Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
330i vs 330xi, would you notice any difference ...
driving them back to back? Does the xi feel heavier and slower?
Thanks, Mike
2001 BMW 330Ci 5 Speed Manual
"This is a revolution, dammit! We're going to have to offend SOMEbody!" |
Yes, the x will fell slightly heavier and slower. But faster on snow.
Obvious, isn´t it ? |
Off the line the xi is a tiny bit faster because of traction, but they even out. The i is lighter should handle slightly better, but unless your tracking this thing you wont notice much of a difference.
There is more of a difference between the 325xi and 325i
You will feel it in a few ways:
1) The xi steering will be heavier and you will feel torque steer on the throttle in turns. (NOT in a straight line.) 2) xi initial roll is greater than a RWD 3'er with the sport suspension, but ABSOLUTE roll is much greater in the RWD version. 3) Acceleration will be marginally worse, but not that bad. 4) Braking will likewise be marginally worse. 5) When driven hard, the xi requires a far more careful management of grip.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed 1995 BMW M3 Alpinweiß/Black 1999 323i KP/GTS2 Alpinweiß 1989 325is S50 Alpinweiß/Black 1988 M3 Alpinweiß/Black Basket Case
You actually have these enabled?
-rkahn |
Xi with snows has superior traction over your RWD with snows.
Greater satisfaction for the same price.
In braking, the Xi took 175 ft to stop from 70 mph, whereas the WRX (a whopping 433 lbs lighter) took 181 ft and the S4 (127 lbs heavier) took 164 ft. Skidpad was .78g Xi, .82g WRX and .86g the S4. The Xi did not have any performance tires or suspension. Then Car and Driver tested a 2003 330i Performance Package on 9/03 which did the 0-60 in 5.6 sec, the quarter in 14.3 sec @ 97mph and took 158 ft to stop from 70mph. Skidpad was .86g. So sometimes weight works in mysterious ways... |
I have an 04 330xi with the sport package. I wasn't going to bother with AWD but my wife wanted one car in the "fleet" with it. I don't find it that different from a (non ZHP) 330i, except that under acceleration out of some corners you will sometime feel the torque steer. You might have to "manage" your turns a little more but no biggie. The steering also feels a little heavier but not enough that it bothers me. Seat of the pants acceleration or braking didn't feel much different between the two. Maybe it is the sport package or the 330 model, or the fact it is a sedan, but the xi does not seem to sit that much taller than the "i" either.
I don't like the A/S run-flat tires - they are too greasy feeling in the wet and are not the best handling tire. The snows I put on for this winter (Semperit Sportgrip) actually feel better on the car. I may replace the run-flats with standard performance summer tires. Even though it is a heck of a lot bigger and heavier than the open-wheel cars I used to race, it is still enteraining snicking through the gears and running the backroads. Overall the car puts a smile on my face and that is not a bad thing.
![]() 04 BMW 330xi 6spd w/Premium,Sport,Winter & Xenon 02 BMW K1200RS moto 06 Pontiac GTO 6MT RIP '99 BMW 528iT |
I'm sorry, I didn't mean to bring up the snow factor because I'm not sure if mtmnet was even considering that. I just mentioned it because living in the Northeast I had some reservations about going with a RWD and snows and I also considered the Xi, but I wanted to mention that I'm very pleased with the RWD and performance snow tires. I should mention that I do have an AWD Subaru Outback which I use when the weather gets really nasty. That car has new A/S tires and it does take hills bettter then the RWD with snows, BUT in every other situation, other then straight ahead traction, the 330i with snows is better then that car. The 330i with snows brakes better and is more stable on corners. I just love the characteristics of the RWD 330i with summer tires during spring, summer and fall so much that I think it's worth it to get the (i) and spend the money on winter wheels and tires. Even though you are going to spend another 1K on winter wheels and tires and you could put that 1K towards the Xi and not bother with changing wheels, keep in mind that over the winter that set of rims will get trashed, they will get all pitted and nasty looking from not cleaning them often enough. Plus like I mentioned before the traction you gain from snow tires is very confidence inspiring. Let's put it this way, even if I got the Xi, I would still get a set of winter tires and snows for it. The bottom line is this, if RWD is important to you then get the (i), if not then get the Xi. |
Now if I could just win the Lotto.. |
I'll live with the so called marginal handling in winter. Last edited by ObD; 01-16-2005 at 12:15 PM. |
It's funny how the guys who are so confident about the superiority of summer tires over All-seasons on dry roads get vague about the superiority of Ultra high-performance all seasons over winter tires on those same dry roads.
For those of you interested in high performance winter tires that rock in snow, wet & dry - check out the Vredstein Wintracs. I really can't say enough about the performance aspects of this tire. On my Audi S4 I run Yoko AVS sports on 19" rims for my summer tires and switch to Vreds on 17" rims. Yeah - you can somewhat feel the additional sidewall (flex/wobble) and in the dry it doesn't have quite the stick - but its really amazing how close it is. For 95% of my (hard) driving - I don't at all miss the Yokos - yeah the Vreds are just that good - I could use this tire year round (and so far wear seems very good as well) - and in fact last year I kept the Vreds on till June!
