E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Impressions, problems at 5000 miles
Hello All
Have had my 2005 325i for a few months now with 5000 miles on it. I am seeing a few issues. This just started a couple of days ago. I hear like a rattling sound from near the front door or window on the passenger side. Tried to listen hard and it seems to be coming from where the door is fixed to the car or near the windows. Its quite irritating and feel like something is loose and might fall off. Just wanted to find out if any of you have seen any problem like this? The noise seems to come most when the road is not smooth ( like surface roads ) and it comes even while driving and braking on bumps etc. Will be taking it to the dealer but was wondering if it was something that I could set right? The other thing I have noticed is that if I leave the steering of the car it starts moving towards the right rather than go straight. Apart from these I havent really had any other problems and the car is beautiful. Makes me very happy .
You get a courtesy alignment from the dealer with a new car, but you have to request it within 1200 (or is it 1000?) miles. Maybe they'll do one for you if you ask nicely and tell them it has always been like this. |
I have the same rattle! I brought mine in a few days ago for a D pillar rattle and since that has been fixed, I was able to locate the rattle in the door panel. I am going to bring it in (again, third time) for them to fix it. I only seem to have it on the driver's side, but I am going to have them look at both.
Aren't they called "A", "B", "C"?
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm |
AZGal, I bet you dollars to donuts that the rattle is your front passenger seat headrest. Mine rattles as well. The steering is supposed to go to the right, slightly. If it's a marked shift to the right, your alignment or something is off. But otherwise it's normal, in case you fall asleep at the wheel.
2004 BMW 330i • 6MT • Orient Blue Metallic • Sand Leather • Black Cube Trim • ZHP • ZCW |
is the radio on when you hear this? For a while they had issues with HK sound and rattles in the speaker grilles.... also ( and I feel silly about it) the seatbelt buckle gets hung up on the seat release, and can rattle you crazy before you realize it.
You have a coupe, I have a sedan, so I don't have your problem. My front passenger seatbelt still manages to knock against the side like crazy when my windows are down and I'm going above 30 mph, though. Drives me batty.
Seriously, though, better to go off the road and hit a tree at 35 mph than crash into oncoming 35 mph traffic head-on.
For the record I would rather frankly the car not drift either one way or another, but remain dead straight in terms of steering setup.I am pretty sure, though, somewhere in the sea of paper that is my Mini Cooper library is some documentation on the alignment that sets up the car to drift slightly right i.e. in Britain you drive on the left, the crown of the road is set to be higher in the middle than the curb (due to the usual heavy rainfall), the combination of which is supposed to keep the car straight. YMMV I suppose.
1980 633csi (Retired 1985) 2005 325i (Retired) 2006 Z4 3.0si (Retired) 2008 135i vert (Retired) 2009 328i vert (Retired) 2011 335is (Retired) 2011 Z4 3.0 (Retired) 2012 328i Coupe 2013 M3 Coupe (Retired) 2013 650i Coupe |
, I've always heard that explanation I gave. Maybe it's just a bunch of fluff.
No rattles for me and I am kinda surprised. I had read alot about rattles. I am at 8000 miles and the car is still as quiet and tight as when I drove off the lot.
2008 M3 Sedan, Silverstone II, Fox Red Extended, 6MT |
I have just over 7K miles on mine and already I'm going to have to take it in to have the shade on the sun roof fixed for the second time. It's funny, I had my 328i for 5 years and never had a problem with the shade, I've had this car just over six months and it's broken twice. Kinda pisses me off.
"Life is all about ass ... either you are covering it, kicking it, kissing it, sitting on it or trying to get it." |
The buckle rattle happens when the buckle is in the middle of the belt and is allowed to bounce between the passenger seat and the B pillar. If you slide the buckle down lower, it does not have as much movement freedom. (Or slide it up, though it might come back down.) |
1. You can slide the belt over the seat side bolster. That way it won't touch the pillar panel anymore. 2. You can stick a small piece of self-adhesive black felt in the spot where the plastic buckle cover hits the pillar panel. I did #2 and it works like a charm, even driving at 80mph with all the windows open. adc 03 330 ZHP |
I've had my 04 330i for about 10 months now and it has almost 11K miles. I haven't had any problems with it except for a noisy gearbox which BMW insists is normal, it works fine but it's just a bit too noisy when the car is idling so it concerns me. If it's still noisy by 45K miles I'm going to push for a new one under warranty because I don't want to have to pay for a new one if it breaks at 50,001 miles.
As far as the rattles go, my experinence with cars is that unless you have a cushy suspension, with 14" wheels and lots of sidewall on the tires, on crappy roads every car is going to have some rattles. If the roads are smooth and you're getting rattling then it's something to look into, otherwise on bumpy, uneven roads which seem to be getting more and more prevalent in the US , then some rattling on a car with a million parts is going to be enevitable. Once you accept that fact the rattling won't bother you anymore.
It's your seat belt metal buckle hitting on the plastic trim!!! |
Solved
Hiya
Did some investigation and the rattle seemed to come from the seatbelt on the passenger side. Wow quite an irritating one. Now that I found the problem , took care of it and its gone . whew.. And the fact that the car is supposed to slide to the right is so interesting. Never thought that it was actually thought of and implemented. ![]() I am back in the happy zone. Thanks for your replies. |
#25
Usually, it's not a problem for me, and I've only had to move it a few times. (I just reach over at a traffic light.) |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wall Street Journal reports reliability problems | Robert A | 5 Series | 10 | 11-18-2004 12:40 AM |
| 5000 mile impressions - 2004 530i (long) | nickferr | 5 Series | 8 | 09-24-2004 08:40 PM |
| I guess BMW's aren't the only ones with rattles... | chalkem77 | General BMW | 16 | 03-20-2002 12:00 PM |
| Problems with new 7-series | SchwartzBlack | General BMW | 3 | 01-14-2002 07:13 PM |
