Common issues with the N62 engine. (Mods, consider making this a sticky)
1 reading
233K views 71 replies 36 participants last post by  The Thomas J
#1 ·
As a member of this forum for 2.5 years, I feel that creating a dedicated thread like this would help prospective owners and current owners find answers without having to use the search function to a common issue. Plus, it would be a lot more convenient to find the answers immediately.
Okay, onto the topic of this thread.
What is the N62 engine? It is a naturally aspirated V8 engine created by BMW in 4.4L and 4.8L forms(for North American models). This engine can be found in the following models:
2002-2005 745i, 745Li
2006-2008 750i, 750Li
2004-2005 545i, 645Ci
2006-2010 550i, 650i
2003-2006 X5 4.4i, X5 4.8iS
2007-2010 X5 4.8i
The engines perform well, but they do have a number of common issues, which include but not limited to:
Leaking: valve cover gaskets, upper timing cover gaskets, alternator bracket gasket,
Valve stem seal failure
Coolant transfer pipe seal failure
Secondary air system failure(limited to models with N62B44 4.4L engine).
Others are welcome to add if I missed any issues regarding the N62 engine. Hope this helps!
#2 ·
common issues? This motor is the sole reason i will never buy another v8 powered BMW, Besides making decent power, these things are crap, expensive as hell to fix, and not very friendly to the DIY'er. Trying to troubleshoot one of these things yourself is going to put you out of a lot more $$ than you think you are saving. Best bet is to roll in to the stealer, bend over, and spread em wide. Hopefully you know a good indy that specializes in BMW.
#3 · (Edited)
The motor seems to be an old Northstar design, it has potential, and should be pulling a little over 380hp. The air pump yada yada, the intake manifold, and the Vanos system is crap.. If we could get an updated Intake manifold, and air pump mor or delete with a new efi mapping that be awesome...Meanwhile id like to slap a SRT8 or SRT10 Mopar...lol
#4 ·
Northstar, funny you should bring that up. Another overcomplicated motor to steer clear of. I LOVE Cadillac and fantasized about having one since i was 5! No chance in hell i'm touching anything with a north star in it.
#71 ·
As long as you get the right year of the Northstar V8, You won't have many if any problems. I Have one now. 2011 DTS. Just shy of 200.000. Had to replace alt and water pump. Car has gone through several states with out a problem. That's all that I had to replace in 4 years.
#6 ·
it's not a matter of difficulty to troubleshoot, but there are a lot of things that are unique to this motor, and a lot of parts that will need re programming if they are removed. Lots of stuff that you would end up in the shop for if you started trying to fix. There are also a lot of things that need to be done a certain way, and not the way you would do on any old car. If you dont do it the way the n62 likes, it's gonna break again a month later.
#7 ·
There are not many things to do out side of the box, on the N62 engine. Simple programming or remapping of the engine would become very expensive, & and there is a lack of aftermarket parts to support the positive gains. The only positive move for HP on a E63 or E64, is a move to the M6.
#8 ·
Well back to topic..
The common problems with the N62 engine are:
  1. The Alternator oil seal
  2. The leaking Coolant resovoir
  3. The small coolant recovery hose on top of the rad
  4. The peep hole leak by the water pump on the engine block
  5. The diaphrams on the valve covers
  6. The dreded valve stem seals
  7. The valvetronic motor malfunction
  8. the bad oil pump caused by bad LOF service
If you guys have others in mind please add..
  • Like
Reactions: Carbonsuz
#9 ·
OK Guys, I'm puzzled. My 07' has 77k miles on it. I drive about 12k miles a year. Had the car for 3.5 years so about 40k +- miles on my dime.
Other than the Mechatronics sleeve that was replaced under warranty, I have had ZERO issues. Really, none. All I have done is change the oil about every 5-6k miles, change trans fluid at 60k, brake fluid at 60k and changed the PS fluid at 60k, and a battery.
All of my expenses have been in upgrades, not repairs. :thumbup:
So maybe it would help if any complaints/comments about the N62 engine had a year, mileage and trans type. We all know the SMG trans can be a challenge.
I know I'm not alone, several members have had cars well in to the 100k zone with good success and reasonable costs.
I'm just wondering why cars some seem more problematic than others. :dunno:
#10 ·
I suspect that most of the cars we have purchased were off lease. A leased vehicle is usually not taken care of as well as a purchased vehicle. 5k oil changes along with good PM's, go a long way into taking care of the engine & tranny. Gary has a very good plan!
#11 ·
4.8 ltr owner
I do see allot of negative comments. Unfortunate.
