Torque graphs of the new Valvetronic Inline-6 engines - Bimmerfest - BMW Forums
Old 01-18-2005, 01:52 PM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Courtesy of BMW AG
ID:	43063   Click image for larger version
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Ex-Dictator
Mein Auto: Saab
325i left - 330i right
Old 01-18-2005, 01:57 PM
STEVE46 STEVE46 is offline
Mein Auto: 530i Sport
Does BMW try to make it's torque output equal its engine displacement? Or is that just an odd coincidence?
Old 01-20-2005, 09:50 PM
Jspeed Jspeed is offline
Mein Auto: E46 330i
Most efficient street car engines nowadays generate around 100 N-m of torque per liter.
Old 01-21-2005, 02:50 AM
andy_thomas andy_thomas is offline
Mein Auto: 318i
BMW's 2.0 litre inline petrol four: 200 Nm
Yup . But this only applies to petrol engines. BMW's diesels kick out anywhere from 170-190 Nm per litre.
Old 01-21-2005, 04:31 AM
Plaz's Avatar
Plaz Plaz is offline
Mein Auto: '11 1M;'08 MCS;'02 325iT
Nice to see that dip eliminated!
2011 1M
2008 MCS
2002 325iT
Old 01-21-2005, 05:04 AM
Patrick Patrick is offline
Banned
Mein Auto:
Originally Posted by ff
You Europeans with your newton meters and killowatts and such...
I love the Metric System!
Old 01-21-2005, 05:55 AM
Staszek Staszek is offline
Mein Auto: Something German
Euro Delivery Thread
///M3 -6MT
E30 M3 Sold, E36 Sold, E46 Sold, E90 Sold
Old 01-21-2005, 06:24 AM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
Well.. It can't be an odd coincidence... I thought both engines were 3.0 litres?
Old 01-21-2005, 06:27 AM
Ex-Dictator
Mein Auto: Saab
Not the European spec cars. It looks like the US spec cars will be getting the same engine (with different output) according to the order guides that's been mentioned here.
Old 01-21-2005, 04:28 PM
dynosor's Avatar
dynosor dynosor is offline
Mein Auto: 2003 E46 330i
Normally aspirated VS Turbo-charged
The diesels are all turbo charged. If they were normally aspirated their torque would be lower than the petrol engines.
Old 01-21-2005, 04:34 PM
JAWJr's Avatar
JAWJr JAWJr is offline
Le plaisir de conduire
Send a message via AIM to JAWJr
Mein Auto: All Manuals
Maybe a dumb question but if the displacement is the same, what do they change on the engine itself to get a different output out of both? Very confused.
Wouldn't that make it easy to mod a lower output car up to the higher output ones? People always say there's no substitute for displacement...
~Jon
2013 135is | Le Mans / Black w/ Blue stitching | Manual | Premium | HK Sound
1991 318is | BrilliantRot / Natur ette' | Manual | Fogs | Sunroof
2009 135i Cp | Alpine White / Black Plastic Cow | ZSP | ZPS SOLD
2007 Z4 R 3.0i | Silber Grau / Dream Red | ZSP | 711 | 522 | 494 SOLD
2007 335i Cp | A61 / LCSW | ZPP | ZSP | 322 | 4AS | 609 | 655 SOLD
2005 DINAN 330Ci | Silber Grau / Alacantara | ZHP | ED 12.10.04 SOLD
Old 01-21-2005, 04:37 PM
philippek philippek is offline
Proud S ponsor
Mein Auto: Z4 M Cpe, Miata, X6 50i
That is quite impressive. 80% of peak torque available at 1100 rpm? Wow.
Old 01-21-2005, 05:54 PM
dynosor's Avatar
It is very common to use different cams for different applications
It is very common to use different cams for different applications. These affect the breathing of the engine and determine the torque characteristics. Usually, a light car would get more top end power at the expense of low end torque, and a heavier vehicle (SUV/RV/Truck) would get more torque at low speed at the expense of top end power.
BMW had an eta line of engines in the '80s that were optimized for torque and fuel efficiency. The 528e for example, had its power peak at about 4000 RPM and had no high RPM punch at all.
With double vanos (variable valve timing) and variable inlet track length or resonance there is much less need to make this compromise, and torque can be optimized through a much wider engine speed range. The valvetronic engines have so much torque at low speed that they would work well for SUVs and good top end power too.
It would be possible to limit power and torque by means of the engine controller software, but that would be silly. Even sillier than limiting the performance of a particular model by using very long gearing (low revving).
I seriously doubt that the US will get two derivatives of the 3 liter engine, with one called a "325" in that car. The graphs above strongly suggest displacement of about 2.5 and 3 liters. That does not mean there won't be two 3 liter engines with slightly different characteristics; like with the ZHP engine we have now.
