E46 (1999 - 2006)
Old 01-18-2005, 08:49 PM
tmjb tmjb is offline
Mein Auto: 530i
Bluetooth: 2005 voice recognition add?
I have read many Bluetooth posts but haven't clearly understood the answer to this question: With a 2005 Bluetooth (and NAV) eqipped car do you need to add a voice recognition module in order to voice dial (and voice activate the NAV)? It seems that this comes with the Bluetooth retrofit kit necessary for non-factory Bluetooth cars.
If this is the case, where do you get a voce activation module (is this also known as an SES?) and how much should it be. Also, is it then better to get an '05 car without Assist (assuming you don't otherwise want the Assist functions) and install a Bluetooth kit?
Please advise. Many thanks.
Old 01-19-2005, 05:28 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Originally Posted by tmjb
I have read many Bluetooth posts but haven't clearly understood the answer to this question: 1)With a 2005 Bluetooth (and NAV) eqipped car do you need to add a voice recognition module in order to voice dial (and voice activate the NAV)? It seems that this comes with the Bluetooth retrofit kit necessary for non-factory Bluetooth cars.
2)If this is the case, where do you get a voce activation module (is this also known as an SES?) and how much should it be. 3)Also, is it then better to get an '05 car without Assist (assuming you don't otherwise want the Assist functions) and install a Bluetooth kit?
1) Yes, you need the SES.
2) Pacific BMW, Circle BMW, any BMW dealer can sell you the newest one for around $375.00; Circle BMW has one with an old part number that costs $265.00, I bought that one and works pretty good for me. What is the difference between this one and the newest one in term of features: none. However (and I am guessing here), perhaps the voice recognition decoding software is more precise (less prone to voice recognition mistakes).
3) The BT ULF module is around $500.00 with the SES built in, installation is extra or you can DIY. The Assist/BT factory single option is $750.00, it is bundled into the Premium Package or even standard depending if your M3 is a Convertible. So it all depends of what you want to spend and maybe you do not have any decision to make at all if you have a Cab...
Old 01-19-2005, 08:51 AM
Mein Auto: 530i
3) The BT ULF module is around $500.00 with the SES built in, installation is extra or you can DIY. The Assist/BT factory single option is $700.00, it is bundled into the Premium Package or even standard depending if your M3 is a Convertible. So it all depends of what you want to spend and maybe you do not have any decision to make at all if you have a Cab...
Thanks for the reply. So with Assist you can still add the VR? Is installation just a question of plugging it in and bolting it to a bracket in the trunk?
Am I correct that installation of the BT ULF involves installing a button in the center console and a microphone in the trim above the interior mirror in addition to installing a box in the trunk?
Old 01-19-2005, 09:04 AM
Technic's Avatar
Mein Auto: 2017 M3
Thanks for the reply. 1)So with Assist you can still add the VR? 2)Is installation just a question of plugging it in and bolting it to a bracket in the trunk?
3)Am I correct that installation of the BT ULF involves installing a button in the center console and a microphone in the trim above the interior mirror in addition to installing a box in the trunk?
1) Yes
2) Is as simple as this link: http://bmwtips.com/tipsntricks/tips_...ecognition.htm (this is a E39, however the E46 is the same concept, different install location)
3) If you have the phone preparation you should not require the installation of a microphone, it is already there. The pairing button and the box installation is correct.
www.x5world.com
Old 01-19-2005, 09:16 AM
Mein Auto: 530i
1) Yes
www.x5world.com
But you need the pairing button in addition to the button on the steering wheel?
Old 01-19-2005, 09:46 AM
Technic's Avatar
Mein Auto: 2017 M3
With the separate BT ULF module, yes...
Old 01-19-2005, 09:58 AM
Mein Auto: 530i
That's too bad. Many thanks for all your advice.
Old 01-19-2005, 10:45 AM
e36M3r's Avatar
e36M3r e36M3r is offline
Mein Auto: e46 M3
I'm not sure that is true for '05. I thought I read somewhere that you don't need a pairing button for the latest BT module. M3 Tech, if you can find him, seems very knowledgeable on this stuff. Do a search.
Old 01-19-2005, 12:12 PM
Technic's Avatar
Mein Auto: 2017 M3
I am M3Tech (Technic here)...
tmjb is asking for the separate BT ULF module, not the Assist/BT TCU, which you are correct, it does not have a pairing button. In addition, some of the OEM BT phone cradles comes with the pairing button as part of the frame, like this one (seems like a X5):
http://www.bimmernav.com/assist2BT.htm
Old 01-19-2005, 12:23 PM
Mein Auto: 530i
Thanks to you both for your replies.
What I am asking is for an '05 330 CiC without Assist can I install bluetooth (wiring and mic are already preinstalled right?) without having to use the cradle and pairing button, and instead use the button on the steering wheel for pairing/Bluetooth use? I would then only have to install the ULF in the trunk I beleive.