In April 2016 I purchased a 2007 650 convertible with the 4.8 & 54,000 miles. I wanted a convertible, possibly a Mercedes SL. I settled on the 650 for the back seat, for what its worth, lol. I had wanted for a rag top for years but I got an interest in BMW only lately.
I truly love the car. But haven't had it long. There are many reasons to like it but one of my biggest is the motor/drive train. The motor has plenty of torque and feels like an old american big block to me. Not what I expected and love it every time I press the accelerator. I am approaching 70k and so far so good on the motor.
I will keep everyone posted.
Greg
#12 ·
I agree with Roeng, my 2009 650i has around 55K miles on it, and no real issues. Like him, around 50k miles, I replaced the radiator fluid, brake fluid, power steering fluid, and routine oil changes. The only "problem" I've had to fix was when my oil pressure sensor finally died a month ago... a $20 fix (and that included new gaskets for the vacuum pump).
that said, I would like to replace my transmission fluid, as my shifting feels sluggish at times. I'd also like to replace the solenoids and various gaskets that are prone to go bad in these transmissions over time. The main thing holding me back is the PITA protocol for adding fluid back in... I'm not looking forward to crawling under a car while it is running and in Drive.
#14 ·
As long as you use a lift or a good set of jack stands, it is not to bad. It is a 2 person job to get it done correctly & fast, without making a mess while adding the fluid. I think that a hydraulic quick connect with a 90 degree fitting would be a good thing to install. This way you could use a quick connect that will close off after adding the fluid, & have better access to connecting your pump to the quick connect. Adding a regular 90 degree fitting with a plug at the same level, will still give you better access to installing the plug. You just need to make sure to keep the fluid level at the same height.
#13 ·
Too bad this thread took an election season like turn immediately.
I think the couple of posts that list weaknesses cover it.
FWIW, I've had my 07 650 since 2009. I bought it after a fallen tree totaled my 88 635csi and my partner begged me not to buy another old car when I started searching for a replacement. You could say I'm a fan of the big BMW coupes. I wanted a low mileage non rust belt 6 speed so the search took several months and some travel. I ended up finding what I think is a rather cool and hard to find equipment list (6 speed manual, pearl leather, HUD, night vison, whatever the upgraded sound system was called) on top of the sport and cold weather packages. It had 13k miles at the time, it is now at 60k, not a daily driver, mostly used on long highway trips (regular 220 mile drives and covered 800-900 miles per day several times).
I'm a believer in a old school type of maintenance schedule so it has has no oil change interval longer than 7500 since I've bought it, manual trans and diff fluids changed at 30k miles and again just now at 60k, power steering fluid at 35k, plugs and belts just changed at 60k. Coolant is every four years, brake fluid, air and pollen filters every 2 years.
As far as repairs I had a failed sill plate light replaced under warranty, there was the brake booster recall, and I think another recall related to battery cables. Out of pocket repairs have been the IVM which cost $100 and some of my time searching for cause of issue and an hour to DIY replace. I replaced the battery and it's on its third set of tires. Due to highway driving and stick shift the brakes are still original as are all suspension parts.
So far it's been an awesome car. Not cheap because I don't do all the maintenance myself, I use dedicated BMW shops, and I only buy Michelin or Continental tires, but the actual repair cost for a non wear items over seven years has been a whopping $100!! What's not to love?
I know it will eventually have leaks, but I am monitoring the situation and I will bite the bullet when the time comes. It will be cheaper in the long run than depreciation on a newer 6 series or equivalent, and I'm fairly attached to this car.
Everyone will have a different experience with their E63/4, but I fall under the no regrets category.
owns 2018 BMW 540i x-drive
#15 ·
My thanks to the OP, carraz, and a couple of others. I do find this thread helpful. It should be pruned of comments about the quality of the engine, and then posted as a sticky. It can be enlarged to include discussions of maintenance schedules (as Fredo has done), and more detail on the common problems and what they cost to fix.
#16 ·
Glad to hear that this has helped you out.
Whenever I google search "BMW N62 problems", this thread becomes one of the first results. :thumbup:
#17 ·
I have a 2009 650i with about 60k miles bought CPO post-lease with 33k miles. Here's a list of N62 powertrain issues:
1. Two upper timing cover leaks, fixed under CPO warranty. Valve cover gaskets replaced in process.
2. New transmission, replaced under CPO warranty.
3. Leaking brake vacuum pump, warranty.
4. Leaking alternator gasket, replaced under warranty.
5. Bad pre-cat oxygen sensor, replaced DIY, about $100.
6. CCV valve replaced DIY, about $20.
Other non-powertrain issues:
1. Stuck CD changer cartridge. Fixed DIY.
2. Stuck center console. Resolved itself.
The car is a beast. Just took it on a round-trip to Houston last weekend cruising at ~80MPH and got 24+MPG. That's pretty amazing for an engine that big/powerful.
