E46 (1999 - 2006)
Old 01-23-2005, 10:05 AM
MC's Avatar
MC MC is offline
Mein Auto: '02 325i Sport
Angry Rattling Noise Cold Start!
I noticed a rattling noise in the engine on cold start in am. I sounds like the noise is coming from the front engine. The rattling noise dissipates after the engine warms up. It only happens in cold start then goes away afterwards.
Does anybody experience similar problems? Any advise is appreciated. (02' 325i w/SP)
Old 02-20-2005, 02:44 PM
kataliyst kataliyst is offline
Mein Auto: BMW 325XI
I seem to be getting terrible noise from my engine as well and I just bought a 2005 325XI in November. It runs fine, but sounds terrible. It is about -5 to -10 average here and we are in February right now. Not sure if that is normal in these weather conditions, but I do not like it.
I have asked if I can compare the sound at the dealership to another.
Old 02-20-2005, 03:24 PM
opelrsx opelrsx is offline
Send a message via MSN to opelrsx
Mein Auto: BMW 2k4 330cim
I am in an opposite situation.. the rattle noise only appears when the car warmed up, and only at a certain rpm about 1000~1200 I am taking it to dealer next tuesday see what the hell going on
2k4 330CI ZHP
Eisenmann Race;UUC EVO III SSK;UUC Underdrive Pulleys;ACS Racing Strut Bar;ACS Pedals;RE Clutch Stop;6speed OEM Illuminated Shift Knob;Bodycolored Reflector;Bodycolored Keyhole Cover;CF Roundels;
Old 02-20-2005, 07:14 PM
doeboy's Avatar
doeboy doeboy is offline
DHP pwns ZHP :p
Mein Auto: DHP Heehee... :p
What's your oil level in the car? When was the last time you checked it? Could be valve/lifter noise...
'03 330Ci DHP
'06 M3 SMG
"du hast mich gefragt, und ich hab nichts gesagt"
Old 02-21-2005, 07:46 AM
edsmax's Avatar
edsmax edsmax is offline
I shift my own gears!
Send a message via AIM to edsmax
Mein Auto: Orient Blue 01 330i Sport
I believe its the air pump under the hood (cylinder, black object on RH side of engine bay). Part of emissions equipment, most seem to make a "rattle" noise on cold start up and then disappears after 2 minutes.
I could be wrong but others have found this to be making the noise you are referring to. I forgot if it is called AIR PUMP or AIR INJECTION PUMP or neither...try a search on those.
Ed
Mods: BMW OE Clear corners, OE aluminum ///M shift knob, GruppeM CAI, UUC Clutch stop
Old 02-21-2005, 07:49 AM
edsmax's Avatar
Wait...its called a "secondary air pump". Check this link...
http://www.bimmerfest.com/forums/sho...light=air+pump
The noise is normal.
Ed
Old 02-21-2005, 08:04 AM
Blax's Avatar
Blax Blax is offline
Le fabuleux destin
Mein Auto: F30 328i x two
Mine sounds like the belts squealing (high pitched) but lasts about the same amount of time in the cold. It's not a rattle. Is this the same thing?
Old 02-21-2005, 11:54 AM
edsmax's Avatar
No, more than likely it IS your belts. Get some belt spray at your local parts store--this should quite them down or at least you can eliminate that issue. If it is the belts and the spray doesn't work, you need the belt tightened.
Ed
Old 02-22-2005, 06:42 PM
65Cobra 65Cobra is offline
Mein Auto: 2002 325i
I too have an '02 325i with SP and noticed a noise during the first couple minutes of a cold start this week. Sounds like its coming from the fan area behind the radiator. Haven't looked further.
DO NOT USE BELT SPRAY! That stuff is made for the old V belt systems.
Old 02-22-2005, 08:55 PM
MC's Avatar
MC MC is offline
You are exactly right to where the noise is coming from.
I called the dealer to make an appointment regarding the noise. It's more like a rattling squealing noise at the same time. The minute I describe the conditon, I was told that it was a normal condition. Most of their loaner cars make the same noise on cold start.
It's strange, it didn't make that noise for the first year we owned car.
