Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-29-2004, 06:37 AM
ChrisF ChrisF is offline
Mein Auto: 2002 330 xi
Parking Brake Adjustment DIY
After changing my pads and rotors last month, I noticed that my parking brake seemed a little loose. I had to pull the brake handle up like 10 or 11 clicks to get it to fully engage.
Thanks in large part to what I've learned here on this board, I went ahead and adjusted the parking brake yesterday. The only problem I had was that I wasn't able to adjust the parking brake shoes by removing one lug nut from each tire and accessing the brake shoe adjuster through the lug nut hole as described in the Bently manual. Maybe with some more practice I could make it work that way, but this time around I ended up just pulling off the wheels and rotors so I could see what I was doing.
I documented the procedure in this Parking Brake Adjustment DIY. It's a pdf so you'll need a copy of Acrobat Reader to view it. If you don't have Acrobat Reader, you can download it here.
I hope others find this useful. I've certainly benefited from the many good DIY write ups here, so I wanted to contribute to the cause. Enjoy
ChrisF
2002 330xi, 5-spd, Orient Blue w/ Sand Leather, SP, PP, Xenons
Old 01-02-2005, 08:09 AM
reevesna reevesna is offline
Acceleration Junkie
Send a message via AIM to reevesna
Mein Auto: '99 328i, '03 cbr954RR
hey thanks for the post...i too have had difficutlies with my parking break ever since i purchased the car this summer...not that it doesn't work or anything...as long as ur on a flat level surface it works just fine anyways i'll be sure to read ur acrobat file and hopefully i'll learn something about the adjustment and resolve the park break issue...thanks for the post
Old 01-02-2005, 09:52 AM
alpinewhite325i alpinewhite325i is offline
I love my beautiful wife.
Mein Auto: '01 325i
My parking brake is so tight, I couldn't get my rear rotors off to replace them when I did my brakes last week.
'01 325i
5sp
I Love my beautiful wife
moonroof:
Old 01-02-2005, 01:06 PM
Not trying to be a wise guy, but
you did remember to disengage the parking brake before attempting to remove the rear rotors right? You'll never get them off if the parking brake is engaged.....
ChrisF
Old 01-04-2005, 03:55 PM
Mein Auto: '01 325i
I did disengage it.
I wonder if I loosen the bolts under the p.b. handle will give me enough clearance to get the rear rotors off???
Excellent "diy" BTW.
'01 325i
5sp
moonroof:
Old 01-04-2005, 05:00 PM
Stevies3 Stevies3 is offline
Mein Auto: Mazda3
In the past, I thought to adjust the rear pads you simply drive in reverse and firmly step on the brakes. Doing this a few times is suppose to adjust the rear pads. Steven
Old 01-04-2005, 05:04 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
No, you need to turn the barrel adjuster in the hub through one of the wheel stud holes.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 04-04-2008, 01:09 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Thank you Chris for the excellent parking brake DIY
Thank you Chris!
I must say that I read a LOT of articles on E39 brakes before finding yours on the parking brake adjustment.
Too late for me, I hope others find your DIY before they complete their job wrongly (like I did).
http://www.bimmerfest.com/forums/sho...hlight=bluebee
In my case, I followed the Bentley instructions, but, methinks most people don't even touch the settings. When they put on the new rear rotors, their driver-side parking-brake lever only changes by a couple of clicks, I guess.
Old 11-16-2008, 08:59 AM
bluebee's Avatar
Zeckhausen parking brake DIY
This is a good html link for parking brake adjustment and replacement
http://www.zeckhausen.com/E39_BMW_Re...arking%20Brake
Old 11-16-2008, 01:55 PM
Black 335xi Black 335xi is offline
You talking to me?
Mein Auto: 2008 335xi Coupe
Nice write up Chris
2008 335xi Coupe Black Sapphire Metallic | 6MT | Sport Package | Cold Weather Package | Premium Package (Saddle Brown Dakota) | Navigation w/iDrive | Sattelite Radio | Dinan Exhaust
2009 KGT1300 Apple Red Metallic
2008 R1200RT Blue Biarritz (sold)
2003 Goldwing Black (sold)
Old 11-19-2009, 04:29 AM
boleneger boleneger is offline
Mein Auto: bmw 320i
Perfect lesson to all of us. Thanks a lot mate.
Old 07-13-2010, 06:30 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Just finished up this parking-brake install with the Pagid kit. Also replaced pads and rotors. I didn't have much luck counting the number of clicks I turned the star wheels when adjusting the e-brake shoes so I just bolted the new rotors on and tightened up the adjusters until I could not longer spin the rotors by hand.
The rotors I've installed are new Zimmerman zinc-coated, and that coating comes off really fast at the friction points. After getting everything back together, I have great parking brakes now ... compared to almost nothing ... at 150K the Jurid shoes were bare metal....