Cheers!
#18 ·
How much power can the N62 handle?
Hey everyone, I have been reading these forums for over three years now. I have an 05 745i with 92,500 mi on it.
I already fixed all the issues that goes wrong with this car, & now im in the upgrading stage. I already put BC Racing coilovers on it, AFE Stage 3 cold air intake, AFE throttle body spacer, Chipped with to OBD2 for additional 42hp, 37tq, dual in dual out cat back flowmaster exhaust, slotted rotors, replaced transmission, drained then filled fluid 3 times, replaced rear end fluid with Red Line fluid.
But i want more power. From my calculations i should be making 400 hp to the engine. Im also on 22in rims.
Being that this car is roughly 5000lb, its not enough power for me. Also this is my weekend car, so I drive it hard when I bring it out, be looking for a street race lol.
I'm thinking about adding nitrous to it, but not sure what this engine can handle before I destroy something. The kit I'm looking at is a NX wet up to 150 shot. I was planning on using the 100 shot tip.
So does anyone know for a fact can this engine handle 500hp? Thanks
#39 ·
...I'm thinking about adding nitrous to it, but not sure what this engine can handle before I destroy something. The kit I'm looking at is a NX wet up to 150 shot. I was planning on using the 100 shot tip.
My ALPINA B7 is running that kind of Horsepower right out of the box.
#19 ·
^^^^Put nitrous on the car, and soon after it will be on a flatbed going to the junkyard. Seriously, why would you want to push a car to do something it's not good at?
Do yourself a favor, but a 3-series and take it to the track and eat Porches.
Back to the engine,,, yep it is a beast. It sounds/burbles like an old 70's muscle car (I have cat back exhaust), makes good torque down low, but it also has top end. Unlike the muscle cars, the Beemer makes power all the way up to 6grand. Who said vanos was crap?---lol. That combined with TC/DTC means you can WFO from mid corner w/o worries. In the wet, it does a great job of keeping the rear end from stepping out too much. And the greatest thing, you can turn all that electronic nanny **** OFF. :thumbup: That's a beastly car imo.
#20 ·
I found this thread to be somewhat informative. I sense the engine is, for the most part, a strong dependable engine. Compared to other engines in this arena, it ain't bad at all. I notice there is much complaining about things OTHER THAN the engine. Drain tubes, failing water pumps, alternator this and booster that.
I offer you this: other than the common issues which would include leaky valve covers and timing chain covers it seems to hold up well. I cannot speak to valve guide issues. Mine is a 2009 650i with sport package. All the issues, except for the water pump, I've fixed. Transmission issue, thruster bushings, vacuum pump leak, gaskets, spark plugs, fluid changes... All done. Zero issues. But, I paid to get it this way just like Treyopound305. Even threw on a set of cross-drilled rotors, Hawk pads and BC coilovers.
#21 ·
Once you have the issues fixed (as I'm about to do, preventatively, before my aftermarket warranty runs out), how expensive is this car to maintain? Once I've addressed the usual problems, how much expense should I anticipate in routine and preventive maintenance? (I have a good independent mechanic. He's not cheap but he's honest and reasonable.)
#22 · (Edited)
BMW V8 issues
Problems with this engine start at around 100k miles.
For me to fix all the issues I removed the whole engine.
Mostly leaks is the problem.
Replaced:
the rear coolant cover
rear main seal
side oil cooler seal
front diff seal
front main seal
all oil pan seals
all head cover seals
all timing chain tensioner/rubrail/etc. Leave them be and youll be buying a new engine
front engine cover seals
water pump with new stint for Oring seal
valley cover seal
coolant hoses that I could not replace the Oring
The way BMW over engineered the engine, makes it prone to issues, reliability. Too many points of failure.
Too many O rings in stead of AN fittings.
Eccentric valve system is another issue that will leave you stranded. BMW should have left this out.
I'm sure I am forgetting more parts and issues. All these issues can bring down BMW in the long run. Right now it affects us the consumers with cars worth half in 3 years.
