E46 (1999 - 2006)
Old 01-19-2005, 02:39 AM
troymerritt troymerritt is offline
Send a message via AIM to troymerritt Send a message via Yahoo to troymerritt
Mein Auto: BMW
Cool How do you pair a bluetooth phone with GPS/Assist
I have a 2005 M3 and I want to be able to pair my phone with my car. How do you activate the blue tooth in the car so that my phone will see it and so that I can add the passcode. I am having problems pairing it. I have done it on a 330I that did not have GPS but I can't figure out how to do it in a car that has the GPS. I guess you can't do it the same way.
Please help me with this!!!!!
Thanks Troy Merritt
Soldier in Germany
Old 01-19-2005, 05:15 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Thanks Troy Merritt
Soldier in Germany
Here you go... http://www.x5world.com/2005_bt_pairing.htm
Old 01-19-2005, 06:39 AM
Mein Auto: BMW
Cool Question regarding blue tooth
Originally Posted by Technic
Does the vehicle need to be turned on. What are the specific details on how to do this. Do I hold the button or quickly press down? Do I hold the button as I turn the key?
I have GPS/Assist. My vehicle is an M3. I don't know if that makes a difference or not?
Thanks, Troy Merritt
Old 01-19-2005, 06:44 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Troy, the procedure is the same as you did on the 330i. Yes, hold the key as you turn the key, it should ask for the passkey.
Also note that, before starting the pairing process, you should set the cell phone to 'Bluetooth visible' mode, almost every cell phone has this option in the bluetooth configuration menu.
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 01-19-2005, 06:47 AM
Technic's Avatar
Mein Auto: 2017 M3
Troy, the instructions are in that link...
PAIRING PROCEDURE E46/E83/E85/E53
1. Turn Key off and then to KL-R or KL-15.
2. The vehicle is ready for pairing for the first 2 minutes of key on.
3. "Activate Telephone" appears on the MID or Board Monitor.
4. During the pairing process, depending on equipment, the indicator lights on MID or Board Monitor display flash.
5. Your mobile phone should now be set to search for BT devices. See the Owner's Manual for your handset.
6. A request to enter a password, PIN, or code appears on the handset display, depending on your model. Enter the 'BLUETOOTH PASSKEY" (supplied with the vehicle literature), using the numerical keys on the handset and confirm the input. Look for a confirmation message on the handset.
7. To conclude the pairing process, turn the key off.
8. Wait approximately 30 seconds before turning the key back on. The phone will now be connected when the key is turned on. It may take several minutes to initially load the phone book stored in the handset depending on the number of entries.
Old 01-27-2005, 08:37 AM
trikerider trikerider is offline
Mein Auto: 2006 M3 -w- Everything
I'm going to feel sooooo stupid after I ask this question but . . .
What does, "1. Turn Key off and then to KL-R or KL-15." mean?
#750
| M3 | 2006 | 3-Pedals | Titanium Silver | Black Leather | Brushed Aluminum Trim | ZCW | ZPP | Nav | Sirius | Xenons | 19" Factory Wheels
Old 01-27-2005, 08:50 AM
#750
Found it - sorry.
http://www.bimmerfest.com/forums/sho...8&postcount=17
Hi, KL-R is ignition switch on RADIO position and KL-15 is ignition ON
(basicaly ignition switch has three positions 1st R,2nd ignition on and 3rd is start)
#750
Similar Threads
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 08:21 PM
Installed Bluetooth Phone in 2001 540i jwebster540i 5 Series 18 02-08-2005 09:44 AM
I have a Verizon bluetooth phone working with my BMW Dmitri Car Navigation, Audio & Electronics by BAVSOUND 2 02-10-2004 03:35 PM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 10:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 05:46 PM
