ever that an M car don't excite me at all, the new M5 and the new M6. And I got this feeling that the new M3 will go the same route. Some details are all right, like the wheels, the roof line, the mid section. Everything else is tacked on to move the BMW design somewhere, just anywhere, it just does not "go". For example, the four bland, straight exhaust pipes are like an incomplete design homework that somebody forgot to turn in on time, in a (supposely) $95,000 car; maybe that's the reason that I keep thinking of replacing my set in the M3, they are just "unfinished business" in this type of car. The impressive mechanicals are there, as well as the driving dynamics will be top notch as always I would assume, but something is telling me that the mechanical engineers don't hang out with the design people too much and viceversa, not even to test drive the cars.
I'm officially convinced that this crop of current design people in BMW are not as talented as they seem to believe.
Well, I guess that the thrill is gone... damned BB King.
Old 12-14-2004, 02:27 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
I'd like to learn how they manufactured the tops of the strut towers. The stiffeners look too narrow to be stamped.
Either it's the lighting or the color, but it looks like the front bumper doesn't match up well with the driver's side fender.
Other than the steering wheel and the pregnant light switch, I like the interior.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 12-14-2004, 02:40 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
I sorta like the side strakes. I was never really a fan of the Z3/E46M3 gills look. And there is no ///M6 badge in the front grille so at least there's some sort of ID toward the front of the car.
The rear bumper has that same ugly @sshole treatment as the M5, but unless it's changed for markets like the US, the license plate is going to cover the middle of it.
IIRC, the first E60M5 press photos didn't have wood inside, but this one does. Doesn't help with the 'luxo-cruiser' image per Mathew's observation.
Old 12-14-2004, 03:35 PM
WILLIA///M's Avatar
WILLIA///M WILLIA///M is offline
95NU>*
Mein Auto: '04 Imola/Cinn M3
Better looking than the 5 but still kind of bulbous and bloated looking. It is a big badass cruiser though. Worth the cost?
I'm not a race car driver, but I play one on my TV.
Old 12-14-2004, 04:36 PM
ZHPerfect ZHPerfect is offline
Mein Auto: '94 Acura Integra
Not saying that i'm not a fan of the weight savings and lower center of gravity of the CF roof, but what are they to tell all the people buying this car not for performance but because it's the newest hottest thing where their precious moonroof has gone?
Old 12-14-2004, 04:41 PM
Also... i think the reason that the design is kind of a letdown is because M cars typically have flared fenders and a noticeably wider track than their pedestrian stablemates. Apparently the M6 doesn't need bigger tires than the 6 is already designed for... i.e same fenders. Not a huge deal but a detail that is guilty for the relatively mild visual transformation between the non-M and M models that many people may gripe about.
Old 12-14-2004, 06:21 PM
Jeff_DML Jeff_DML is offline
doh!!!
Mein Auto: 1999 E36 M3/2/5 Estoril
looks better then I expected. Does look/seem like a huge luxo cruiser but I guess it is not a M3.
Old 12-14-2004, 07:21 PM
jrp's Avatar
jrp jrp is offline
Informed Badge Whore
Mein Auto: JS Edition 340i
Old 12-14-2004, 11:32 PM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
Originally Posted by jrp
Car and Driver made the same analogy in a recent 6-series review.
Old 12-14-2004, 11:37 PM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
One of the best angles of this car.
Old 12-15-2004, 03:21 AM
Josh (PA)'s Avatar
Josh (PA) Josh (PA) is offline
superwagon pilot
Send a message via Yahoo to Josh (PA)
Mein Auto: 11 135vert 09 e61 03 e46T
It's strange not seeing fog lights in the lower grille. Overall it's a far more bland form than any previous M-car, it just seems unemotional. I guess if I had to give an opinion, I'd say I don't hate it, I'm just kind of blah towards it.
Old 12-15-2004, 09:30 AM
jrp's Avatar
jrp jrp is offline
Although I never wore a mullet, I once owned an IROC...the resemblance of the new 6 is even more striking in person. Not in terms of styling details but from a "line and general presence" standpoint.
The new M6 definitely does not have that old familiar, "Oooh I must have it" factor. Definitely nowhere near as sexy as say, a Jaguar XK. But it won't take much guessing and speculation that the driving experience in the M6 will be on a much higher plain. Could be the litmus test for the true enthusiast, "Exactly how much do you really value substance over style?" The M6, she's not much to look at, but boy, can she cook!
Or...it could be the ultimate confidence in marketing as well. As long as there's a roundel on the nose and tail, there will be enough poseurs and brand whores who will buy it.
Old 12-15-2004, 09:31 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
"typically?" Hmm, only the E30 and E46 M3s have different fenders than their non-M counterparts. Every other M car has had very minor body differences; usually different bumpers and rocker panels.
Old 12-15-2004, 11:39 PM
xfactor xfactor is offline
Mein Auto: Volvo C70
The exterior is pretty nice (especially from the rear), but the interior of that car is just atrocious. Let's hope the new M3 abandons that look for the interior.
Old 12-16-2004, 11:52 AM
Riuster's Avatar
Riuster Riuster is offline
Riuster = Rooster
Mein Auto: 02 M3, 07 X3 and 04 TSX
You kidding, you like the rear? its soo damn ugly....both are ugly..how can they make such a big mistake?
HOW HOW HOW
02 CB/Blk Lthr, Cold/Prem. Pkgs, HK, Xenon, Rev. Alert, SMGII, ACS comps, Hamann Comps, OEM Bar, Intros Aero Pol 19s 2-3 In.lips, w/275 Potenzas, Koni S, RMS, AA GEN3, SS Midpipes, DDE lights, LED Retrofit, Lthr Steering, OEM Sheepskins, Kewood Amateur 7000, XM 2, V1, GT2, Garmin 7200, Carputer-SONY T140 with Xenarc display, CSL splitters, ACS diffuser
BMW 2007 AW X3, prem and cold pkg.
Acura 2004 CG TSX
  #25
Old 12-16-2004, 12:03 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
I have to agree that interior is terrible. And aside from the obvious performance numbers there is nothing I like about this car.
Hopefully the next generation of cars from BMW will be more attractive.
Photobucket
Similar Threads
Official E90 Thread - Pictures and Press Release Alex Baumann 3 Series & 4 Series 171 01-16-2005 08:19 PM
Official E60 M5 Concept Pictures Alex Baumann 1M & M2 35 05-06-2004 05:30 PM