Old 07-22-2010, 05:53 PM
gerardw gerardw is offline
Mein Auto: Z3
In my case I was able to adjust the brakes without removing the rotors, but only because Chris's write up made it so clear what was what.
Old 02-02-2011, 10:41 AM
Bmonkey Bmonkey is offline
Mein Auto: X5 E53
Fantastic tutorial, Chris!! Great photos and readable text. Where can I buy your tech manual on disc?!? If it's not ready yet, what is the best one you've seen and would recommend?
Anyone else have a tech manual suggestion for an '04 E53 X5 3.0 man. trans?
Old 09-13-2011, 07:21 PM
Billy Hopkins Billy Hopkins is offline
****ie w/ my 528i
Mein Auto: 1999 528i w/ 16" wheels
So clear and concise! I want to read it again, because I learned something. Great job.
Old 12-03-2011, 02:11 PM
Tweezer Tweezer is offline
Mein Auto: 530xi sport wagon
Does it go without saying that the transmission should be in Neutral (so that the wheel can spin)? Thanks again, great write up!
Old 12-04-2011, 07:06 AM
Anyone know how to remove the dust boot on a 2006 530Xi wagon?
Old 08-18-2012, 10:51 AM
rotorbrain23 rotorbrain23 is offline
Mein Auto: 325i
Thanks ChrisF
One of the more organized write ups I've seen on here, complete with powerpoint text, awesome! thanks again. rotorbrain23
Old 01-22-2013, 01:33 PM
antsnaidoo antsnaidoo is offline
Mein Auto: BMW 320i 2007
new member
Hi I'm Anthony and I own a 320i E90 model 2007.
I've got the vehicle for 2 years now and had endless problems with the agents regarding repairs, I've decided to do all repairs myself and found your site very valuable and informative, thank you very much for your support. Oh I'm from South Africa.
I have one problem though.
The right rear brake is binding and getting very hot.
How do I solve this problem, do I need to change the shoes or is it just a matter of adjusting the shoes, please help my daughters getting married this weekend (26/01/2013) and I need the car to be fixed before this date. Thanks Guys.
Old 01-26-2013, 12:48 PM
catso's Avatar
catso catso is offline
catso
Use the procedure in this thread to adjust your parking brakes but make sure all the parts and cables are moving freely. I've noticed the mechanism in the rear rotors' drums getting rusty over time. You may have to remove the rear rotors and disassemble, clean, and lubricate things to assure smooth operation of all the moving parts.
![/I][/FONT]
Old 01-28-2013, 07:53 AM
Thank you very much, I've managed to adjust it through a wheel nut hole.
Thanks for your help.
Old 02-06-2013, 09:40 PM
Hi guys can anyone tell me what is the the service intervals for a bmw 320i exclusive E90 2007. My vehicle is under warranty and they refuse to pay for repairs on the diff, saying the vehicle was not serviced on time. As far as I know the intervals are 25k to 30k, that's according to the specifications.
Old 02-16-2013, 04:14 PM
HeliBarney HeliBarney is offline
Mein Auto: '02 540iT Wagon
Adjusting Gears not at 6 o'clock??
I have a 2002 540iT, and recently spent a couple of frustrating hours poking around with a flashlight and screwdriver and scouring BMW forums to learn that, on my E39, the parking brake mechanism isn't at 6 o'clock, as stated in many of these posts, but rotated 90-degrees to the rear.
So the adjusting gear is at approximately 3 o'clock on the left/driver side, and 9 o'clock on the right/passenger side. I assume this is just for the Touring/Sport Wagon, but am not sure. I also can't remember which way to turn it to tighten, but think it's toward the front on the right side, and toward the rear on the left side. If you turn the gear it to the extreme and the wheel won't move, it's tight - then back it off by the recommended 12 notches.
Old 05-21-2013, 09:56 AM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
Lightbulb
In the old days, to adjust shoe brakes, with the auto adjuster, you could drive backwards at moderate speed and slam the brakes,, when I put new rear rotors on, the Zimmerman with zinc coating (PAGID Pads), the emergency brake shoes had plenty of meat, the last owner said he never used the emergency brakes. I just tightened them up a bit at the cable ends on the console. While they are not very good, they are better than no emergency brake, even though it is an auto trans, it's stil good practice to use them to relieve strain on the park setting of the auto trans.
IMHO
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Similar Threads
Parking brake adjustment Mark_325i Do-It-Yourself H.Q. 8 04-17-2010 07:53 PM
Rotora Brake System Performance on BMW M3 Racer Car ralphwarren Motorsports, Racing & Track 6 03-13-2009 06:00 PM
Rear Rotor Grinding Noise - Could it be the Parking Brake? MantisMan13 3 Series & 4 Series 9 11-09-2004 07:35 AM
Dave Zeckhausen Brake pad recommendation please Tom S. 5 Series 19 03-08-2004 06:29 PM
Parking brake concern stan323i 3 Series & 4 Series 6 07-23-2002 08:53 AM
