E46 (1999 - 2006)
Old 01-21-2005, 11:42 AM
rrockinj rrockinj is offline
Mein Auto: 2000 328i
Replacing front turn signal bulb.
This is probably a stupid question but I'm a new BMW owner. I'm trying to replace my right front turn signal bulb in my 328i. The manual just says to release the hook with a screwdriver but I can't figure out exactly how do to this. Which way does the hook need to be pushed to release it?
Old 01-21-2005, 01:00 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
IIRC, it has to be pushed down; that being said, I never actually was able to get it unlatched... I had to get my SA to do it ( ), because I was cranking on it and nothing was happening... Be careful, it is easy to break it... so easy that they make repair kits that the dealer can sell you, to repair the broken hook... Good luck!
Old 01-21-2005, 01:11 PM
Bill325Ci's Avatar
Bill325Ci Bill325Ci is offline
TXSunDvl
Mein Auto: '01 325Ci, ZSP, '08 CR-V
Maybe this will help:
http://www.my330i.com/mod2.php
The failure of Government Interference is always blamed on the astounding conclusion that Government didn't interfere enough - Hayek.
Old 01-07-2011, 05:50 PM
dosan dosan is offline
Mein Auto: 08 BMW 535xi
Thanks for the links with pictures... !!
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Front bumper in bad shape on underside - worth replacing? halsnook 3 Series & 4 Series 1 06-18-2003 11:21 AM
How to remove front turn signal lenses? SG1 3 Series & 4 Series 3 09-30-2002 07:56 AM
Drivers side turn signal bulb ObD 3 Series & 4 Series 0 08-03-2002 10:35 AM
Roof not open, sit belt sign on, and no turn signal FrancisK 3 Series & 4 Series 2 04-18-2002 08:54 AM
