Got "configure sports mode" working on a 2014 F10 - Bimmerfest - BMW Forums
Old 04-07-2015, 07:00 PM
bmw325 bmw325 is online now
Mein Auto: 528i
As many of you know, it hasn't been possible to get the "configure sport mode" menu working properly on an NBT equipped car simply by changing the MACRO_FDS parameter in HU_NBT. You'd get the menu but then couldn't select one of the choices.
Today, I FDL coded the ICM module and changed Icmkod_b_sportsindividualisierbar to ein (werte 01). Lo and behold, the menu now works! (I had already coded MACRO_FDS in HU_NBT to "popup_and_configure" previously).
Apparently, 2015 F30s now get this standard and you can enable it by simply changing the "zeitkretierium" to 0714 and FA coding NBT, ICM and FEM_body. THat didn't work on my F10 so I went looking through ICM and came across that setting.
Finallly I can select the heavier sport steering without having the touchy throttle along with it. I'm very happy about this.
Note: car was recently uprgaded from 52.3 to 55.1 by the dealer, so I'm not 100% sure this would work on older versions, but I suspect it would.
Old 04-08-2015, 03:10 AM
SergAA SergAA is offline
Mein Auto: 535d 2013
Can you please make and share the foto's of this menu, to understand do i need it or not? ;-)
Thank you in advance
Old 04-08-2015, 03:49 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Good to know. Thanks.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 04-08-2015, 07:16 AM
Mein Auto: 528i
Originally Posted by sergaa View Post
can you please make and share the foto's of this menu, to understand do i need it or not? ;-)
thank you in advance
Old 04-08-2015, 08:23 AM
Aha, Ok. This menu i already have from factory, on pre-lci f10... Thanks for foto =)
Old 04-08-2015, 08:47 AM
Mein Auto: 528i
Yeah on US cars they only give it to you if you buy an active suspension option. Used to be codeable in the cic days with just 1 parameter. They added this extra twist when nbt was introduced I guess. And it's now standard on f30s (but not f10s). Go figure. Thank god (and shawn) for coding.
Old 04-08-2015, 08:57 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
+1
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 04-08-2015, 10:11 AM
Rsnic's Avatar
Rsnic Rsnic is offline
Mein Auto: 2014 328i (F30)
Hi,
Will this work on a 2014 328i as well? Do you have to have any specific options?
Thank you very much
Al
2014 328i |Premium| Technology| Cold Weather| Harmon Kardon Stereo| Manual|
Mods: Rear deck spoiler| DRL, Amber Rear turn signals & Back-up LEDs| Rear & Side view cameras| Front & Rear PDCs| Addional interior pearl gloss chrome trim
BMW CCA
Old 04-08-2015, 12:14 PM
Mein Auto: 528i
Originally Posted by Rsnic View Post
Hi,
Thank you very much
Not sure but it should. No specific options
Old 04-11-2015, 05:26 AM
Rsnic's Avatar
Am curious because my car has "standard" suspension, steering and brakes. If they can be "adjusted", that would be great!
Al
BMW CCA
Old 04-11-2015, 07:05 AM
Mein Auto: 528i
It will adjust the transmission, steering and throttle. But that should already happen when you select sport mode. This menu allows you to configure sport mode to only change the steering (chassis) or throttle and suspension (drivetrain). It won't affect suslebsion unless you have dhp
Old 04-11-2015, 07:12 AM
Rsnic's Avatar
BMW325,
Thank you very much!!
Al
BMW CCA
Old 04-11-2015, 07:20 AM
zkiifreak's Avatar
zkiifreak zkiifreak is offline
Mein Auto: F11 520d
What is the parm in the CIC? Thanks
10.10 F11 520D w MPPK, black sapphire.
Old 04-11-2015, 07:47 AM
Mein Auto: 528i
You only need to change macro_fds to popup_and_configure if u have cic. No need to mess with icm
Old 04-13-2015, 01:56 PM
Rsnic's Avatar
Didn't have to change build date, just coded the items listed above and now have the selectable menu under Configure Sport Mode.
So in my case (with manual transmission, "standard" steering & suspension), selecting:
  • Chassis gives me the tighter Sport Steering & Comfort accelerator
  • Drivetrain gives me a more responsive Sport accelerator & comfort steering
Is that correct?
Thank you very much
Al
BMW CCA
Old 04-13-2015, 02:42 PM
Mein Auto: 528i
Is that correct?
Thank you very much
Correct - the transmission shift points also change when drivetrain is selected - same as when you move the shift lever to "DS" mode
Old 04-13-2015, 02:51 PM
Rsnic's Avatar
Thanks -- omitted shift points as they remain the same -- between my ears :-)
Terrific!
Al
BMW CCA
Old 04-13-2015, 03:02 PM
Mein Auto: 528i
Terrific!
Sorry - missed that you've got a manual!
Old 04-13-2015, 03:22 PM
Rsnic's Avatar
Kein problem :-)
Al
BMW CCA
