$100 CASH Back With your Order of any UUC Big Brake Kit - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds
Classifieds
Post for sale items in one of the for sale categories. Click here to browse new posts.
Old 12-18-2004, 01:16 AM
Mike@Modbargains's Avatar
Mike@Modbargains Mike@Modbargains is offline
Mein Auto: E46 - E82 - CTS-V
$100 Cash Back with your Purchase of any UUC Big Brake Kit!!!
Performance: compared to similar brake systems, the UUC Ultimate Brake Kit provides more brake torque than other systems - up to 40% in some same-size rotor examples. Stiffness and caliper deformation characteristics are comparable or superior to other designs, and piston sizes are optimized for each application.
The Ultimate Big Brake Kits are designed as a complete systems, not individual components. This means that the caliper and piston sizes are optimally calculated for the specific application. Piston sizes ranging from 38mm to 48mm are used, with rotor sizing from 330mm (13'' - UBBK330 kits) to 355mm (14''- UBBK355 kits). Everything from the diameters of the pistons to the length of the DOT-approved stainless steel hoses are designed for that specific model. For example, the specifications of the 3-series kit is tailored to the weight, wheel size, and balance of those cars. Likewise, a kit suitable for the 7-series has a completely different specification list. No grinding or permanent vehicle modification is required for fitment of this system as it is designed specifically for each particular vehicle.
The Ultimate Big Brake Kit is easy to live with. As needs develop, the UUC Ultimate Brake Kit has many resources. Need the replacement rotors? They are available. Need replacement seals? Yes, a standard part easily sourced. Need a different brake pad compound or one that just lasts longer? Yes, virtually whatever type you may want.
With the Ultimate Big Brake Kit, there''s no need to bust the bank. No need to spend $2800, $3200 or more on a big brake kit that will provide more than adequate braking power and performance. The Ultimate Brake kit is available for those looking for performance without sacrificing their entire upgrade budget.
Complete Kit Includes: Calipers, Rotors, Pads, Stainless Steel Lines, Mounting Brackets, Mounting Hardware
CLICK HERE TO ORDER
Mike Brown
Co-Founder & CEO
ModBargains
ModBargains Specializes in:
BMW Wheels | BMW Exhaust | BMW Parts | Forgestar Wheels | VMR Wheels
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
Wallenrod's ED Adventure Wallenrod European Delivery 36 06-02-2004 10:45 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
Changing front rotors/brake pads Esteves E36/7 Z3 (1996-2002) 7 05-25-2003 09:30 AM