BMW should put reliability 3 times ahead of "over engineering"
I will keep my 89 5 series for a long time.
https://www.youtube.com/watch?v=6UNDSKCguqc
#24 ·
Replaced:
rear main seal
front diff seal
front main seal
all oil pan seals
valley cover seal
I have to disagree. All of the items you mentioned above happen to ALL CARS. Not just BMW's. The e36 and the e46 M3's were over-engineered to intentionally take abuse. I can say that since I've owned four (4) M3's over the years. Nerve pain in my leg forced me to buy an automatic PHucK! These cars were not made to go nuts in. It's a friggin highway car, a cruiser; not a stop light-to-stop light car. Take care of it, it will take care of you.
BMW's as most German cars are the bomb! Look around at us and the rest of the general public. We buy these for status and good build quality. People pay dearly to own cars of this quality. And, yes, they do break. And they are goddam expensive to repair. But our cars will outlast most other cars currently on the road....including some of the new ones of other brands.
You complaining? Sell it. Can't afford it? Shouldn't of bought it.
Now that all those items were fixed, I gotta know: how's it driving?
#25 ·
I have a related question. I have a 2005 645 that I have maintained well with 144K miles and still haven't had the dreaded coolant pipe issue. An independent shop suggested I have the alternative solution done for a little less than $3K as preventive maintenance. I'd appreciate everyone's thoughts. I love this car and would like to keep it a few more years. Has anyone else with an N62 engine gone more miles without the coolant pipe issue?
#27 ·
Taking care of a care properly, keeps the gremlins away. Leasing a vehicle that is turned in, who cares how its taken care of, its not your future problem! Most of us have purchased 2nd or 3rd hand, & acquire someone else's problems. This is where the problems start failing after the factory warranty, & they can get quite expensive. Proper PM on a car can make a huge difference in repair cost. It sounds like you have taken care of your car, & the problems have been minimal. I would wait until your coolant pipe becomes a problem, then address the issue. If you are going to change the water pump for some reason, I would do the stent at that time.
#26 ·
If you want to put a preventative fix in don't go with a pipe replacement which runs $3000 or so, go with the Bimmerfix Stent for N62 coolant pipe transfer. The Stent is $200 but then you have the labor to pull the necessary front of the engine parts to insert. Still way cheaper!
#28 ·
I bought mine CPO with an extended warranty when it was 3 years old after it was turned in from a lease, and have had it for 8 1/2 years and 100k of the 144k miles. Oil leaks started around 92k (6 years old) and I've had most of the gaskets replaced (not cheap). Otherwise it's been great. While the service manager encouraged the coolant pipe job for preventive maintenance, when I talked to the actual mechanic in private, he felt I should wait until it actually starts leaking coolant. All in all, it is by far my favorite car, including a '66 Mustang, '80 280zx and 3 other BMWs.
#30 ·
Guys, just picked up an 08 /650i with 65K on the clock, im familiar with 4.8 bmw engine, moving from previous 550i.
Came with Dinan exhaust , already:thumbup:
only downside is that I was used to a clutch..... this on is auto...:cry:
is the dry weight of these cars 3814 lbs? that's only 154lbs difference from a 4dr (550i) ..
how are you guys holding on to 5.0's,6.2's, and srt-8s?
#32 ·
2008 BMW 750 Li with new seals still burns oil
I picked up a gorgeous 2008 750 Li with 72K miles on it. After I got it home I notice an oil leak that was the size of a quarter on my garage floor. This grew to become a half a quart. The repair was the infamous: valve cover gaskets, upper timing cover gaskets, alternator bracket gasket. This was $about $1800 from Boise European Motors. The Dealer wanted twice that.
A year later my car now has 83K miles and (knock on wood) has zero oil leaks having all that work done. However, it STILL BURNS oil. It consumes about 2 quarts of oil over 3K of driving. I was told to consider using a thicker grade of oil to reduce that oil loss.
The car is beautiful and fun to drive, but consider this I would never buy another V8 engine from BMW until they fix their issues. This engine is complicated, very, very expensive to repair and even when fully repaired still burns oil.
One comment on oil changes. During the 2008 period BMW said the oil was good for 15K miles between changes. This is why I think so many cars in part are having seal issues. The oil breaks down after 5K and the seals become chemically fatigued and brital. I highly recommend you DO NOT wait 15K to change the oil. I'm doing mine every 3-4K to protect my seals.
Good luck folks!
j-dawg
#34 · (Edited)
Newsflash. Wasn't just "during the 08 period", it was from 1997 model year (ironically when BMW started the 4/50 maintenance) until sometime in 2012 model year.
Now that you've discovered 15k oil change interval was bad news, what have you done about lifetime trans and diff fluid?
Sent from my iPad using Bimmerfest