Old 02-22-2005, 09:27 PM
Test_Engineer's Avatar
Test_Engineer Test_Engineer is offline
Drives cars for a living!
Mein Auto: 2011 BMW 335i
Ed
This is what my service rep said it most likely was on my car as well.
Simptoms:
It only happens on first cold start. Happens below 45 degrees. lasts about 1-2 minutes. Sound is louder/quieter when A/C is turned on/off.
I had them check it out when I had my regulators replaced, but obviously they couldn't reproduce it due to the fact that it wasn't the first cold start of the day. They want me to bring it back in on a colder day to soak over night. Warrenty is up on the 27th
Old 02-22-2005, 09:33 PM
Niftster Niftster is offline
Mein Auto: a beater right now
I had the exact same symptoms around 60k miles in my 323. It sounded like a belt. When I took it in, it was something with the fan and they replaced it. It didn't make the noise when I arrived, but as I described it the tech seemed to know almost what it was. They had to order the part.
Old 02-22-2005, 09:59 PM
doeboy's Avatar
DHP pwns ZHP :p
The tensioners commonly make these noises too.
'03 330Ci DHP
'06 M3 SMG
Old 02-22-2005, 10:12 PM
icky's Avatar
icky icky is offline
Send a message via MSN to icky
Mein Auto: 2006 325xi
i think BMWs just dont like being cold in any way shape or form.
Old 02-27-2005, 12:00 AM
Jspeed Jspeed is offline
Mein Auto: E46 330i
I experienced the exact symptom, and the dealer traced the problem to the belt tensioner.
Old 02-27-2005, 01:48 PM
robj213 robj213 is offline
Mein Auto: 2003 325i SP, Xenon
My car has been experiencing the same problem as well, I meant to take it to be looked at for a few months now but will finallly take it in a week. But from speaking with a BMW tech, he mentioned the belt tensioner as well.
Old 02-27-2005, 02:38 PM
Blax's Avatar
Le fabuleux destin
I had the dealer look at it 2 or 3 times and eventually gave up. Either the dealer changed the tension and it came right back, or it was too warm the day they had it and they could not fix it. I have two 3s and a 525i which all do the same thing (same engine in all three) so I am getting a new 3 and hoping the e90 is better.
Old 02-28-2005, 04:04 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Had the same problem and they put in a new tensioner but after awhile the noise came back.They put in a up dated hydraulic tensioner and the noise never came back no matter what the weather was.
Good luck
vern
Old 02-28-2005, 09:26 PM
Good luck
vern
Hydraulic tensioner? Sounds interesting, do you know what the original one is?
I'll mention that to them when I am there.
Old 02-28-2005, 09:34 PM
doeboy's Avatar
DHP pwns ZHP :p
It's a spring loaded tensioner... there is a Service Bulletin on that.
They thought that was why my car was making the squealing on cold start, so they were about to replace the tensioner when they took a look and discovered I already have the new style hydraulic tensioner. So for me, it's something else...
'03 330Ci DHP
'06 M3 SMG
Old 02-28-2005, 10:51 PM
are 04 cars have the new version tensioner?
2k4 330CI ZHP
Old 02-28-2005, 10:54 PM
doeboy's Avatar
DHP pwns ZHP :p
Could be.... my '03 has the new tensioner already.
'03 330Ci DHP
'06 M3 SMG
Old 03-01-2005, 05:00 AM
SPRING TENSIONER
Old 03-01-2005, 05:32 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
The redesigned tensioners will help with the cold startup noise as long as what your hearing isn't actually a loud emmissions secondary airpump rattle/squeak.
Old 03-01-2005, 12:39 PM
My is an '03 too, but a early production '03. The suspense holds until next week! Hope they will be able to get it right.
Similar Threads
2003 320 Whining noise when started in the cold mliwanagcert 3 Series & 4 Series 15 12-17-2004 09:43 AM
Rattling noise (part 1) Ron Stygar E36/7 Z3 (1996-2002) 24 07-18-2004 06:25 AM
Help on BMW Assist and static noise 330SMG 3 Series & 4 Series 10 12-19-2003 07:58 PM
cold start clinking noise sj-02-325Cic 3 Series & 4 Series 13 04-05-2002 10:02 PM