Before variable valve timing it was common for hot rodders to replace the stock cams in their engines for ones that improved top end breathing. Today you have the best of both worlds, but it can still be done. The ZHP is BMW's version of such an engine.
~Jon
Old 01-21-2005, 10:05 PM
numbersguy numbersguy is offline
Mein Auto: 2013 535i
It's in the ordering guide. Two three liter motors, one producing 185 lbs/ft peak torque and the other 220.
Maybe somebody can explain to me the advantages of a 325i motor that has been so drastically detuned from the 330i. It still runs on premium, according to the guide, so it won't save money at the pump.
Old 01-21-2005, 10:22 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
If this is really going to be the case, it's probably because displacement sells in this country. The general carbuying public in America will buy a 160hp 4.0l V6 over a 160hp 2.0l 4cyl, even if every other characteristic between the two were exactly the same.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 01-21-2005, 10:53 PM
dynosor's Avatar
Australian broshure
Australian brosure shows 2, 2.5 and 3 liter engines.
http://carpoint.ninemsn.com.au/Tig/U...ias=carpointau
I believe two three liter engines is a typo, but if this is correct, the only reason to do it is economy of scale:
You cover two marketing price points with only one investment in hardware. Same block, crank , head, etc. That suggests the differences are in cams, because if it is only in software, hacks will be selling cheap upgrades in a hurry.
Old 01-21-2005, 11:04 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
But other markets worldwide will get the other displacements.
Old 01-21-2005, 11:06 PM
dynosor's Avatar
Aha!
That means the money has already been invested for other engines, so why not use them. The US drops the 2 liter engine; that is enough deviation.
Old 01-21-2005, 11:15 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Er, you just contradicted yourself. First you say it's economies of scale so they can use the same block/heads/etc. Then next you say they've already made the investment in the different parts. So which is it?
Old 01-21-2005, 11:16 PM
dynosor's Avatar
From BMW USA
Based on this info from BMW on the 5 series, who knows...
http://www.bmwusa.com/bmwexperience/...tm?article=152
http://66.102.7.104/search?q=cache:_...+215+hp+&hl=en
"In order to offer improved performance while at the same time improving fuel efficiency and meeting ever more challenging emissions requirements, two 3.0-liter engines will be offered. In the U.S., the 525i and 525xi will offer a 3.0-liter engine which produces 215 hp (SAE net) and 185 lb-ft of torque at 2,750 rpm. Responsiveness in everyday driving situations is outstanding. Nearly 85 percent of peak torque is available from 1000 rpm all the way to 7000. The 530i and 530xi models will feature a 3.0-liter engine which produces 255 hp (SAE net) and 220 lb-ft of torque. Peak torque is available between 2750 and 4000 rpm. Here fully 90 percent of peak torque is available between 1500 and 6700 rpm."
Old 01-21-2005, 11:39 PM
dynosor's Avatar
Clarification
Ok, let me make my position clear. I don't know if BMW will offer two versions of the 3 liter engine, but I am trying to find evidence one way or the other.
I think that detuning the 3 liter engine could make sense if it allowed you to build more of the same engine, and not a 2.5 liter engine. As the rest of the world will be getting a range of engines, including a 2.5, offering two 3 liter engines is not being done for economy of scale.
Perhaps I should delete my previous posts or edit them as my opinion develops and new facts come into play. On the other hand, I think I have already edited some and thereby seem to be contradicting myself.
I was offering a potential reason for doing something, not stating that as fact. It seems the facts point away from economy of scale, in this instance.
Old 01-22-2005, 05:36 AM
Detuning might make sense if the detuned motor would run on regular. Which BMW owners would rejoice over a savings of $.25 per gallon? Many of the same ones who drive 325s and 525s with slushboxes. Yet the ordering guide says premium for both motors. Maybe THAT is the typo.
Old 01-22-2005, 10:50 AM
Jalli's Avatar
Jalli Jalli is offline
Mein Auto: 11 X5 35i
or they could just be putting it in there for bragging rights... look even our base model has a 3.0 liter engine...
It is not surprising to me at all that the US would get a 3 liter in both cars. The reason is that competition from other brands is so tough here .
Old 01-22-2005, 11:53 AM
kyfdx's Avatar
Who, me?
I still don't get it..
I see that Europe is getting a 2.5 litre engine.. But, they are saying that the U.S. 325i will have a 3.0 litre engine..
And, yet.. coincidentally... The power specs for the 2.5 litre and the "de-tuned" 3.0 in the U.S. model are identical?
This just doesn't seem right.. I can't believe they will be building these cars in the next few weeks.. and, no one seems to know for sure..
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 04:52 PM
MazdaSpeed 6 Official info from Dealer Optimus Prime General Automotive Forum 47 10-18-2004 04:07 PM
My ZHP is slow! Nefilim 3 Series & 4 Series 103 06-25-2004 12:04 PM
Valvetronic engines DaveN323i General BMW Questions 2 03-28-2002 09:24 AM
