P Stackhouse #130 325i Race Car - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 01-19-2005, 07:58 PM
psrace13 psrace13 is offline
Mein Auto: 325i, M3, Z3
Contact
Pete Stachhouse
2657 Dresden Rd
Zanesville, OH 43701
home 740.607.9467
work 614.771.7744
Cost to have built: $42,000.00 Asking Price
$24,000.00 / $26,500.00 with fresh 2.5 short block
Car
93’ BMW 325i/ white/ 4 door
Suggested Classes Drivers Schools (could be driven to track) BMWCCA J Prepared / NASA German Touring Car / SCCA ITS ( with stock cams/ smaller tires & wheels) / SCCA DSP Autocross ( can be made legal for all classes listed. I have the parts and can install)
History
This car was purchased used in 2002 from a doctor in North Carolina. The car was used as a daily driver. Upon inspection, the car appeared to have been well maintained. I attended one driver school the day after purchase just to check the car out. I then parked it and began the preparation.
The car was immediately dismantled and inspected for chassis stress and worn parts. The custom TC Kline Roll Cage was welded in and all bushings and worn chassis parts were replaced with new. If there was any doubt…. The part was replaced.
With TC Kline (my boss) as consultant throughout this project, race prep was near complete in late summer 2003. I attended 3 track weekends for preliminary testing and evaluation of the car. Things went ok, but I still had some tuning to do….. back to the garage.
Further modifications were completed and the car went to Sebring for testing at the 04’ Winterfest event. The car performed flawlessly and was finally ready to race. This was a great test for my latest design sealed radiator shrouding. In the Florida heat, the temps stayed right where they needed to be.
I installed the ARJ ramp angle/ shimmed 3:91 limited slip differential and took the car to its first club race at Putnam Park. The next race was Beaver Run.
After winning the Beaver Run Race, the engine was removed and the cylinder head went to our engine builder ARJ Race Engineering to receive freshening, 7 angle racing valve job, lightweight valve train components and E36 M3 LTW cams were installed. Bored throttle body, larger HFM, Oscar Velez software, and custom intake were added to this package. At this time, a practically new (approx 5000 miles) 5 speed transmission was also installed.
The car has since run 2 more race weekends.
Important Note: An additional racing engine short block is currently ready to be built to match the ARJ race prepped cylinder head for this car and the fresh engine will be installed upon purchase. You can hear run, test drive the car, and purchase the car for a lower price as it sits today, just the way it left the track after winng both saturday & sunday at Mid Ohio Great Pumpkin Race. I would even consider selling without the engine. The new short block should add another 15-20hp
2004 Season Race Results Sat/ Sun
Putnam Park DNF (flat tire) / 2nd
Beaver Run 1st / 1st set track record ITS Legal
Mid Ohio 2nd / 2nd got excited & spun out while leading
Mid Ohio 1st / 1st beat some fast cars
Engine/ Drivetrain
ARJ Racing Cylinder Head w/ M3 Cams
Custom Racing Exhaust Burns Stainless
2 into 1 Merge Collector with 3” .065 Stainless
into Borla XR1 Race Muffler
TCK Spec /RC Engineering Throttle Body
Euro HFM
Custom Air Box/ Plumbing
K&N Cone Air Filter
Oscar Velez Racing Chip (tuned 2 times)
Custom Radiator Support/ Shrouding
Radiator & Hoses
Engine Belt
Water Pump & Thermostat
Aluminum 11lb Flywheel
Sachs Racing Clutch
JT Design Oil Dist Block
Custom Inline Temp Sensor Port
Transmission (5000 mi)
Driveshaft w center Bearing & Guibo
ARJ Racing 3:91 Limited Slip
Differential w Ramp Angle & Shimming
Wheels & Safety
TC Kline Welded Racing Cage
2.5 lb Fire Bottle
Team Tech Window Net & Mounting Kit
TRS 6 Point Safety Harness
Momo Hub Adapter
Momo Steering Wheel
Bicknell Quick Release
Tail Lights
Recaro Pole Position Racing Shell
& Seat Side Brackets
TCK Seat Mount
Recaro Flat Slider
SFI High Density Roll Padding
Goodridge Stainless Brake Lines
Hawk Blue Brake Pads F&R (60%)
4 SSR Competetion 17x9 wheels
4 used Hoosier 245/40/17 (35%)
20 TC Kline Pro Wheel Studs ( long)
20 Steel Nuts 17mm socket head
2 Wheel Spacers 18mm
2 Wheel Spacers 5mm
Suspension & Steering