Old 01-19-2005, 12:32 PM
e36M3r's Avatar
Mein Auto: e46 M3
Ah... I should have realized. Hey, thanks for all the good information on this stuff, your help is appreciated.
So, on a 2005 M3 with nav and assist (premium pk), is the extra SES module needed?
FWIW: I've decided to go with a v551 since they have a snap in adapter for the 3 series, and also the Razr is just too expensive and who knows if there ever will be an adapter.
I'm picking up the car in Munich in March!
Old 01-19-2005, 12:35 PM
Mein Auto: 530i
I am too, mid March. How about you?
Old 01-19-2005, 12:40 PM
e36M3r's Avatar
Mein Auto: e46 M3
Yes, mid march, right now set for the 15th, but I may change it by a few days!
Old 01-19-2005, 12:48 PM
Mein Auto: 530i
I'm due to pick up March 18th. Maybe we'll meet?
Old 01-19-2005, 02:09 PM
e36M3r's Avatar
Mein Auto: e46 M3
I'll post as my plans get more solid. What are you picking up?
Here's my info:
http://www.bimmerfest.com/forums/showthread.php?t=84273
Old 01-19-2005, 03:02 PM
Technic's Avatar
Mein Auto: 2017 M3
You still will need to install the pairing button, tmjb... this is not the new TCU that got rid of that button. However you do not have to permanently install it (as in cutting a hole in your center console), just make sure that you have it easily accessible. And the cradle is an option, not a requirement.
The best post so far that I have read for a CiC BT ULF installation is this one: http://www.bmwboard.com/forum/showpo...9&postcount=34
... and you can read there that the owner did not cut anything to install the pairing button.
Old 01-19-2005, 03:04 PM
Mein Auto: 530i
I read your post with interest the other day.
Mine is my first BMW: 330 CiC, Sparkling Graphite, Black top and interior, Step (for my wife), Xenon, Nav, Assist (possibly - this is what I am trying to finalize becuase I want Bluetooth and voice activation but don't care to much about Assist), ZCW.
We intend to drive from Munich through Austria to Florence, Cinque Terre, Provence, Barcelona and drop off in Madrid.
Technic's Avatar
Mein Auto: 2017 M3
Your welcome... yes it is needed if you want voice commands, the SES is not part of the new Assist/BT TCU.
Old 01-19-2005, 03:09 PM
Technic's Avatar
Mein Auto: 2017 M3
Get the Assist and then order the SES thru Crevier or Circle BMW (it is plug and play) and you will solve your issue of the pairing button. After all, the price of the Assist will be part of your payment, and you will be getting a year of free service. You might use it, you never know (hope not)...
Old 01-19-2005, 03:18 PM
Mein Auto: 530i
Sounds like good advice. Thanks.
Old 01-19-2005, 03:36 PM
e36M3r's Avatar
Mein Auto: e46 M3
Sounds beautiful. The e46 cabs are probably better looking then the coupes. Tempting no doubt. Assist comes with the M3 premium package, so I'm getting it that way, doubt if I'd renew. I'm also getting a package that eliminates the steering wheel buttons including the phone button, but with Nav, I should be able to get back the (voice) features I hope.
Keep in touch.
Old 01-19-2005, 03:38 PM
e36M3r's Avatar
Mein Auto: e46 M3
OK, I guess that's BMWs way of getting a few hundred out of us, while still "including" Bluetooth for 2005.
Old 01-19-2005, 05:35 PM
Technic's Avatar
Mein Auto: 2017 M3
If you are getting the M3 ZCP I am not sure that the SES will work in your car. Unless the Nav phone button will be enabled for voice commands (by pressing and holding) just for the ZCP config, I do not know how you are going to activate the SES.
In the regular M3 full buttons steering wheel you only activate the SES by pressing and holding the Voice button below the R/T button; with Nav the phone button do not activate the SES. Ask this out to your dealer before ordering the SES...
Old 01-19-2005, 05:53 PM
e36M3r's Avatar
Mein Auto: e46 M3
Yes, ZCP. So we may not have the voice options, but the bluetooth phone should still work with the Nav to see the caller id, and to dial using the nav display / phone book transfer.
Old 01-19-2005, 08:01 PM
Mein Auto: 530i
I contacted Circle to ask about the SES for the 05 330CiC and so far they can't find one listed. I got a 'Hmmm'. I've them to investigate further.
Any ideas?
Similar Threads
Anyone? Can i add an Aux Input to 2005 530i? tcumbo 5 Series 9 10-21-2004 06:28 AM
Bluetooth w/assist installed. Question? tand Car Navigation, Audio & Electronics by BAVSOUND 18 10-14-2004 06:52 PM
Jon, Bluetooth order doubts... sarastro Regional Forums 8 12-02-2002 01:06 PM
