E46 (1999 - 2006)
Old 01-24-2005, 10:58 AM
dream_machine dream_machine is offline
Mein Auto: bmw 325i
Oil level
Just did my very first oil ever yesterday!!! Things went fairly smoothly but I think i added a little too much oil. The ideal level is between the middle part of the dipstick, but mine shows approx. 3/4 way of the indicator. Is this ok or should I drain some of the new oil out?
Name:	oil level.jpg
Old 01-24-2005, 11:59 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
Are you saying the oil is to the blue arrow?
If so that is where it should be. If anything its a 1/8 - 1/16 quart low.
Old 01-24-2005, 01:01 PM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
If the oil level is anywhere on that block in the middle, then you are in the "OK" range, though if it is below the middle, you'll start seeing the "low oil light" come on when you start or shutdown the engine.
I usually get the new filter soaked with new oil, then put in 6 quarts, then run the engine for a while and see where the oil level comes out and top it off if needed. Then over the next couple of days I keep checking an top it off as necessary, just to be sure.
How many posts could a repost post if a repost could post posts?
Similar Threads
Oil Level Too High markseven 5 Series 4 08-30-2004 03:39 PM
oil level? mallards 3 Series & 4 Series 4 02-24-2004 09:56 AM
Water Pump <--> Oil Pump - Relationship???? KenC-VA 5 Series 3 11-03-2003 10:16 AM
Curious oil light and engine oil fluctuations. C-Bear General BMW Questions 1 03-11-2003 07:41 AM
Is the war about oil? nate Off-Topic 10 02-18-2003 06:06 AM