Lemforder M3 Tie Rods
M3 Front Control Arms
Delrin Offset Front Control Arm Bushings
TC Kline Adjustable Camber/ Caster Plates
TC Kline Adjustable Rear Lower Arms
M3 Rear Lower Outer Barings
TC Kline Trailing Arm Bearings
2 TC Kline VVS Alloy Front Springs
2 TC Kline VVS Alloy Rear Springs (Shorty)
TC Kline Rear Ride Height Adjusters
2 Hyper Coil Rear Keeper Springs
Custom Quick Change Rear Spring Sliders
TC Kline Monobal Rear Shock Mounts
TC Kline / Koni D/A Front Coilover Struts
TC Kline/ Koni D/A Rear Shocks
Ireland Engineering Engine/Trans Mounts
Lower Steering Shaft , Joint , Rack Coupler
Body Shell & Chassis
Custom Gauge panel Inserts
Custom Aluminum Door Panels
Optima Battery
Custom Chassis Wiring Harness
Switch Panel w/ Marine Switches
Auxillary Fuse Panel
Starter Button / misc Switches
Auto Meter Ultra Lite Oil Pressure Gauge
Auto Meter Ultra Lite Water Temp Gauge
Auto Meter Ultra Lite Tachometer
Auto Meter Ultra Lite Voltage Gauge
ID:	43155   Click image for larger version
ID:	43156   Click image for larger version
ID:	43157   Click image for larger version
ID:	43158   Click image for larger version
Old 01-19-2005, 08:06 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Holy crap!
3.91!
Good luck with the sale, Pete!
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 01-19-2005, 08:15 PM
bmwork1's Avatar
bmwork1 bmwork1 is offline
Mein Auto: M-coupe
We have been using 4:33's in the world challenge 325cis....still see over 140mph at Road America, Mosport, and Road Atlanta with a 33% restrictor plate.
Old 01-19-2005, 08:20 PM
My.
What's the redline on them?
Old 01-19-2005, 08:47 PM
bmwork1's Avatar
Mein Auto: M-coupe
we have run redlines from 8250 to 8750 based on what was dictated by SCCA.....some of the motors in 2003 ran closer to 9000. For 2004 we were limited to 8250 to "reduce engine wear" by SCCA. Having the higher redline really helped make the shorter gear ratio sweet by reducing the number of shifts.....essentially the higher redline gave us a more trackable gear ratio. For 2004 we changed the cam timing to produce more HP at the lower RPM. Did a comparison at Road America with our 3:91 vs the 4:33 and we were never able to reach more than 138mph with the 3:91.....the 4:33 got us to 142
Old 01-19-2005, 08:50 PM
I had a sneaking suspicion.
Old 01-19-2005, 09:13 PM
bmwork1's Avatar
Mein Auto: M-coupe
a couple of places on the track we would bump into the rev-limiter with the 4:33 but with the 3:91 and the restrictor we just didn't have the juice to get the car to move as well....lap times slowed with the 3:91......Easy track/street upgrade is to change out the rear-end...relatively simple and cheap way to add torque and get into the power band
Old 01-20-2005, 03:20 PM
Oh Yeah! 3:91
Originally Posted by Nick325xiT 5spd
Holy crap!
3.91!
Cranking up the R's wins races. I realize the power falls off above certain RPM, but you can carry it further and pass others while they are shifting, especially when there is a short shift for others at the end of a straight. A competitor with lets say a 3:73 is always in the same gear as you at corner exit and typically running the same diameter tire. Coming off med or slow corner the 3:91 will get up and go, typically passing someone. Once you are in front, you have an advantage even against a faster car. I like it, it wins.
Turns approx 7450 at the end of the (longest straight) back straight at Mid Ohio. I forget, but I think the rev limit is around 7750. I personally would not twist a Legal JP engine much beyond that without expecting premature failure. After all, the prize money will not even come close to purchasing a Happy Meal.... Pete
Old 01-21-2005, 09:56 AM
Andy's Avatar
Andy Andy is offline
Mein Auto: E30, M3, 540i
Hi Pete!! Good luck with the sale. I really hate to see you get rid of ‘er, but can certainly understand. Like I said before, if you were putting this up for sale a year from now, I’d be all over it!! Good luck!!
Andy
- 1987 BMW 325is
- 2002 BMW M3
- 2003 BMW 540i Sport
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
Does buying a new car make sense? Moderato General Automotive Forum 22 12-04-2004 09:26 PM
PTG Phoenix Result - ***Real Spoiler*** SteveT Motorsports, Racing & Track 8 04-22-2004 05:51 PM
