E46 (1999 - 2006)
Old 01-17-2005, 04:50 AM
NJ325ci NJ325ci is offline
Mein Auto: 325ci
Question ? about replacing burned out head light bulb
While driving my 2001 325ci (w/ non zeon headlights) my left side head light burned out (Both my high beams work). My question is can I replace the bulb myself? I am not the most nimble with tools, but would hate the pay the dealer $50 to charge a bulb if I can do it myself?
Any adivse appreciated!
2001 325ci - Jet Blk w/ PP & SP
Old 01-17-2005, 06:32 AM
alpinewhite325i alpinewhite325i is offline
I love my beautiful wife.
Mein Auto: '01 325i
Very easy...check the manual.
'01 325i
5sp
I Love my beautiful wife
moonroof:
Old 01-17-2005, 09:26 AM
mhiggi02 mhiggi02 is offline
Cocoa Beach Bimmer Addict
Mein Auto: 2008 128i Vert
Agreed, you can do it. I have and am not mechanically savvy. However, the high beam on the driver's side is much more akward - you have to really remove the air intake to get it in and out - unless you have REALLY small hands.
Old 01-17-2005, 04:39 PM
Mein Auto: 325ci
Will try to replace it this weekend.
Old 01-25-2005, 02:35 PM
carson2246 carson2246 is offline
Mein Auto: 2000 328Ci
Replacing headlight
Its easy once you figure out the German logic for the locking ring that holds the bulb. Nothing in the manual. Be prepared to replace the other headlight. Mine both went out a week apart. In an emergency, unless they've changed since the 2000 model, the high beam and low beam bulbs are the same. Put one of the high beams in as a temporary replacement.
Old 01-25-2005, 02:59 PM
drmwvr's Avatar
drmwvr drmwvr is offline
Stick Drive
Mein Auto: 330i, 911E, UZJ100
How did it go?
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold
Old 03-22-2005, 07:03 AM
mojo_bmw mojo_bmw is offline
Mein Auto: 325i
Question German logic for the locking ring that holds the bulb?
We want to replace the headlamp bulbs on 2001 325i, but we are stumped. We have been fidgeting and fumbling with the locking ring, but can't seem to get the right twist remove the ring and the bulb. We are afraid of snapping the plastic and so have not used any metal tools, but just aren't able to get the right torque or movement to get the ring off with our bare hands. Suggestions welcome!!!
Old 03-22-2005, 12:03 PM
edsmax's Avatar
edsmax edsmax is offline
I shift my own gears!
Send a message via AIM to edsmax
Mein Auto: Orient Blue 01 330i Sport
Be forcefull and m,ake sure you are turning the correct way. if you shine a flashlight in there and look at the holes in the locking ring, you will see the correct way to turn. It is probably just a bit stuck becasue it has never been changed.
Ed
Mods: BMW OE Clear corners, OE aluminum ///M shift knob, GruppeM CAI, UUC Clutch stop
Old 05-23-2005, 12:15 PM
mjames's Avatar
mjames mjames is offline
Dragon Slayer
Mein Auto: 2004 M3
I bought some new light bulbs I want to try, but can't for the life of me figure out how to do it. I've consulted the owner's manual, but the picture is confusing and I can't even find what they are pointing to! I wish there was a guide online showing how to do this. Any hints?
2004 ///M3 - Carbon Black/Cinnamon
Follow me on Twitter: @mnjames
Old 05-23-2005, 12:36 PM
edsmax's Avatar
The bulbs are held in by locking rings. Turn the ring and then pull out (towards the engine). Take out old H7 bulb, insert new one (do not touch bulb with fingers) and installation is the reverse. Easy.
Old 09-07-2005, 07:27 AM
Under90 Under90 is offline
Mein Auto: E39 - 6 speed
edsmax -
i've got a bulb to replace on my 540. Assuming BMW did not go out and design a totally new headlight concept for the 5-series, where did you go for your replacement bulb? Autozone? Online? Does it matter?
Thanks,
<90
Old 09-07-2005, 08:38 AM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
Originally Posted by Under90
edsmax -
Thanks,
<90
Yes. And if you ask nicely they will probably even change it for you.
Photobucket
Old 09-07-2005, 04:01 PM
blackBMr blackBMr is offline
Blk beemer
Send a message via Yahoo to blackBMr
Mein Auto: 328i
true... i had to replace my headlights too... its an easy job but i couldnt do it coz i dont have a manual..!!!!! but the Kragen's guy helped me out..5 mins n it was all good!!!
Similar Threads
Brake Light Bulb zrdster E36/7 Z3 (1996-2002) 1 09-05-2004 10:44 PM
X5 Brake Light Bulb zrdster X5 E53 (1999 - 2006) 2 09-05-2004 01:25 AM
7000K xenon head light blubs (D2S)& 7000K Fog light kits for sale fucy626 Classifieds 0 04-23-2003 10:40 PM
head light bulb ak330i 3 Series & 4 Series 1 10-13-2002 10:02 PM
FS: OEM E46 Coupe Head light Unit with projector lens and Xenon System Hamann330i Classifieds 0 04-26-2002 08:15 AM
