E46 (1999 - 2006)
Old 01-24-2005, 01:17 PM
Megatron Megatron is offline
Mein Auto: 330i M Perf Pack
Handbrake - How many "notches" to stop car
Maybe it's just me, but I find that if I want to park on a mild hill, I've got to pull that handbrake up to the maximum travel to keep the car from rolling. Is that normal? In my previous car, if I want to park my car on a mild hill, I would need to pull on about 4 notches to hold the car...maximum number of notches if I want to park on a steep hill.
Dealer said the handbrake will only hold when I pull it to the top, but considering that I need to pull it to the top to have it hold my car on a mild hill, I'm not sure if that is correct.
Just wondering if your handbrakes work the same way or does the brake engage earlier?
Old 01-24-2005, 01:30 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
I'll check again, but I think I've only needed to pull the brake about 6 or 7 notches max on a medium angle hill. Sounds like it's probably a simple cable adjustment might be necessary.
BMW-CCA
Bimmerfest Supporting Member
2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 01-24-2005, 02:35 PM
I'm thinking it is a cable adjustment as well, but dealer said it was normal and that I'm required to pull to the maximum travel for any incline.
Old 01-24-2005, 02:45 PM
allaboutme allaboutme is offline
Mein Auto: 3x330,AMV8,996GT2
Your dealer is lazy, simple as that. However, BMW states that the handbrake should light up on the cluster by the second notch. Mine needs to be pulled to the top after maybe 10 notches. It basically touches the arm rest. I can adjust it at any time by pulling off the handbrake shroud and tightening the nuts.
Old 01-24-2005, 02:54 PM
msbrown's Avatar
msbrown msbrown is offline
Z3 Crash-test Veteran
Mein Auto: 2002 325i
It's a simple fix
and I'm surprised more people don't ask for it. I mean, cables do stretch, fasteners become loose, etc. Once in a blue moon I'll get the car rolling (at about 5mph) in the parking lot and stop using the handbrake -- if I can feel it engage without having to pull it too hard, I figure I'm good.
Not that I ever want to have to try to really stop that way
Old 01-24-2005, 03:19 PM
atlau atlau is offline
www.cyon.com.au
Send a message via ICQ to atlau Send a message via MSN to atlau
Mein Auto: E60 525i E46 318i
huh?? 10 notches?
I've always pulled it to 2 only... and it seems tight enough. On a hill, I'll go up 3... but never more.
And it goes NOWHERE near the arm rest... I thought all bimmers were like that?
Old 01-24-2005, 05:08 PM
mkh's Avatar
mkh mkh is offline
Mein Auto: E90 330i, X3 3.0i
Originally Posted by atlau
huh?? 10 notches?
No, not all bimmers are like that. Both my 330i and X5 take 6-7 notches to fully engaged. 8 notches for a steep incline.
Old 01-24-2005, 05:10 PM
www.cyon.com.au
Oh no... is there something wrong with mine?
maybe diff between manual transmission and auto transmission???
Old 01-24-2005, 05:51 PM
Wow, that's a lot! Has it always been like that for your 330i since you've owned the car or only after a lot of use?
Old 01-24-2005, 06:02 PM
markl53's Avatar
I re-checked mine when I got home -- it's also about 6-7 for moderate tightness like I had thought. That seems pretty normal to me.
Atlau, if yours is fully tight at 2 notches, it may actually be adjusted too tight. The brake could be dragging even when fully released (IMO).
BMW-CCA
Old 01-24-2005, 07:09 PM
I also rechecked mine. Basically the car stops rolling at around 6 to 7 notches on a mild hill. It doesn't go any more than that. If that is what everyone else is experiencing, then maybe it is normal for my car.
I was expecting moderate tightness at 4 notches and 6 to 7 for use on those steep hills in San Francisco.
Old 01-24-2005, 07:44 PM
www.cyon.com.au
Hmm... come to think of it... i rarely park on hills, and 2 notches is pretty light pulling (conservative)... I think i can achieve 4, but I never want to... if my gf drives the car, she'll yank the thing to reach maybe 5... but i always tell her to stop after 2 or 3...
thanks for the opinion tho.
Old 01-24-2005, 07:49 PM
Rowag Rowag is offline
Mein Auto: 2005 330ci ZHP, 1998 986
Funny thread - I've always been anal about the parking brake, so here's my notes on my 2002 325ci:
- New: 2 notches stopped car on flat surface
- New: 3 notches on incline
- New: 4 notches on steepest incline
- Worn (several months later): +1-2 notches on all
The light has always come on *just* as it was hitting the first notch - I always remark at the precision of the contact point for that. Go German engineering!
As a general rule of thumb, though, I always tell the service guys to tighten the parking brake anytime they work on the rear brakes. If you need to tighten things before servicing the rears you can always use the nut under the parking brake boot.
TeeZee's Avatar
TeeZee TeeZee is offline
Freude am Fahren
Mein Auto: 2011 Z4 3.0i, 2003 325iT
Parking Brake Adjustment DIY
http://www.bimmerfest.com/forums/showthread.php?t=82648
2011 E89 Z4 30i Crimson over Ivory (Munich delivery, redelivery at Performance Center)
2003 E46 325i Touring Oxford Green over Sand
Old 01-24-2005, 08:15 PM
Terry Kennedy's Avatar
Terry Kennedy Terry Kennedy is offline
There and back again
Mein Auto: 2003 325xiT, 2006 Atom
Actually, it is an incredibly cheap plastic pin w/ a spring clip to hold the wire - see the attachment.
There are actually 2, one for each rear drum.
Old 01-24-2005, 08:35 PM
www.cyon.com.au
My light comes on slightly before the first notch. If i am driving, and slowly lift it, it starts beeping at me (swearing?!!)
Old 01-24-2005, 09:34 PM
mkh's Avatar
mkh mkh is offline
When both were new, they were about 2 notches less. Now after 38k miles on the 330i and 58k on the X5, they did loosen up a bit, but is nothing to concern. Also, both parking brake lights come on at the 2nd notch.
Similar Threads
Rotora Brake System Performance on BMW M3 Racer Car ralphwarren Motorsports, Racing & Track 6 03-13-2009 06:00 PM
Some F1 History... FSelekler Motorsports, Racing & Track 7 11-22-2007 10:11 PM
Autoxing an S2000… my impressions Andy Motorsports, Racing & Track 43 09-29-2004 09:04 PM
The saga of the Orinoco ZHP (very, very long) Orinoco ZHP 3 Series / 4 Series 15 01-07-2004 10:38 PM
Started to really like my car this past weekend... bmw325 General BMW 7 07-08-2002 09:02 AM