And its hard to compare between vehicals - but I'd swear by both the Yokos and the Vreds over the Michilen Pilots I have on the Bimmer (all nice tires). But I really think the Vreds are grippier - even in the dry(but noticibly so in wet weather)...but it just might be the AWD. Anyway - I recently dogged this Sti in the rain where try as he might (in the twisties and on the straights) he could not pull away from me - and he was fishtailing, slipping and sliding all over in the corners - my traction control never went on and I never slid - even a bit - I was firmly planted to the pavement with the Vreds - at high speeds and in the rain. And yeah - snow tires in general really make sense for snow driving. The Vreds are so vastly superior to the Toyo all season (performance) tires I had previously used - and consider the dangers/risks - its really worth a winter change out (and yeah - I have stacks of wheels & tires in my garage - lol).
Current Rides: 2004 330i Sedan - ZHP - Imola Red - alcantara, xenons, cold w/hole in roof, silver cube ![]() 2001 Audi S4 Avant - Nogaro Blue, St3, AWE ex/dp, Stptch brks, KW coilvrs, h-sport sways, EVO CAI, B & M ss, Clmster st3 LtwtFW - etc 1964 1/2 Mustang Conv - 289 4 bar V8 - Vintage Burgundy - unrestored/near mint - 53K miles [b][size=2] |
If you are worried enough about snow to get AWD, then go all the way and get AWD + snow tires.
2004 330i ZHP Black Sapphire Metallic and Black Leather Cold Weather Package Lumbar Support Moonroof Xenons |
I hate to bring a thread back to life after it's been dead for a while but here goes.
I ran my 330xi for 2+ years on the GY AS tires and they did a decent job but they are a compromise in the winter and summer and I would suggest tossing them all together. This year I switched to Wintersports for the winter and they make a big difference in handling and stopping but not as much of a difference in traction. I thought it would be night and day but it's not. Can you notice? Absolutely! But not night and day. What I have found is that the AWD system will make the most difference, followed by the tires. We picked up the X3 this year and it is night and day better in the snow compared to the 330xi and the X3 has stock tires on it. There is a new development going in up the road and we have taken both vehicles through the un-plowed snow and the you can't even compare the 330xi to the X3. Although the 330xi with snow tires will get you there and back 99.9% of the time, I can only imagine what it would be like with a real AWD system like the X3 or Audi. I wish I had it the one time I got stuck 3/4 the way up my steep driveway with 1' of snow on the ground Luckily I did the right thing and put it in park and cleared the driveway around the car
330xi (sold) 1965 C2 Roadster 2005 X3 3.0 1997 TJ Sahara 2008 JK Unlimited Sahara |
I have chance to drive 330xi in BMW fund racing for breast canser event. Let me chip in my 2 cents here, but it is base on the impression of xi on a 30 minutes test drive, so no acceleration or handling measurement number from me. On the process of getting in to he car, I will immediately feel the car is higher, this makes getting in and out easier. The increase in ride high is actually very noticeable when going around freeway ramp, car rolls more than the i. Xi in feels heavier mainly because the steering is heavier. In terms of acceleration, I would say it is about the same as i but the RPM on xi is notically higher than i at cruising speed. I didn't experience torque steer on xi at all. On the exist of the corner, I though I can put it harder because of tht AWD, but the body roll of the xi tells me that I don't want to push it any harder than i. Overall, I think xi is a great car, but it is just not as sporty as i especially with the high stance. Also in CA, xi really doesn't show its advantage over i. eel |
![]() After running the xi with the performance snow tires this winter... I still like the way the 5er feels in the snow. The xi felt unpredictable in some of the nasty stuff I drove in, like it was wandering, trying to find which wheel to give traction to. I'm not sure if changing to the WS-50 type Blizzaks that the 5er has would help.
I know I'm going to get flamed, but let me just add how amazingly bad summer tires are in the snow. I figured I wouln't drive in the snow and I'd make it 1/2 a winter without getting wheels and tires, but boy was I wrong. The only thing that saved me from a dozen wrecks was the manual gearbox, otherwise I would have been toast. Needless to say I learned my lesson.
I learned my lesson last year when the Explorer got stuck 3/4 the way up. I tried to keep going and ended up going backwards and almost rolled it off the driveway
Took the tow guy 1 hour to get it out ![]() It's best to leave it there and get the snow-blower out and go around it.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| "ZHP" vs. Stock 330i - Acceleration Numbers | Emission | 3 Series | 63 | 06-02-2004 01:22 PM |
| ZHP vs. 330i SP? Help please- | eyeguy | 3 Series | 50 | 05-02-2004 12:47 PM |
| 330i SP vs. 330i ZHP : comparison | ClubSpec330i | 3 Series | 7 | 03-22-2004 07:30 PM |
| First 2500 miles: Thoughts on my 330i, Step, HK, Nav and other aspects | OBS3SSION | 3 Series | 13 | 03-13-2003 07:02 AM |
| What bits of the 330i Performance Package are "worth it" to you? | OBS3SSION | 3 Series | 30 | 03-09-2003 07:59 AM |
